Author Topic: How would you fix this?  (Read 1841 times)
Offline Andreus
« on: January 07, 2015, 07:39 PM »
Greetings all. I'm refinishing this table, pictured, which has a crack in one of the turnings (see below.)
What is the best way to go about filling in this crack so it matches the shape of the turning? The leg is about 2" in diameter and I'm going to repaint it so color is not a big issue I just want to reconstruct the shape accurately.
Offline roblg3
  • Transforming into a whole new machine
Re: How would you fix this?
« Reply #1 on: January 07, 2015, 07:55 PM »
There's several types of filling epoxies.  Woodcraft sells one.  It's. Intended to sculpt on like clay.  You then cut/scrape/sand to get the desired shape.
Rob Gardner
Operator
RL3 Enterprises
Offline Brent Taylor
« Reply #2 on: January 09, 2015, 07:50 PM »
Build new legs and aprons, lose the sawdust board & uses your tools. It will last longer & give you time in the shop. And the legs will burn nicely.
Offline T. Ernsberger
« Reply #3 on: January 09, 2015, 08:04 PM »
You can go to any home center and get bondo home solutions.   It uses a white hardener instead of red.   It works great for rebuilding wood.
Offline NERemodeling
    • New England Remodeling, LLC
« Reply #4 on: January 10, 2015, 03:49 PM »
I would probably do a little research of local woodshops, stair companies, wood turners and see if they could make a reproduction for you.   Cost shouldn't be crazy, it will take a bunch less time and effort and the repair will be much nicer.
CT26  -  (2) Midi  - Planex - Kapex -  Domino 500  -  Carvex  -  TS55EQ -  Rails; 800, 1080, 1400(holy rail), 1900, 3000 -  OF1400 - OF1010  - LR 32 - RO 150 - RO90 - RAS115 - ETS125 - DTS400 - LS130 -  EHL65 - HL850 -  MFT1080 - (2) MFT800
Offline Motown
« Reply #5 on: January 10, 2015, 04:26 PM »
I'd highly recommend this product:
http://www.abatron.com/buildingandrestorationproducts/woodrestorationmaintenance/woodepox.html
Not cheap, but if you think you could use it again on another job then it might be worth a go. I've used Bondo on exterior paint work and it wont work for this repair. With Abatron's wood  epoxy you can actually work the material with your hands (with gloves they provide).
