Pages: [1]   Go Down
  Print
Author Topic: Woodpecker box clamps?  (Read 4459 times)
bruegf
Offline Offline
Michigan
« on: May 26, 2012, 07:38 AM »
I'm curious if any of you use the Woodpecker BC4-M2 Box Clamps and what you think about them.   I'm about to start on a building a new set of kitchen cabinets for myself and need to buy some clamps to build the cabinet boxes.  I'm wondering how the box clamps work or if I'd be better off buying Bessey K body clamps.
While the box clamps won't be as versatile as the Bessey clamps, they look like they would be far more convenient and have the advantage of making it easier to keep the boxes square.
Thx
Fred
Fred
RonWen
Retailer
Offline Offline
Location: One of the Thirteen Original Colonies of the United States of America.
WWW
« Reply #1 on: May 26, 2012, 08:19 AM »
I have several of both the old style aluminum and the newer plastic box clamps.   I use them when I glue up several sets of drawers (8 per drawer) & they work no matter what joint I choose.  They have no where near the clamping force of Bessey clamps but are adequate for the purpose.  The obvious advantage is the investment is much lower than Besseys and it doesn't matter what span the drawers (or other box) are.
doc4som
Offline Offline
« Reply #2 on: May 27, 2012, 01:52 AM »
Fred,I am also considering what system to use for clamping (building ) cabinets. I was looking at Fastcap Assembly blocks (fastcap.com under pro tools). I have no experience with them nor have I bought them. Maybe somebody else knows more. I would like to know. Good luck- Carlos
doc4som
Offline Offline
« Reply #3 on: June 20, 2012, 11:49 PM »
To RonWen,  Just recently I saw the video on the Woodpecker fiberglass (FG) clamps where they say these clamps have a grove teeth & channel which makes them easier to work. They fail to say easier than what .  In your experience,are the FG clamps easier to work with than the aluminum ones ?
RonWen
Retailer
Offline Offline
WWW
« Reply #4 on: June 21, 2012, 01:45 AM »
Yes, I suppose the teeth are an improvement over the (smooth) aluminum ones although I didn't seem to have issues using those either.  The FG clamps are considerably cheaper which is always a good thing.
doc4som
Offline Offline
« Reply #5 on: June 21, 2012, 02:42 AM »
Thanks, RONWEN.  I just saw that  incrementaltools.com has the FG clamps for 10% off , but Woodpeck.com has them at the original price!
Sal LiVecchi
Offline Offline
« Reply #6 on: June 21, 2012, 07:57 AM »
I have been using them latley , I used them for the carcase build on my last set of cabinets and they work great. To me they helped square up the cabinet carcase and draw assemblies that much easier.
Sal
Life is too short and the road is too long to drive anything less than a Festool
bruegf
Offline Offline
Michigan
« Reply #7 on: June 21, 2012, 08:52 AM »
Sal,
Did you have to use regular clamps to ensure the joint was tight or did the box clamp alone draw the joint together?
I just bought a set of 8 of the plastic box clamps and haven't used them yet, but just playing with a pair and a couple pieces of 3/4 scrap plywood, they didn't seem to get the butt joint tight enough to glue properly w/o also using a bar clamp to provide the actual clamping pressure.
Fred
Fred
Sal LiVecchi
Offline Offline
« Reply #8 on: June 21, 2012, 10:46 AM »
Fred      I used them to square up everything and used bar clamps to hold it in place until the glue set
Sal
Tim Raleigh
Offline Offline
WWW
« Reply #9 on: June 21, 2012, 11:01 AM »
I have 2 pairs of these woodpecker clamps and I thought they would be a good solution/backup to my bessy clamps.
I really tried to like them but I really find them extremely fussy to use. They looked like a great idea but when I started to use them in a recent cabinet project I just found they took some time to set up properly and then taking them off and repositioning them for the next corner/box was just a pain.
I really like the Bessey WS-3 Angle Clamp, more expensive but way easier to work with particularly when you are trying to work quickly and have a lot of boxes to make.
Tim
doc4som
Offline Offline
« Reply #10 on: June 21, 2012, 12:19 PM »
There is a similar product at www.fastcap.com . the  block (this is not a typo) . It seems to be the same idea as the Woopecker clamp. Has any of you used this? The Bessey product--- can it be screwed onto a table like the fastcap product?
bruegf
Offline Offline
Michigan
« Reply #11 on: June 21, 2012, 01:15 PM »
Sal
Ok, that makes sense.   They do appear to be very quick and convenient for keeping the box square.
Fred
Fred
RonWen
Retailer
Offline Offline
WWW
« Reply #12 on: June 21, 2012, 03:30 PM »
Tim
A couple of things that I do may help -- I marked each block (magic marker) at the correct thickness setting for the stock size (3/4", 1/2", etc.) so I could pre-set them and when I'm ready to remove them I just pop them off with a mallet.  They are very durable & don't seem to mind.
Tim Raleigh
Offline Offline
WWW
« Reply #13 on: June 21, 2012, 09:02 PM »
Nope. The fast cap product looks like it would be good for drawers and smaller boxes.
Ron:
Thanks, I will try it out.
While I did have to fiddle with them, they did hold the box securely and squarely.
Tim
fshanno
Offline Offline
« Reply #14 on: June 23, 2012, 10:10 PM »
Lamello has a product that looks pretty good.
Lamello Clamping System
Almost bought a set from someone here on the FOG.  Pains me that I didn't do it.  Doesn't seem to be advertised here in the US but I bet Lamello dealers may be able to get it.
doc4som
Offline Offline
« Reply #15 on: June 27, 2012, 01:31 AM »
This lamello systems reminds me of the MERLE CLAMP from www.mclswoodworking.com. I received an e-mail from www. Woodpeck.com , they really like their BC4-M2 box clamps, which are less expensive than their own aluminun box clamps. Now I only need to find someone who has compared the Woodpecker BC4-M2 vs Fastcap assembly block (at www. Fastcap.com). Anyone?
Pages: [1]   Go Up
  Print
Jump to:
