Author Topic: Table saw rips not even  (Read 3689 times)
Offline ColossusX
« on: August 26, 2018, 07:09 PM »
So I've been ripping cleats from 1/2 ply for my van racking system. I have a Hitachi C10RJ 10" jobsite saw.  I've checked the blade was parallel to the fence.  No fancy measuring devices but my tape measure measurements was the same front, middle, and back of the blade and also matched the fence measurement. (1 1/4 inch if it makes a difference). My systainer racks are 13" deep.  However I'm getting about 1/8 to 1/4 difference on my rips at 13". I'm thinking it's my technique since before this I've only used a table saw for rough framing and sub floors. I dont do that anymore since purchasing my track saw.
Any ideas what I'm doing wrong?
Thanks.
Steve
Offline tjbnwi
  • Cedar Tucky Indiana
Re: Table saw rips not even
« Reply #1 on: August 26, 2018, 07:13 PM »
Change the blade.
Offline Wooden Skye
« Reply #2 on: August 26, 2018, 07:26 PM »
Are you keeping pressure against the fence during the cut?  You may be moving slightly without noticing.  Also are you measuring from fence to side of blade closest to the fence.
Bryan
TS 55, (2) 1400 Guide Rails, 1900 Guide Rail, MFT/3, Domino DF 500, 2 domino systainers, ETS 150/3, RO 90, CT 26, (2) OF1400, RO 150. RTS 400, LR 32 set, PS300 jigsaw, 3 abrasive systainers, (2) sys toolbox, (2) sys mini, clamps and other accesories
Online Peter_C
« Reply #3 on: August 26, 2018, 08:07 PM »
Push the fence over to the blade and see if there is a gap on the front or rear. Use a square from the body of the saw to blade. Then check the body of the saw to the fence. I have a Bosch 4100 contractors saw and it isn't hard to rack the fence when tightening it down. Your square should be able to find if that is happening.
Tom's suggestion is a good one too!
As also suggested above make sure you are pushing smoothly and against the fence.
Offline ColossusX
« Reply #4 on: August 26, 2018, 09:49 PM »
I'll double check the fence and pick up a new blade.  I think I'm having issues keeping it against the fence.  It seems to be the right measurement at the beginning of the piece but it's off when I finish the cut.
Offline tjbnwi
Offline 3PedalMINI
    • Signature Sound & Video
« Reply #6 on: August 28, 2018, 12:26 PM »
I would wager that it is your technique. Get an infeed and outfeed system going. Large sheets on contractor table saws are very combersome.
Why aren’t you using your track?
The Bitterness of poor quality remains long after the sweetness of low price is forgotten -Benjamin Franklin
Professional Custom Audio Video System Designer/Installer serving Southern - Middle NJ, Eastern PA & the Surrounding Shore Points.
www.sigsv.com
Kapex 120,TS55,RO150,ETS125,CT-26,CT-MIDI,Tradesmen Cleaning Kit, Festool Ratchet Kit, Sys-lite, Sys Roll Cart, T18 +3, 2013 Centrotec Kit, Carvex 420, Carvex Accessory Kit, CXS,RO90, TI15 and Various Festool Systainers
Offline ColossusX
« Reply #7 on: August 28, 2018, 01:33 PM »
My technique is poor.  I was using the table saw because the pieces I'm ripping are 1 inch by 13 inches.  Since I needed like 80+ of these I thought the repeatability of the table saw would be faster.  But I ended up using my track saw to cut the last 40ish. More accurate but more time consuming
Offline JimH2
« Reply #8 on: August 28, 2018, 04:26 PM »
If you are cutting 1" x 13" pieces on any type of table saw and it is not coming out perfect it is most likely the saw, followed by the operator. From what you have said the saw has never been properly set up. It takes some time to do correctly, but the end result is a safer, more accurate and more enjoyable saw. There is no excuse for not being able to cut strips of that size on any table saw unless you are starting with large panels. If so then cut them down to something manageable before moving to the table saw. If you cutting a 1" strip off of a 13"x8' piece of plywood you don't stand a chance unless you have a pull saw option on your table saw which I know you do not.
