Kodi Crescent
Offline
« on: November 12, 2011, 10:24 AM » |
To Hewey Lewis's "I need a new drug":
I need a new putty. One that won't make me sick One that won't give me walking pneumonia Or that comes in a stick
I need a new putty One that won't crack One that if I sand it dry Won't make me or my spouse hack
One I can stain or paint One that that's not tough to use One that is compatible with wood glues
One that I can use...
I've been using this Minwax putty, I forget the name. It's kind of like Bondo (I think). The last time I used this stuff without a respirator, I ended up with walking pneumonia (could be a coincidence).
I was sanding some recently without a respirator, and lo and behold I have some sort of respiratory problem now.
So I'm looking for a new putty/filler. I don't have much experience with that Durham Rock Hard putty. It seems a bit brittle. What other options are available that won't require a hazmat suit to use?
Peter Halle
Global Moderator
Online
« Reply #1 on: November 12, 2011, 10:30 AM » |
This might be worth a look: TimbermateI started using this stuff last week and don't have much experience with it, but I think that you can do a search here and find more information. Peter
SRSemenza
Global Moderator
Offline
« Reply #2 on: November 12, 2011, 02:03 PM » |
Is that the two part Minwax filler? Yeah, sort of like Bondo. I really like the solid, very effective fill, and the drying time. But you are right ... resperator all the way. Nasty stuff.
Festool Service 800-554-8741
Kodi Crescent
Offline
« Reply #3 on: November 12, 2011, 03:55 PM » |
Minwax high performance wood putty. I like its characteristics, but yes, respirator for all work with it.
Kodi Crescent
Offline
« Reply #4 on: November 12, 2011, 03:57 PM » |
Thanks, Peter. I'll look for that and give it a try.
Peter Halle
Global Moderator
Online
« Reply #6 on: November 12, 2011, 04:23 PM » |
I forgot to say that Woocraft carries the Timbermate. Sorry.
Kodi Crescent
Offline
« Reply #7 on: November 12, 2011, 08:31 PM » |
Thanks Peter. I'll go there and check it out.
Kodi Crescent
Offline
« Reply #8 on: November 12, 2011, 08:33 PM » |
Zar, another option. Thanks mishle!
rnt80
Offline
« Reply #9 on: November 12, 2011, 09:05 PM » |
Thumbs up for Timbermate. I've been using it for over a year and love it. It's waterbased so if you need to thin it or if it drys out you just add some water.
mishle
Offline
« Reply #10 on: November 12, 2011, 09:58 PM » |
Timbermate has free samples I'm going to order it and try them side by side.
SRSemenza
Global Moderator
Offline
« Reply #11 on: November 12, 2011, 10:10 PM » |
I just did the same. I hope it works as well as the Minwax. Seth
Kodi Crescent
Offline
« Reply #12 on: November 13, 2011, 10:02 AM » |
I'll go buy some of that today and try it. That Minwax is just too irritating to the respiratory system to continue to use.
junk
Offline
« Reply #13 on: November 13, 2011, 10:09 AM » |
I originally was using Famowood fillers but after a while they developed really off smells in the container. I've been using the Timbermate for about 8 months now and the product works great, only problem is the antibacterial agent they use in it has a unique odour and the smell is hard to get off your skin.
John
JLB builders LLC
Offline
« Reply #14 on: November 13, 2011, 10:44 AM » |
I use this. Works great on PVS trim out doors, filling nail holes on interior paint grade trim. I also have used it to fill hinge routes and latch plate routes when taking a single door frame and putting in a french door style. The door on my sig pic had a screen door at one time and I filled the hinge mortis, sanded and painted and they are gone. Inside the same door I removed an old deadbolt that mounts on the door and the trim was notched, I cut a piece of trim to fill the space then used this stuff to fill and sand, unless you are 3-6 inches you can't even tell with one coat of paint. http://www.homedepot.com/h_d1/N-5yc1v/R-100398387/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
