Author Topic: Source for 10mm dia. drill bushing?  (Read 1373 times)
Offline ChuckM
« on: May 18, 2019, 12:15 PM »
Does anyone know a source to get a 10mm dia. drill bushing?
Edit: Something like this: http://www.leevalley.com/en/wood/page.aspx?p=40089&cat=1,180,40089
Found this, but the shipping cost is way too much for this Canuck: https://www.ebay.ca/itm/GRAINGER-APPROVED-Drill-Bushing-H-Drill-Size-10mm-H406JZ/312587351443?hash=item48c7a87593:g:uzoAAOSwZ3lcxCpA
« Last Edit: May 18, 2019, 01:25 PM by ChuckM »
Re: Source for 10mm dia. drill bushing?
« Reply #1 on: May 18, 2019, 01:10 PM »
Looks like your only option is to buy a 3/8” bushing and a 10mm ream and hope it works.
If you try that probably need to start with a tapered ream (possibly from both sides) and follow with straight.
« Last Edit: May 18, 2019, 04:11 PM by Michael Kellough »
« Reply #2 on: May 18, 2019, 02:07 PM »
Try Carr Lane, they manufacture all sorts of manufacturing and fixturing items. They're pretty much the standard in the manufacturing arena.
Here, I just found a straight press-in version.
https://www.carrlane.com/en-us/product/drill-jig-bushings/press-fit-bushings/press-fit-bushings-metric-pm/pm-15-12-1000
They're also available in 10.2 mm and 10.5 mm bores.
Here's a headed version.
https://www.carrlane.com/en-us/product/drill-jig-bushings/press-fit-bushings/head-press-fit-bushings-metric-hm/hm-15-12-1000
And here's a replaceable version.
https://www.carrlane.com/en-us/product/drill-jig-bushings/renewable-bushings/slipfixed-renewable-bushings-metric-sfm/sfm-15-16-1000
« Last Edit: May 18, 2019, 02:21 PM by Cheese »
Offline demographic
« Reply #3 on: May 18, 2019, 02:22 PM »
If you mean internal diameter couldn't you pilot drill out using a bushing (so the hole doesnt elongate and lose accuracy) to a smaller size then final drill it at 10mm?
Thats what we used to do at a local engineering company on the parts that didnt need to be full on machinists accurate
Offline Don T
  • Phoenix, Az
« Reply #4 on: May 18, 2019, 03:31 PM »
Bridge City Tools did have metric bushings when they were in business. I know someone bought him and out.
« Last Edit: May 18, 2019, 03:34 PM by Don T »
« Reply #5 on: May 18, 2019, 04:10 PM »
There are plenty of “10mm bushing” available but none that I’ve seen that are interchangeable with a press-in “mother bushing” like what the OP linked at Lee Valley.
So, what exactly does “like this” mean?
« Reply #6 on: May 18, 2019, 04:12 PM »
BCT is still in business under new ownership, Harvey Industries, but still known as and found under the name Bridge City Tools. John still designs tools etc.
Offline ChuckM
« Reply #7 on: May 18, 2019, 04:38 PM »
Thanks, everyone, for your inputs.
My plan was to get a 10mm bushing as I already have a set of LV's metric bushings. Upon inquiry, the vendor that supplies LV's bushings advised that it no longer produces 10mm bushings due to issues related to the bushing wall.
I now managed to find online a steel tube of 10mm ID for a just a few bucks, and will use it to make a jig, so I can use my DF500 like a DF700 (up to 10mm x 24mm x 100mm dominoes) in a more structured manner.
Previously for one table project, I used the DF500 plus a drill bit/bushing to use the 8mm x 22mm x 100mm dominoes in a two rows of double-mortises joinery. This time for another table project (a single row of double mortise joinery), I would make a drill jig for using the 10mm x 100mm ones after the mortises are precut to 50mm deep with the DF500.
Online neilc
« Reply #8 on: May 18, 2019, 09:28 PM »
« Reply #9 on: May 18, 2019, 09:57 PM »
Yea it all depends upon the duty cycle. If it’s a non-critical application where you’ll be drilling 40 or fewer holes and they only need to be located within a +/- .010” positional tolerance, the non-hardened drill bushings are fine as they are not really guide bushings but rather just drill guides.
If it’s a repetitive process for hundreds of parts and the positional tolerance needs to be within a +/- .002” range or less, then hardened drill bushings are required. Given of course the jig/fixture you've created is even capable of holding the tolerances you need.
« Last Edit: May 18, 2019, 10:00 PM by Cheese »
Offline ChuckM
« Reply #11 on: May 19, 2019, 01:24 AM »
Thanks for the ebay link. Ordered one such set even though I have already placed an online order for a 10mm  ID steel tube.
Offline Sparktrician
« Reply #12 on: May 19, 2019, 09:15 AM »
Another source is Amana Tool.   [smile]
- Willy -
