jacko9
Offline
« on: May 04, 2012, 12:28 PM » |
I was wondering what brand and model of saw blade foggers use on their table saws? I mostly do solid wood construction so I use the Forrest Woodworker II 80 tooth blade for my general table saw work. I am going to start building some kitchen cabinets and I would like to find a blade to minimize ragged cross cuts. What do you folks recommend?
Is the Forrest 8" x 80 tooth DURALINE HI-A/T Saw Blade - Thin Kerf a good blade for plywood cutting?
Jack
Michael Kellough
Offline
Southern New York
« Reply #1 on: May 04, 2012, 12:43 PM » |
Are you sure that's an 80 tooth blade? I think 40 tooth is the norm with the WWII.
Whichever, it's an excellent blade for plywood. 80 teeth would be better.
There is a tendency for people to think the higher cost product can't be worth the price. (think Apple) I'm a long time Forrest user and I fell into that skeptical thought process when my old WWII hit a loose nail and chipped several teeth.
I'd heard the Ridge blade was very good so I bought one instead of going through the hassle of sending in the WWII for sharpening. The damaged WWII cut better than the Ridge.
The main difference in circular saw blades is in how much attention is given to flattening the disk. Doesn't matter how finely sharpened the teeth are if one or two stick out too far due to a warped disk. You'll get a scratchy cut. Forrest uses flatter disks and it shows in the cut.
GPowers
Offline
Metric convert
« Reply #2 on: May 04, 2012, 12:49 PM » |
I use the TS55 and the guide rails to cut Plywood.  easier and safer, just my $0.02.
« Last Edit: May 04, 2012, 12:52 PM by GPowers »
Greg Powers Size:XL
Alex
Offline
« Reply #3 on: May 04, 2012, 12:53 PM » |
80 teeth on an 8'' blade? Isn't that a bit of overkill? My 9'' Festool blade on my tablesaw has 48 teeth and it's considered the ''fine'' blade. It works great on many woods including plywood. On an 8'' blade, 40 or 48 teeth should be fine, even 32 would work alright.
Of course 80 teeth will work too, but the more teeth a blade has, the harder it is to push the wood through and the longer the cut will take. The cut should be very fine of course, but the question is if that little bit of extra finesse is worth it.
jacko9
Offline
« Reply #4 on: May 04, 2012, 01:26 PM » |
I guess I should mention that I have mention that I have a 10" Powermatic 66 Table saw with a 5HP motor so, pushing a 80 tooth blade is no problem.
Alex
Offline
« Reply #5 on: May 04, 2012, 02:13 PM » |
I'm not talking about the force the table saw needs, they've generally got enough power, I'm talking about the force YOU need. The more teeth a blade has the more teeth hit the workpiece per second. This creates a resistance that you need to overcome when pushing the piece into the blade. That's why a 12 T Panther blade can rip a lot quicker than a 48 T fine blade. It's a trade off you make between the smoothness of the cut and the work needed to get there.
Timtool
Retailer
Online
« Reply #6 on: May 04, 2012, 04:00 PM » |
I have this $100 special 60T blade with alternating hollow and pointy teeth meant for cutting without tearout on melamine or veneer, it works ok, well no it doesn't. Theres still the occasional chip which is unacceptable. lucky for me i have a scoring blade on my panelsaw, i just raise that one up when cutting plywood, veneered mdf of melamine and keep my normal 48T crosscut blade installed. but i fear scoring blades are an invention that unfortunately hasn't reached the new world yet, good thing is that protruding riving knives are also rare over there so you can probably still cut a first pass backwards with the blade a few mm above the table to fake a scoring blade.
andvari
Offline
« Reply #7 on: May 04, 2012, 05:34 PM » |
Riving knives are on all new table saws over here. Scoring blades appear on some of the higher end table saws like the MiniMax and various panel saws.
mastercabman
Offline
NORFOLK,VA
« Reply #8 on: May 04, 2012, 07:29 PM » |
I like Freud.
