Davej
Offline
« on: February 29, 2012, 05:05 PM » |
Hi, hope someone can help , I have inherited a porter cable 6 1/2 inch circular saw but no spanners to change blade , have tried to contact P.C. directly but being in uk can't register to ask them, saw is in immaculate condition but blade is past its best ( not even tct ! ) would appreciate any help as to the size of spanner to go behind blade, model no. is 346-1 , type 2 , serial no. A 14387 , any help greatly appreciated , thanks , Dave
I dont mind growing old but i refuse to grow up
Scott in San Diego
Offline
« Reply #2 on: February 29, 2012, 05:38 PM » |
Are you able to use a common box end wrench (spanner) or a socket? Probably Imperial size around 1/2" and lefthand thread.
Sparktrician
Offline
Location: Northern Virginia (That's in the USA, Pilgrim!) Member Since: Dec 2009
« Reply #3 on: February 29, 2012, 05:40 PM » |
My P-C 346 takes a 1/2" wrench to change the blade. Hope this helps.
- Willy -
MFT/3 x2, TS55, Guide Rails x3, Parallel Guide Set, CT22 w/Boom Arm, CT Mini, RO90, RO125, ETS125, RTS400, RAS115.04, C12 + Centrotec Imperial Bits, CSX Set, DF500 Domino Set, SCG-10, Domino Plate from RonWen, MFK700 Set, CMS-GE, OF1010, OF1400, OF2200 Set, LR32 System, MFS System, Syslite, Systainers, Sortainers, clamps.
Coming attractions: Carvex, Kapex, Ti-15, more "Stuff"-tainers...
Davej
Offline
« Reply #4 on: March 01, 2012, 09:07 AM » |
Thanks for your replies , seems the spanner I need is the jackshaft spanner , outer bolt is 5/8" so no problem with that one , looks like I will have to make my own for the shaft  , as its 1 1/8" and very slim , tried the old method of a piece of timber between blade and base but didnt work as everything rotated but the blade .
Scott in San Diego
Offline
« Reply #5 on: March 01, 2012, 09:21 AM » |
Thanks for your replies , seems the spanner I need is the jackshaft spanner , outer bolt is 5/8" so no problem with that one , looks like I will have to make my own for the shaft  , as its 1 1/8" and very slim , tried the old method of a piece of timber between blade and base but didnt work as everything rotated but the blade . Porter Cable router wrenches are 1 1/8" and rather thin, flat stamped steel.
Sparktrician
Offline
« Reply #6 on: March 01, 2012, 09:40 AM » |
Why not use the shaft lock plunger?
- Willy -
Davej
Offline
« Reply #7 on: March 01, 2012, 12:03 PM » |
My saw doesn't have a shaft lock as its rather old , bit like me  , but in much better condition than I am ! Managed to make a temporary spanner to get blade off so happy days, interestingly the blade had a knockout for diamond shaped arbor .
