Author Topic: Table saw rips not even  (Read 3913 times)
Offline ChuckM
Re: Table saw rips not even
« Reply #30 on: September 05, 2018, 01:23 PM »
 [big grin]
I am a victim :'(, too, and your photo reminds me that I still have three online/special orders waiting for me to pick up! [eek]
It is a blessing in disguise that I don't live too close to the store (half an hour drive in city traffic) ....
« Last Edit: September 05, 2018, 01:27 PM by ChuckM »
Offline Brian Livingstone
« Reply #31 on: September 05, 2018, 02:02 PM »
Hi Mario,
What is on top of the box ?  Featherboard ?
I have the guides on my LaGuna Fusion.  Really like them.
Brian
Kapex, TS75, MFT, OF1010, OF2200, DTS400 REQ, Parallel guide rails, 800, 1080, 1400, 1900, 3000 guide rail, Domino 500, CT36, CT Midi, , RS2E, RO150, Boom Arm, Crown stops, 6 drawer Sortainer, Carvex, Syslite II, Festool safety glasses must start to wear.
Offline Mario Turcot
« Reply #32 on: September 05, 2018, 02:46 PM »
@Brian Livingstone
Hi Mario,
Brian
They are Mag Switch magnets. If you look at the video I posted above you will see their use.
Took 10 minutes to install :)
« Last Edit: September 05, 2018, 07:53 PM by Mario Turcot »
Mario
Offline ChuckM
« Reply #33 on: September 05, 2018, 08:39 PM »
Snip.
That's unbelievably efficient!
[thumbs up]
JessEm should appoint you as one of their honourary Installation/Assembly consultants.
By the way, I keep a stack of gift cards or access cards (but not credit cards because they are embossed) nearby. Sometimes, I set the front guide and lock the fence, forgetting about the rear guide. Or, with the blade guard in place, setting the rear guide might require moving the fence far to slip in the stock. Instead, I use a stack of cards the same or close to the same thickness of the stock to set the guide I miss.
« Last Edit: September 05, 2018, 08:54 PM by ChuckM »
Online rvieceli
« Reply #34 on: September 05, 2018, 08:42 PM »
@Mario Turcot which model Mag-switches are those?
Ron
« Reply #35 on: September 05, 2018, 08:58 PM »
I already had a strip of 70mm ply, just have to make the holes for the magnets and screw everything together.
Mario
« Reply #36 on: September 05, 2018, 09:25 PM »
Ron
The 20mm Mag-Jig 95lbs I found the 30mm to be a bit too bulky.
Mario
Offline ChuckM
« Reply #37 on: September 06, 2018, 05:12 PM »
The magnets are quite pricey, but they are a great helper.
The featherboards are best mounted with one 20mm and one 30mm magnets. Unlike those used with the mitre slots, these can be positioned anywhere on the table.
If you wax your saw table top, this application is not suitable for you.
« Last Edit: September 06, 2018, 05:14 PM by ChuckM »
Offline rst
« Reply #38 on: September 06, 2018, 09:05 PM »
I have an advantage in that most of my work is commercial, I use Mag Switch 400 and 600 series magnets as feather boards, usually just the magnet against the work.  These Do Not move.