Kevin Stricker
Offline
« Reply #9 on: May 05, 2012, 02:14 AM » |
The Duraline Hi-AT 80tooth blade is a 10" blade( at least mine is). It cuts plywood wonderfully, but you need a ZCI on the saw to get good bottom side cuts.
I do get lazy and make plenty of cuts with my WWII, it does a pretty good job itself. You will get some bottom side splintering, but usually this is not a problem on cabinets as one edge is generally hidden.
Timtool
Retailer
Online
« Reply #10 on: May 05, 2012, 03:12 AM » |
I know, but i meant the protruding riving knives that sit taller than the blade. Mine has such a riving knife and i believe it is mandatory now in europe, so that you cannot make a hidden/non through cut which is a forbidden and dangerous operation according to the manuals. All it does is force us to remove the knife for certain operations, making it even more dangerous.
jacko9
Offline
« Reply #11 on: May 05, 2012, 10:41 AM » |
Thanks, I bought the Duraline blade yesterday and picked up a few zero clearance inserts.
WarnerConstCo.
Offline
« Reply #12 on: May 05, 2012, 11:39 AM » |
The best plywood blades have a AFATR grind.
Alternating Face, Alternating Tooth with a raker.
I got nice splinter free cuts with my old PM66 5hp with a 60 tooth ATB blade from Matsushita, and it ripped everything I could shove into too.
I run a 40t 16" Tenryu on my TS now. That will cut 6" thick solid stock like no one's business.
barnowl
Offline
« Reply #13 on: May 05, 2012, 03:58 PM » |
While most of my plywood/melamine cuts are with the TS55, when I use the table saw, it's with a Forrest 10"DURALINE HI-A/T Saw Blade - Thin Kerf.
It's an excellent blade.
best wishes,
Steve
TS-55, assorted rails, Domino, Kapex, OF1400, ETS 125 EQ, RO 125 FEQ, RO 90, PSB 300 EQ, CT-22, CT-26, MFT-3
Tom Bellemare
Festool Dealer
Offline
« Reply #14 on: May 05, 2012, 05:12 PM » |
Has anyone tried one of these?  I don't have a table saw and I'm wondering how well they perform. Tom
mastercabman
Offline
NORFOLK,VA
« Reply #15 on: May 05, 2012, 08:14 PM » |
I would stay away from CMT.
Tom Bellemare
Festool Dealer
Offline
« Reply #16 on: May 05, 2012, 08:57 PM » |
Can you tell me why, please?
I am sincerely trying to understand why nobody seems to be using them.
Thanks,
jacko9
Offline
« Reply #17 on: May 05, 2012, 09:08 PM » |
I have no experience with the CMT blades. For the first 25 years of woodworking, I had to get all of my blades punched to 20mm since all I could find were 5/8" arbor holes and my Inca Table saw had a 20mm arbor. I think that some of the resizing might have had an adverse effect on the blades and one in particular was the Freud blade which performed like crap.
I switched to Forrest blades for the past 20 years and have been happy with the results so, I tend to stay with them.
Jack
Tom Bellemare
Festool Dealer
Offline
« Reply #18 on: May 05, 2012, 09:39 PM » |
Thanks, Jack!
I'm wondering if it isn't bad experiences and that people have found something they like that prevents them from trying something new. I'm also wondering if there are those that have specific bad experiences with CMT blades...
jacko9
Offline
« Reply #19 on: May 05, 2012, 10:02 PM » |
Tom, I did a search on Fine Woodworking.Com for saw blade reviews and found an "old" posting from 2002 "10-in. Combination Tablesaw Blades Our high-tech test of 14 new blades revealed the smoothest cutters by Tom Begnal" This study rated the Forrest as Excellent and the CMT two steps below as good. I know that this is old data but, if your interested and have access to Fine Woodworking, here's the web site; http://www.finewoodworking.com/ToolGuide/ToolGuidePDF.aspx?id=2777I know that suppliers change their products all of the time so, I would be interested in any folks on here that have more recent experience with the CMT blades. Jack
Tom Bellemare
Festool Dealer
Offline
« Reply #20 on: May 05, 2012, 10:07 PM » |
Thanks again, Jack!
