Author Topic: I blue'd it...  (Read 1440 times)
Offline Richard/RMW
I blue'd it...
« on: November 12, 2017, 03:34 PM »
Black oxide to be more precise. Been experimenting with the gun cold blues available on amazon recently on some hairpin legs for a live edge table & rehabing some machinist tools.
Got fed up with surface rust on stuff in the unheated shop so I ordered some Caswell concentrate w/ their penetrating oil. Gave an abrasive tumble to a bunch of small stuff, hit it with aerosol brake cleaner (spray acetone?) and double dipped (dip/rinse/dry/repeat)in the black oxide followed by a quick bath in the oil.
Previously used this on some machine steel parts of a Veritas carving vise and it is looking like it may prevent them from re-rusting this winter. Fingers crossed. It's a PITA but better than letting everything go to heck.
Anyone else using similar stuff to protect metal or as patina on projects?
RMW
Offline Gregor
Re: I blue'd it...
« Reply #1 on: November 12, 2017, 03:43 PM »
Interesting.
Please keep us updated how the stuff behaves when you use the tools, does it hold up against mechanical wear or does it scratch easily and the rust returns?
Also: Care to link the product(s)?
Offline rvieceli
Re: I blue'd it...
« Reply #2 on: November 12, 2017, 03:46 PM »
Richard - CAswell says the penetrating oil leaves an oily finish. How bad is it? I need something that is clean to touch.
Been using Birchwood Tech stuff but am not thrilled with the room temp black.
Thanks.
Ron
Offline Sparktrician
Re: I blue'd it...
« Reply #3 on: November 12, 2017, 03:49 PM »
My gunsmith first parkerized, then chemically blued a rifle for me almost 30 years ago.  It has held up very well through all kinds of weather, not to mention numerous cleanings.  And no oily finish whatsoever (unless I get careless in my wipe-downs).
- Willy -
Offline Richard/RMW
Re: I blue'd it...
« Reply #4 on: November 12, 2017, 07:56 PM »
The latest stuff I used was from Amazon.
Prior to that it was the Birchwood Casey and Precision Tool-Black. They all seem to work about the same, the reason I bought the latest batch was I wanted enough volume to soak parts in. This kit can make up to 1.25 gallons.
@rvieceli - Ron there is definitely a perceptible oiliness at first but with a little handling it seems to go away to the touch. I don't think I would use it on anything that might contaminate a surface to be finished i.e. a plane sole.
I'll update this after I see how things fare this winter.
RMW
Offline Holmz
Re: I blue'd it...
« Reply #5 on: November 22, 2017, 02:50 AM »
Interesting.
The stuff I used way back (Beechwood Casey) wore off, but it looked pretty cool on a beat up old table saw.
