Author Topic: Cabinet Door Lock Recommendations  (Read 1324 times)
Online Gerald_D
« on: February 05, 2019, 05:47 PM »
Throughout all my years of building furniture,  I almost have never received requests for locks- only ones used before are simple cam locks in drawer fronts.  However, I have been commissioned to build a cabinet that will have two flat-slab doors mounted to the front of the cabinet that will butt up to each other, and need to install a lock to secure the contents.  I have looked online and saw full mortise, half mortise, non-mortise locks available, but have no idea from the descriptions as to which one is best for my application.  Would welcome any advice.
A little detail:  cabinet is made from solid cherry- doors are solid cherry slabs that will be mounted to the front edge of the cabinet with decorative box hinges.  Doors are approximately 7/8" thick.
Thanks!
Gerald
Gerald
I have Festools- Big and Small and a few other tools
Offline neilc
Re: Cabinet Door Lock Recommendations
« Reply #1 on: February 05, 2019, 08:20 PM »
We have a mahogany bar cabinet with a liquor cabinet requiring a locking door -
One door has a simple spring latch like this - https://www.rockler.com/solid-brass-elbow-catch
The other had a lock similar to this - https://www.rockler.com/1-3-4-long-cylinder-lock-choose-finish-and-keying-method
Simple clean installation.  You can go with a mortised lock as well.  Price on these will obviously vary depending on finish and material.
Depends on the tools, time and budget you want to apply.
Offline blaszcsj
« Reply #2 on: February 05, 2019, 08:52 PM »
This lock is cool.
OF1010 EQ Router | MFT/3 | DF500Q | Carvex 420 | ETS EC 150/3 | CT 36 Auto Clean | TSC55 | LR32 | OF1400 EQ Router | ZOBO Metric Set | CXS Li 2.6 - 90 Limited Edition | Universal Cleaning Set | HKC55 | Centrotec CE-SORT | RO150 FEQ | DTS 400 | RO90 DX | CTSYS | C18 Drill | SysLite KALII | Syslite STL 450 | RAS 115 E | OF2200 EB
Online Gerald_D
« Reply #3 on: February 06, 2019, 01:29 PM »
Thanks guys for the recommendations.  Neil, I thought of your solution for my application, but don't think it will work to mount the spring latch- the floor of the cabinet needs to be free of obstructions, and the tops of the doors and cabinet raise up to a point (think of a gable roof), so the spring latch would have to be mounted too high to reach.  I could go with a cam lock in each door and have them keyed alike, but thought that was too redundant.
Appreciate the ideas!
Regards,
Gerald
Gerald