I'm hesitant to believe reviews that could have a profit motive but I'll definitely take a look. I could be wrong but it seems that I get the most reliable feedback from people that make a living with their tools or at least use them all the time as if they were, like a dedicated hobbyist.
mastercabman
Offline
NORFOLK,VA
« Reply #21 on: May 06, 2012, 02:13 PM » |
Thanks,
Here is my experience and what i found out. Lowes used to carry CMT blades but if you go to any Lowes you will notice that CMT blades are on close out.They are discontinued. I bought one about 6 months ago and put it in my table saw.After using it for about 4 months(light to medium use)I noticed that some of the teeth was chipped and i mean big chunk.I do not recall running into any metal,nails etc... I talked with some other woodworker friends and most of them who had used CMT were not too "shabby"about it. Then i met a sale rep from FREUD. OK i know he is going to tell me that CMT is bad and Freud is good.But i had to hear what he had to say. CMT does not make their carbide.The use recycle hard carbide.I have also heard that from someone else before. Also,their so called "orange coating" is nothing more than paint.Freud uses some kind of Teflon coating. I can't recall what he told me about the way the blade is made but it is not like most top blade manufacturer does.Making it not so flat? Since i had good result with my Freud blades and bad experience with CMT,I can only conclude that i will never buy CMT again.
Peter James
Festool Dealer
Offline
Festool Dealer Right Outside NYC - 10,000 Sq Feet
« Reply #22 on: May 10, 2012, 01:53 PM » |
Thanks again, Jack!
Disclaimer - We sell both Freud AND CMT.... Here is my $.02 on this topic, and I am by no means an expert. - Kerf: CMT offers industrial full kerf (all orange) blades, and ITK (silver and orange) blades. ITK stands for industrial thin kerf - thicker than a Diablo, but still not a full kerf blade. Freud also offers full kerf (LU & LM series) and thin kerf blades (Diablo series). Both the Diablo line from Freud and the ITK from CMT are more aimed at contractors out in the field. Typically running portable table saws and miter saws. Both of their industrial lineups are geared at wood shops. I would imagine, but don't want to speculate that big boxes are going to sell the thin kerf lines from both vendors as they offer a lower price point and the average consumer shops based upon cost. CMT also offers non coated industrial blades (Industrial XTreme) more marketed at larger production shops with panel saws, etc as well as a ITK Contractor line which are purely price driven, disposable blades. - Coatings: CMT industrial (all orange) blades have a PTFE (teflon made by Dupont) coating on them. CMT ITK blades do not. Freud Diablo and the some industrial (LU and LM - varies by blade I believe) have a Perma-Shield (teflon, but not by Dupont) coating on them. Dupont used to make a teflon coating for Freud, but I believe the two companies no loner have a relationship. - Bodies: Both companies laser cut their plates. - Carbide: I do not know much about the specifics about the carbide these companies use, other than they use C4 carbide. The higher the "C" rating, the harder the carbide. Unfortunately, harder carbide typically means more brittle and resistant to chipping. The softer the carbide, the quicker it is to dull, so again, it is about finding a balance. And remember - the number one enemy of carbide (other than a nail) is HEAT! Bottom line, both are good brands as long as you know what you're buying. We love both brands here, and the fact that these two companies compete so closely only means the consumer wins in the long run. I am not in a position to say one is better than another as long as the customer knows what they are looking for and expecting. There are plenty of other lines out there that sell great blades - Amana, Tenryu, Skarpaz, Forrest, etc. but I'm focusing on the two primarily mentioned in this thread. Everything I said in this thread is talk and info - what matters most is when you put the teeth to the wood and see what happens though! I hope this is at least a little bit helpful to all.
jacko9
Offline
« Reply #23 on: May 10, 2012, 09:04 PM » |
Thanks again, Jack!
Disclaimer - We sell both Freud AND CMT.... Here is my $.02 on this topic, and I am by no means an expert. - Kerf: CMT offers industrial full kerf (all orange) blades, and ITK (silver and orange) blades. ITK stands for industrial thin kerf - thicker than a Diablo, but still not a full kerf blade. Freud also offers full kerf (LU & LM series) and thin kerf blades (Diablo series). Both the Diablo line from Freud and the ITK from CMT are more aimed at contractors out in the field. Typically running portable table saws and miter saws. Both of their industrial lineups are geared at wood shops. I would imagine, but don't want to speculate that big boxes are going to sell the thin kerf lines from both vendors as they offer a lower price point and the average consumer shops based upon cost. CMT also offers non coated industrial blades (Industrial XTreme) more marketed at larger production shops with panel saws, etc as well as a ITK Contractor line which are purely price driven, disposable blades. - Coatings: CMT industrial (all orange) blades have a PTFE (teflon made by Dupont) coating on them. CMT ITK blades do not. Freud Diablo and the some industrial (LU and LM - varies by blade I believe) have a Perma-Shield (teflon, but not by Dupont) coating on them. Dupont used to make a teflon coating for Freud, but I believe the two companies no loner have a relationship. - Bodies: Both companies laser cut their plates. - Carbide: I do not know much about the specifics about the carbide these companies use, other than they use C4 carbide. The higher the "C" rating, the harder the carbide. Unfortunately, harder carbide typically means more brittle and resistant to chipping. The softer the carbide, the quicker it is to dull, so again, it is about finding a balance. And remember - the number one enemy of carbide (other than a nail) is HEAT! Bottom line, both are good brands as long as you know what you're buying. We love both brands here, and the fact that these two companies compete so closely only means the consumer wins in the long run. I am not in a position to say one is better than another as long as the customer knows what they are looking for and expecting. There are plenty of other lines out there that sell great blades - Amana, Tenryu, Skarpaz, Forrest, etc. but I'm focusing on the two primarily mentioned in this thread. Everything I said in this thread is talk and info - what matters most is when you put the teeth to the wood and see what happens though! I hope this is at least a little bit helpful to all. Thanks Peter, I do value a suppliers knowledge and that's why I posted this question on here and I'll keep this in mind for future purchases. Jack
GaryLaroff
Offline
« Reply #24 on: May 10, 2012, 10:17 PM » |
I had been using the Forrest Woodworker II for many years and therefore got the 12-inch Woodworker II on my Inca 2200 cabinet saw when I purchased it around ten years ago. I've been sold on Forrest blades for 20 years. Last year I sent the Forrest WW-II back for sharpening and needed a spare blade for mahogany and hardwood veneer plywood while I waited for the Forrest blade to come back. I bought the high-end 12-inch Freud blade which was certainly quieter than the Forrest and used it on the saw for some months, choosing to keep the Forrest in reserve freshly sharpened. My impression was that it was not as good as the Forrest and was making a mess of the plywood. When I recently replaced the Freud with the Forrest Woodworker-II the superiority of the Forrest blade was obvious to me. This was most obvious on the quality of the cut on the plywood and the ease of cutting 8/4 and thicker mahogany.
Gary
Peter James
Festool Dealer
Offline
« Reply #25 on: May 10, 2012, 10:33 PM » |
Thanks again, Jack!
