Author Topic: Sander won't quit. Need Suggestions  (Read 2669 times)
Offline Dick Mahany
« on: June 12, 2018, 05:42 PM »
I have been wanting to get a new Festool Sander for a long time. The only problem is that my 20+ year old PC333 just won't die.  I have replaced one or two pads over the years and all in, I have less than $100US over that time.  My wife and CFO saw the price of the Festool sander [eek].   She purchased mine, so she knows what it originally cost.  I need need to make a convincing justification of why I need a new one when this one just won't quit.  Any  suggestions ?  [crying]
Offline Joe Felchlin
  • Just another day in paradise - Livin’ the dream!
Re: Sander won't quit. Need Suggestions
« Reply #1 on: June 12, 2018, 06:20 PM »
If you drop it often enough - Or from high enough - Or spill Titebond (I, II, or III) in the housing - IT WILL STOP - Permanently.
These maneuvers are best done alone (I.e. Sans the “CFO”)
I learned this long ago, when I opined to my new secretary, that our old (ancient) fax machine didn’t have any of the features of the newest models.
The next morning, she told me that we needed to requisition a new model.
The old (ancient) model, usually located on a table in our supply room -
Was laying on the floor in pieces.  [big grin]
Wonderful, resourceful woman - Worked for me until I retired - 26 years later.
She never missed “maxing” a raise. Worth every penny. [smile]
As for justifying Festool’s price for a new sander -
20 years of inflation - From the original’s $100 price - Ought to get you “close”.
And...
You can tell her that you need to buy it as soon as possible -
Because Festool products go up in price 5% every year.  [wink]
« Last Edit: June 12, 2018, 10:42 PM by Joe Felchlin »
FESTOOL: CT26 and CT33 E HEPA Dust Extractors, MFT 1080, MFT-3, TS 55 REQ-F-Plus USA, TS75 EQ, Guide Rails: 1080's/1400/3000mm, LR 32-SYS/Holey Rail, Parallel Guides and Extensions, OF1400 EQ Plunge Router, OF1010 EQ Plunge Router, HL 850 Planer, RO125 FEQ Rotex Sander, LS 130 EQ Linear Detail Sander, DX93E Detail Sander, C12 Cordless Drill, CXS Cordless Compact Drill Driver, SYS-Centrotec-Set, Domino XL DF 700 EQ Plus Tenon Joiner Set, Domino DF 500 Tenon Joiner | WOODPECKERS: DF 500 Offset Base System | BOSCH: 5412L Compound Miter Saw, 4100-09 10-Inch Table Saw | POWERMATIC: 60HH 8" Jointer, PWBS 14" Bandsaw w/Riser Block | MAKITA: 2012NB Bench Top Planer | JESSEM: Mast-R-Lift XL/Fence/Slide, Rout-R-Plate/Table Stand | RIKON: 50-120 6inX48in Belt-Disc Sander | JET: JBOS-5 Benchtop Oscillating Spindle Sander | PORTER CABLE: 7518 and 690LVRS Routers, 557 Pro Plate Joiner, 16/18/23 Gauge Nailers | LEIGH JIGS: D4R 24 Pro Dovetail Jig, FMT Pro Mortise & Tenon Jig | LIE-NIELSEN: Almost every hand plane | DOWELMAX: 3/8" and 1/4" | KREG: K3 Master System | FEIN: Multimaster FMM 250 Q Kit | TORMEK: Super-Grind 2000 | DUST DEPUTY: Industrial (ALL) Steel Deluxe Cyclone (2)
Offline Alanbach
« Reply #2 on: June 12, 2018, 09:06 PM »
How well does the CT SYS pick up dust from your PC? If it leaves dust residue on the workpiece then it is also discharging even smaller particles into your lungs. Although the Festool won’t be perfect it might be a significant improvement and that improvement might be the key to success with your CFO. Besides I see a lot of great Festool tools in the background of your pictures so you clearly know how to work with your board of directors😊.
Offline Alex
« Reply #3 on: June 13, 2018, 01:10 AM »
What a terrible situation where you have to ask permission to spend your money.  [huh]
Sorry, but if you're wife stands between you and your new Festool sander, she just has to go.  [wink]
Offline Sanderxpander
« Reply #4 on: June 13, 2018, 02:42 AM »
Dust collection seems a likely upgrade with a Festool. With that, the lifespan of your abrasives should also increase. And I don't know how vibration levels are on that PC but most Festools have quite low levels which prevent nerve damage. Perhaps even finish quality would improve?
Offline Peter Halle
« Reply #5 on: June 13, 2018, 06:38 AM »
Talk her into taking a “test drive.”  You’ve got thirty days.  If she does a side by side comparison and notices the differences then it will be her idea to keep it or send it back.