BTW I highly recommend then Jessum stock guides to anyone with a larger table saw. Excellent design and they move out of the way when they are not needed.
Offline PaulMarcel
    • Voilà, my blog
« Reply #9 on: August 28, 2018, 04:54 PM »
Sounds like the fence is deflecting while you apply pressure for the cut. It'll measure fine blade-to-fence with no pressure, but while applying pressure, it'll deflect away giving you a tapered cut. I had that with an old job-site saw when I first started.
To test out the idea, put a piece of blue tape on the saw deck (blade side) right next to the fence. Do a test cut. As you get most of the way through the cut, look at the tape. Is there now a gap between the tape and fence? If so, the fence is deflecting during the cut due to the pressure. The fix for that is to make the fence more rigid perhaps by bolting on a piece of angle iron on the outside edge. A temporary fix if you need to run another 50 parts is to clamp a block up against the far end of the fence so it can't deflect away from the blade.
IG: @PaulMarcel328
Offline Alanbach
« Reply #10 on: August 28, 2018, 05:05 PM »
No offense intended to my fellow posters but before you spend any money or make anything more than easy adjustments to your saw I would check your technique. I assume from what you are describing that you are setting the fence to 1.25” and cutting each strip between the blade and the fence? If so then how you hold that piece firmly against the table and against the fence will be crucial. The saw blade will be trying to pull the cut into the blade and away from the fence if it is not held securely. Try another cut and watch the piece as it goes through the saw to see if the whole 13” length says in full contact with the fence. If not, that’s your problem. Are you using your hand on that narrow a piece or are you using some type of push stick? If it is a push stick that only has one small point of contact at the back that might be your problem. Try something that will engage the piece along much of its 13” and maybe even attach (spray adhesive ?) some sandpaper onto the bottom of it so that it has “grab”. In this way you can be sure that the cut off is staying in full contact with the fence the entire way through the cut. Also be really careful because if you are making the 1 1/4” strip cuts between the blade and the fence and you are not holding that piece absolutely securely all the way through the cut you are very susceptible to kick back. As the saw trys to pull the piece into the blade at the back of the blade it is wedging in the front and that is a nice recipe for a kickback. No one wants that😊.
If I making incorrect assumptions about your approach or if you watch the cut and the edge of the cut off stays in full contact with the fence all the way through and the piece is still out of parellel then you are back to many of the recommendations already stated by others.
Offline ColossusX
« Reply #11 on: August 28, 2018, 05:43 PM »
I am using a small push stick that can with the saw.  The 1.25" piece is between the blade and the fence.  I tried it out again today on some scrap and I did notice that as the piece advances it does pull away from the fence towards the blade.  Not every time but enough to throw off the cleats when I attached them to the shelf uprights.
Offline Alanbach
« Reply #12 on: August 28, 2018, 08:09 PM »
Ok, so I think that tells us this is an easy to fix, technique issue. In my opinion what you need is a new push stick. A simple 1x4 or 1x6 with a slice taken off of a portion of the length to leave a “hook” of sorts in the back that will grab your workpiece and pull it through the cut while providing downward pressure along the length of the rip. You just snug the push stick flush with the fence and keep downward pressure down the length of the push stick. In this case the cut would be wider than the push stick so it would not damage the “hook”. If the cut was narrower than the 3/4” wide push stick you just adjust the blade to not protrude too far above the cut and cut right through the “hook”. Eventually the hook will get destroyed and you just toss it and make another one. I doubt that you would need it but if it still lets the workpiece slip at all you can always use spray adhesive to glue a strip of sandpaper onto the bottom of the push stick. This style of push stick is considerably safer then a traditional stick that only contacts the workpiece at the very back edge.
Also, I am going to take a wild guess (please don’t be offended if I’m wrong) that you have removed the blade guard. If that is correct the removal of the splitter that is incorporated into these guards would have probably have prevented this movement and the anti kickback pauls (if applicable)would have made this a much safer cut. If I am visualizing this cut correctly the risk of kickback is high in this particular operation (original operation) as the piece shifts diagonally into the blade.