Disclaimer - We sell both Freud AND CMT.... Here is my $.02 on this topic, and I am by no means an expert. - Kerf: CMT offers industrial full kerf (all orange) blades, and ITK (silver and orange) blades. ITK stands for industrial thin kerf - thicker than a Diablo, but still not a full kerf blade. Freud also offers full kerf (LU & LM series) and thin kerf blades (Diablo series). Both the Diablo line from Freud and the ITK from CMT are more aimed at contractors out in the field. Typically running portable table saws and miter saws. Both of their industrial lineups are geared at wood shops. I would imagine, but don't want to speculate that big boxes are going to sell the thin kerf lines from both vendors as they offer a lower price point and the average consumer shops based upon cost. CMT also offers non coated industrial blades (Industrial XTreme) more marketed at larger production shops with panel saws, etc as well as a ITK Contractor line which are purely price driven, disposable blades. - Coatings: CMT industrial (all orange) blades have a PTFE (teflon made by Dupont) coating on them. CMT ITK blades do not. Freud Diablo and the some industrial (LU and LM - varies by blade I believe) have a Perma-Shield (teflon, but not by Dupont) coating on them. Dupont used to make a teflon coating for Freud, but I believe the two companies no loner have a relationship. - Bodies: Both companies laser cut their plates. - Carbide: I do not know much about the specifics about the carbide these companies use, other than they use C4 carbide. The higher the "C" rating, the harder the carbide. Unfortunately, harder carbide typically means more brittle and resistant to chipping. The softer the carbide, the quicker it is to dull, so again, it is about finding a balance. And remember - the number one enemy of carbide (other than a nail) is HEAT! Bottom line, both are good brands as long as you know what you're buying. We love both brands here, and the fact that these two companies compete so closely only means the consumer wins in the long run. I am not in a position to say one is better than another as long as the customer knows what they are looking for and expecting. There are plenty of other lines out there that sell great blades - Amana, Tenryu, Skarpaz, Forrest, etc. but I'm focusing on the two primarily mentioned in this thread. Everything I said in this thread is talk and info - what matters most is when you put the teeth to the wood and see what happens though! I hope this is at least a little bit helpful to all. Thanks Peter, I do value a suppliers knowledge and that's why I posted this question on here and I'll keep this in mind for future purchases. Jack Happy to help. Like I said both companies make great blades and price point blades. Sometimes it's frustrating when a big box makes the decision on what to offer the customer based upon price alone. It's almost misrepresenting the line to do that. Again there are so many great companies doing great things nowadays. Look how far we've come with carbide vs steel cutters in the past 20 years alone. --- I am here: http://tapatalk.com/map.php?klrcwi
Peter James
Festool Dealer
Offline
« Reply #26 on: May 10, 2012, 10:36 PM » |
Gary
I haven't heard too many people say a bad thing about them - says a lot about the company and the product. Also, I've heard their sharpening rates are fair. Is it true that they use a proprietary grind though and it's best to send blades for sharpening direct back to the manufacturer? If so, are they still including a coupon for a free sharpening with their blades, or was that a long time ago? --- I am here: http://tapatalk.com/map.php?b3rfth
lambeater
Offline
Location: British Columbia, Canada Member Since: Apr 2010
« Reply #27 on: May 11, 2012, 10:01 AM » |
I use both Freud and CMT blades on my table saw, all industrial.
Freud glue line rip for any ripping, CMT 210.80.10 Laminate blade for melamine and ply. Also use my Freud LU80RO10 ultimate plywood melamine blade for plywood and melamine, they all work great.
thx Lambeater
Peter James
Festool Dealer
Offline
« Reply #28 on: May 11, 2012, 10:08 AM » |
Great info Lambeater. I think the end result is both CMT and Freud make high quality blades and some price point blades. What makes FOG so special is we all can ask each other and get some great insight and opinions.
KorDes
Festool Dealer
Offline
« Reply #29 on: May 17, 2012, 04:09 AM » |
Just curious if anyone on here has heard of Leuco tools. They are a huge German tooling manufacturer and make some of the best blades in the market. They have a blade called the G5 blade. A 300mm blade has 100 teeth and the teeth geometry consists of 5 different angles, hence the 5 after the G. It has a series of a flat tooth, then 2 pairs of alternating compound bevels. The grade of the tungsten carbide is harder than the usual grades as well as the body of the blade is cut from the center of the steel sheet leading to a flatter more stable body. http://www.leuco.com/Dateien/G5_E.pdf
