Author Topic: edge banding miters with conturo  (Read 1247 times)
Offline build2ski
« on: March 10, 2018, 03:44 PM »
 having trouble with edge banding 3/4 ply cut at 45 degrees. i set the conturo at 45 in the table but when set at 45 and adjusted for 3/4 edge band there is not enough from for the plywood to pass through between the table and the conturo.. what am in doing wrong here..
Offline TOOLTOWN
  • Festool Dealer
    • tooltown.com
Re: edge banding miters with conturo
« Reply #1 on: March 10, 2018, 07:49 PM »
It sounds like you are trying to use the same height of edgebanding for a 90 and 45 degree application.
Once cut on an angle, the height of the banding will need to increase to meet the new hypotenuse length.
Is this the problem, or did I misinterpret what you are saying?
Ken
Offline tjbnwi
  • Cedar Tucky Indiana
« Reply #2 on: March 10, 2018, 08:57 PM »
As Ken mentioned, you'll need at least 1-1/8" edge banding.
Some day I'll get the Conturo table. Hoping to find a used one....
Offline build2ski
« Reply #3 on: March 12, 2018, 12:39 PM »
both are correct... i was trying to use the 3/4 edge band on my 45 degree because i'm cutting the long point back 1/4 to 90 degree so i don't need the entire hypotenuse covered in edge band. plus i don't have 1 1/4 edge band.. the solution was to do the entire 1 1/4 edge band which is the smallest setting you can do 30mm for the 3/4 set on a 45 and then cut the square edge and the edge after. then edge band square section.... [eek]
anyway resolved thanks for input