Offline ChuckM
« Reply #13 on: August 28, 2018, 08:10 PM »
Alanbach is right about kickbacks.
Use this adjustable push shoe: http://www.leevalley.com/en/wood/page.aspx?p=30067&cat=1,240,45884 (Throw in a replacement parts or pins, and you get free shipping!)
Or, make a similar one (see the attached pdf -- Source: American Woodworker).
The only time I would use a push stick (shop-made narrow stick type) is when I use it with the Jessem Clear Stock Guide for cutting narrow stock in which case the push shoe may get in the way.
« Last Edit: August 28, 2018, 08:29 PM by ChuckM »
Offline ColossusX
« Reply #14 on: August 28, 2018, 09:31 PM »
I've had some kick back issue in the past, so I actually kept the kickback pawls and the blade guard on.  I knew with such narrow pieces it would be hazardous to cut them without the safety gear.  The push stick Hitachi includes leaves much to be desired. Time to make one I think.
Thanks for all the feedback and suggestions.
Offline Alanbach
« Reply #15 on: August 28, 2018, 10:23 PM »
Ha! I have never been so glad to be wrong! I’m glad you us3d the safety devices on your saw. ChuckM is correct that there are many commercially available push sticks that provide not only the ability to push the work piece into the saw but (exp hold it down and in position at the same time. In addition to the Veritas model he noted and the picture of a home made model there are also very good models made by Kreg, Bench Dog and many more. Like the super simple example I posted the picture of, all that really matters is to firmly help hold the piece in the proper position all the way through the cut. When I make one like the picture I posted, I always make three or four so I always have one around when I need it. Mine is made from scrap and doesn’t take more than a few minutes to make. There are also more expensive ones that are extremely versatile. Look up the Micro jig’s GRR Ripper. It’s really expensive but is super versatile and can be configured to protect you on some of the most hazardous types of cuts. Also Jessem’s clear cut table saw guides are another way to play. Remember that table saw safety devices are all super cheap when compared to the cost of an injury and a visit to the ER.
Offline ChuckM
« Reply #16 on: August 28, 2018, 11:26 PM »
I also have the Grr ripper, mostly for resawing. But some woodworkers don't like the fact that the blade guard is removed whenever it is used for narrow stock, and the fact that the hand (holding the Grr ripper) passes over the blade.
The Jessem’s clear cut table saw guides allows me to cut large plywood sheets accurately on the tablesaw as the angled and one-way rollers keep the plywood edge in touch with the fence at all times. I have since sold my TS75, which was used to break down 4 x 8s.
« Last Edit: August 28, 2018, 11:32 PM by ChuckM »
Offline Birdhunter
« Reply #17 on: August 29, 2018, 05:57 AM »
I frequently use two push sticks on my table saw. One used to push the wood through and one to hold the wood down (if necessary) positioned just right outside of the blade guard. My favorite push stick is the Big Horn 10230 Woodworkers Power Hands Safety Push Stick. It’s available from Amazon.
Birdhunter
« Reply #18 on: August 29, 2018, 10:20 AM »
What’s the blade height? Should be only 1/4 to 1/2” over stock.
My go to push stick is an ice pick.
The only way to maintain lateral pressure against the fence as the “push stick” passes by the blade.
Another benefit is that small pieces impaled on the pick can be lifted and depsoited away from the blade without getting your hand near the blade.
« Last Edit: August 29, 2018, 11:48 AM by Michael Kellough »
Offline Mario Turcot
« Reply #19 on: August 30, 2018, 11:20 AM »
@ColossusX Are you using a true riving knife or only an anti-kickback?
Mario
« Reply #20 on: August 30, 2018, 12:22 PM »
@ChuckM What kind of pressure in lbs the Jessem's hold down apply?
I'm considering them on my Hybrid table saw.