Offline McNally Family
  • Festool Atomic Phaser Particle Blaster (APPB Set)
« Reply #6 on: June 13, 2018, 07:39 AM »
@Dick Mahany
I would also discuss with her the advantages of Festools practically vibration free sanders, compared to the sanders of 20 years ago, and the potential damage excessive vibration can cause.   Here is an interesting article that will get you started on the subject:
http://www.vibrosense.eu/knowledge-bank/medical-background/hand-arm-vibration-injuries
GREEN: In order of purchase = | CT26  |  RS 2 E | Hose w/ Sleeve 3.5m | 115mm X 226mm Hand Sanding Block | 80mm X 133mm Hand Sanding Block | HSK D21.5 5m hose | CT Boom Arm Bundle Set | 1080 Plate for custom MFT | OF 1400 EQ Router (metric) w/accessories | SYS-Rock BR10 | Cordless Sander RTSC 400 Set |  Cordless Delta Sander DTSC 400 Basic | Linear Sander LS 130 | PDC 18/4 set | CXS  2.6Ah Set | Installer Cleaning Set (2018 version) |  New style Festool hose D 27/32 x 3,5m AS/CT | Replacement Hose Garage | Remote control CT-F I/M-Set | MFH1000 work stool | Next purchase: TBD
RED: // Mafell P1cc  //  MT55cc  // Next purchase: TBD
Offline Wooden Skye
« Reply #7 on: June 13, 2018, 08:11 AM »
You have never accidentally cut something you shouldn't like a cord, cause you had to just do a quick cut on a crowded bench.  Or more direct, drop it in a bucket of water.
Bryan
TS 55, (2) 1400 Guide Rails, 1900 Guide Rail, MFT/3, Domino DF 500, 2 domino systainers, ETS 150/3, RO 90, CT 26, (2) OF1400, RO 150. RTS 400, LR 32 set, PS300 jigsaw, 3 abrasive systainers, (2) sys toolbox, (2) sys mini, clamps and other accesories
Offline RKA
« Reply #8 on: June 13, 2018, 10:48 AM »
This accidental sabotage could backfire.  It begs the question "What if the same accident happens again, would you prefer it to happen to a $100 sander or a $300 sander?".   [tongue]
-Raj
Offline nvalinski
« Reply #9 on: June 13, 2018, 11:27 AM »
Go for the cord then, at least the Festool one is swappable
Offline Dick Mahany
« Reply #10 on: June 13, 2018, 03:51 PM »
Thanks all for the suggestions.  I like the idea of the 30 day trial, but unfortunately my local Festool store went out of business earlier this year.
@McNally Family thank you for the article link.  I do have several of the symptoms described and thought it was just a part of the aging process.  Looks like there is more to it than I had realized.
Offline Jmacpherson
« Reply #11 on: June 13, 2018, 03:56 PM »
Get one of the EC sanders, the brushless motors are more robust to things like dust and water. [tongue]
The plug-it cord is replaceable or to really throw the cat among the pigeons, there is always the option of the new 18v sanders with optional power adapter, if anything happens to the cable still have batteries [big grin]
Offline SilviaS7
« Reply #12 on: June 14, 2018, 07:56 PM »
I can't recommend the ETS EC enough.  The first time I used it was like a religious experience - I had no idea a sander could perform so well while feeling like it wasn't even powered on.  I was able to do far more work the very first day just due to the low vibration.  However it's still a very powerful sander, obviously not like a Rotex but for a small finish sander I was able to clean up some spots on my hardwood floors that no other hand/palm sander could even touch.
Offline Peter Halle
« Reply #13 on: June 14, 2018, 08:04 PM »
That will only work to your strengths.  Discuss ordering one under the 30 day program.  Get her to try it our and see what it does.  If she decides to return, then the dreaded "I didn't see that I would have to pay return shipping to the dealer" comes in.  She won't want to pay that.
Just a thought.
Offline tallgrass
« Reply #14 on: June 16, 2018, 11:59 AM »
Not difficult..... Discuss the value of your lungs. If it needs to be financial discuss the cost of medical treatment through long term exposure. Or you should calculate out happiness over time. Happiness should be of great value to her.... :)
Offline TomGadwa1
« Reply #15 on: June 16, 2018, 05:03 PM »
Just take away its union card!!! Ha! Ha! [big grin]
TS55 EQ  OF1400 EQ  DFQ 500 Q  RO 125  LR32 SET  Guide Rail Acc Kit Parallel Guide Set MFK 700 EQ Set MFS700 ETS 150/3 EQ Domino Cutter Assortment T15-3 Drill Set RO 90 EQ Workshop Cleaning Set CT36 Kapex 120 MFT/3 LR32 1080 FS 1400 FS 1900 WCR1000 PSB300 Boom Arm Set Clamping Elements RS 2 E  Kapex UG Set Zobo Forstner Set Centrotech Installers Set OF1010 OF2200 ZS-OF 2200 SYS1000 Syslite CT MIDI FS 800
There Are Those That Can Do, There Are Those That Can Not Do, Those That Can Not Do Have Those That Can Do Do The Things That They Can Not Do So That They Feel That They Have Done Something.
There ain't no something for nothing machine.
