Author Topic: Tools and Accessories to make a hole 7" duct  (Read 1434 times)
Offline rylim
« on: January 08, 2018, 11:52 AM »
Hi, I will be installing a new range hood in my kitchen and have to run a 7" duct piping through the ceiling to the roof.
Therefore, I just what tools I can use to make a perfect hole for the duct? I tried to look up for a 7" hole saw but no luck. Any suggestions here?
Sale: Festool 498899 Assorted Domino Beech Tenons Set with Cutter Bits (5-Bits)- New - $265
Offline TomGadwa1
Re: Tools and Accessories to make a hole 7" duct
« Reply #1 on: January 08, 2018, 12:18 PM »
Use a compass! Set to 3.5 inches. Point in the center and the tip on the radius and draw your 7 inch circle!
TS55 EQ  OF1400 EQ  DFQ 500 Q  RO 125  LR32 SET  Guide Rail Acc Kit Parallel Guide Set MFK 700 EQ Set MFS700 ETS 150/3 EQ Domino Cutter Assortment T15-3 Drill Set RO 90 EQ Workshop Cleaning Set CT36 Kapex 120 MFT/3 LR32 1080 FS 1400 FS 1900 WCR1000 PSB300 Boom Arm Set Clamping Elements RS 2 E  Kapex UG Set Zobo Forstner Set Centrotech Installers Set OF1010 OF2200 ZS-OF 2200 SYS1000 Syslite CT MIDI FS 800
There Are Those That Can Do, There Are Those That Can Not Do, Those That Can Not Do Have Those That Can Do Do The Things That They Can Not Do So That They Feel That They Have Done Something.
There ain't no something for nothing machine.
Offline RussellS
« Reply #2 on: January 08, 2018, 12:54 PM »
Yes.  And then get a spade bit and drill a hole inside the circle.  Then get a jigsaw or manual keyhole saw and cut out the circle.  Keyhole saw if you are cutting through drywall into the ceiling.  Electric jigsaw if you are cutting through sheathing on the side of the house or roof.
Offline live4ever
« Reply #3 on: January 08, 2018, 01:15 PM »
Lots of low-tech ways to do this for a one-off task, but if you have frequent need to efficiently drill perfect holes of large diameter take a look at Hole Pro (there are many similar and cheaper knock offs - just make sure you're looking at ones with replaceable and carbide blades).
« Reply #4 on: January 08, 2018, 02:00 PM »
I had to do the same thing for an 8” vent for my range hood going through the side wall. Keep in mind that it’s nigh to impossible to cut an exactly round opening with a jigsaw and sometimes the vent pipe is also not exactly to size and also exactly round. You’ll also want a little slop in the cutout to get everything aligned and not have something binding.
Measure the pipe, add a little room for slop, draw the circle with a compass and make the cutout with a jig saw.
Fabricate a cover of the material of your choice to cover the slop room and to give the penetration a more finished appearance. I fabbed the one shown of 304 stainless sheet.
« Last Edit: January 09, 2018, 10:25 AM by Cheese »
Offline SRSemenza
« Reply #5 on: January 08, 2018, 03:29 PM »
Not sure if you are going through the roof but if so, and the pipe is not perpendicular to the roof line, don't forget that the hole  needed will not be round.
Offline John Beauchamp
« Reply #6 on: January 08, 2018, 03:54 PM »
Don't forget to check for ceiling joists in the way. You might need to transition to 3 1/4 x 10
TS55REQ, MFT/3, RO90, CT36, DF500
Offline Peter_C
« Reply #7 on: January 08, 2018, 08:09 PM »
That is microwave size and my preference if going thru a cabinet so it can be covered in a wooden box.
The Klien tool is supposed to work for 7" holes in drywall. Here is the link. I believe Milwaukee rebrands as I am sure others do too. They work just okay.
https://www.homedepot.com/p/Klein-Tools-Quick-Cutter-Adjustable-Hole-Saw-53731/203828012
t
Offline Bob D.
« Reply #8 on: January 09, 2018, 08:16 AM »
A Roto-zip type tool with compass attachment might be a good choice for this task.
There are corded and cordless versions available from multiple manufacturers.
Offline cpw
« Reply #9 on: January 09, 2018, 08:21 AM »
I had a 10" duct to install for my range hood. It's not quite the same because I went horizontally.
For the holes in the cabinets I used a Trion with the circle guide.
For the siding of the house I used a reciprocating saw to make a square hole.
« Reply #10 on: January 09, 2018, 11:28 AM »
@rylim
FWIW...while rummaging around for info on router bits, I just noticed that Whiteside does manufacture a carbide tipped hole saw that will cut a 7 1/4" diameter hole. Whiteside #8007250K.
https://www.whitesiderouterbits.com/collections/self-clean-hole-saw?page=2
« Last Edit: January 10, 2018, 08:27 AM by Cheese »