Mario
Offline Dick Mahany
« Reply #21 on: August 30, 2018, 12:45 PM »
For thin rips and face frames, using a simple feather board and push stick in addition to the riving knife or blade guard has been very beneficial in maintaining parallelism over the entire length of the cut.  It does take a few seconds to reset the board if the stock width varies, but the results are worth it every time.
Also, an auxiliary tall fence can help with one or more featherboards although they can restrict push stick usage for very narrow rips.
The aux fence is symmetrical so it can be rotated 180 degrees.  Clamp detail is crude but works well.
« Last Edit: August 30, 2018, 06:37 PM by Dick Mahany »
Offline ChuckM
« Reply #22 on: August 30, 2018, 05:45 PM »
Mario,
The rollers are spring loaded and by feel, 5 pounds? But it is important to note that you position the workpiece under the guides, not the rollers, to set them up, and then put the workpiece under the front roller. The rollers are slightly lower than the guides.
It is not just the tension but really also the one-way 5* angle rollers that keep the stock to go tight against the fence as well as preventing kickback. Even if wood opens up after passing the blade and touching the spinning teeth at the back before reaching the riving knife, kickback won't happen as the rollers allow only forward movement.
With this guides, you can handle a large sheet all by yourself as everything you feed stays in contact with the saw fence as long as you push forward.
By the way, many users only handle wide stock when the clear stock guides is installed. They wrongly think that the rollers will get in the way when narrow stock is ripped. I rip as well as resaw (long pieces) regardless of the clear stock guides. See an example in the image.
« Last Edit: August 30, 2018, 06:35 PM by ChuckM »
Offline Steven Owen
« Reply #23 on: August 30, 2018, 05:59 PM »
(Attachment Link)
(Attachment Link)
That’s a good idea Dick.  I always use feather boards on a Dewalt table fence, I never considered building my own auxiliary fence for the Dewalt job site saw.  I always felt the fence on the Dewalt was too short for some task.
That’s cool and a good design.  The addition of the T-track on the fence would allow you to add Jessems clear cut guides to boot.
Festool CT Midi, Festool ETS 125, DF 700 Domino Coming Soon
Offline ColossusX
« Reply #24 on: August 30, 2018, 06:36 PM »
@Mario Turcot , I'm using what came with the saw.  So I'm not positive.
Offline ChuckM
« Reply #25 on: September 04, 2018, 08:01 PM »
snip.
Mario, or anyone who plans to get the Jessem guides,
The guides can be used as a stop bock when cross cutting as shown in the attached image. No need to clamp a block to your fence.
« Reply #26 on: September 04, 2018, 08:03 PM »
Very neat, thank you :)
I'm sold after watching that
« Last Edit: September 04, 2018, 10:43 PM by Mario Turcot »
Mario
Offline ChuckM
« Reply #27 on: September 05, 2018, 12:29 AM »
Some people use other jigs with the fence and don't want the guides screwed to the fence. If you re one of them, you could install the guides to a plywood base and mount the following magnets to the base:
http://www.leevalley.com/en/wood/page.aspx?p=56000&cat=1,43838,47843
When you need to use the guides, simply attach the guides/base to the fence.
With the use of these guides, it is close to being impossible to have a kickback. In addition, cutting a large sheet is no longer nerve wrecking. If I need to cut  25"x48" out of  4x8, I set the fence to cut 25-1/4" in the first pass, then a second pass to trim a dead straight, clean edge.
« Last Edit: September 05, 2018, 06:13 AM by ChuckM »
« Reply #28 on: September 05, 2018, 12:35 AM »
I did my home work and found that Dave Stanton made a video just about that. Thanksa for the LeeValley link  [cool]
Mario
« Reply #29 on: September 05, 2018, 11:20 AM »
@ChuckM
Look into what you pushed me!
12 minutes ago
and they had one in stock  [tongue]
The thing is, I use the table saw a lot. Beside regular usage, I cut out and square all the left over from the CNC and what not. Those helpers will simplify the task enormously  [eek]
« Last Edit: September 05, 2018, 11:42 AM by Mario Turcot »
Mario
