Pages: [1]   Go Down
  Print
Author Topic: I need a new putty  (Read 2136 times)
Kodi Crescent
Offline Offline
« on: November 12, 2011, 10:24 AM »
To Hewey Lewis's "I need a new drug":
I need a new putty.
One that won't make me sick
One that won't give me walking pneumonia
Or that comes in a stick
I need a new putty
One that won't crack
One that if I sand it dry
Won't make me or my spouse hack
One I can stain or paint
One that that's not tough to use
One that is compatible with wood glues
One that I can use...
I've been using this Minwax putty, I forget the name.  It's kind of like Bondo (I think).  The last time I used this stuff without a respirator, I ended up with walking pneumonia (could be a coincidence).
I was sanding some recently without a respirator, and lo and behold I have some sort of respiratory problem now.
So I'm looking for a new putty/filler.  I don't have much experience with that Durham Rock Hard putty.  It seems a bit brittle.  What other options are available that won't require a hazmat suit to use?
Peter Halle
Global Moderator
Offline Offline
WWW
« Reply #1 on: November 12, 2011, 10:30 AM »
This might be worth a look:  Timbermate
I started using this stuff last week and don't have much experience with it, but I think that you can do a search here and find more information.
SRSemenza
Global Moderator
Online Online
« Reply #2 on: November 12, 2011, 02:03 PM »
Is that the two part Minwax filler? Yeah, sort of like Bondo. I really like the solid, very effective fill, and the drying time. But you are right ... resperator all the way. Nasty stuff.
Seth R. Semenza
S. R. Semenza Woodworking
Festool Service 800-554-8741
Kodi Crescent
Offline Offline
« Reply #3 on: November 12, 2011, 03:55 PM »
Minwax high performance wood putty.  I like its characteristics, but yes, respirator for all work with it.
Kodi Crescent
Offline Offline
« Reply #4 on: November 12, 2011, 03:57 PM »
Thanks, Peter.  I'll look for that and give it a try.
mishle
Offline Offline
« Reply #5 on: November 12, 2011, 04:20 PM »
I have used the Zar brand putty http://www.acehardware.com/product/index.jsp?productId=3577570&CAWELAID=342248200zar
But I'm always open to something better
I however do NOT recommend their polyurethanes at all, though the company did refund all my money on that product so they do have good customer service.
Peter Halle
Global Moderator
Offline Offline
WWW
« Reply #6 on: November 12, 2011, 04:23 PM »
I forgot to say that Woocraft carries the Timbermate.
Sorry.
Kodi Crescent
Offline Offline
« Reply #7 on: November 12, 2011, 08:31 PM »
Thanks Peter.  I'll go there and check it out.
Kodi Crescent
Offline Offline
« Reply #8 on: November 12, 2011, 08:33 PM »
Zar, another option.   Thanks mishle!
rnt80
Offline Offline
WWW
« Reply #9 on: November 12, 2011, 09:05 PM »
Thumbs up for Timbermate.  I've been using it for over a year and love it.  It's waterbased so if you need to thin it or if it drys out you just add some water.
Russell Tribby
Gilbert AZ
www.agapewooddesign.com
mishle
Offline Offline
« Reply #10 on: November 12, 2011, 09:58 PM »
Timbermate has free samples I'm going to order it and try them side by side.
SRSemenza
Global Moderator
Online Online
« Reply #11 on: November 12, 2011, 10:10 PM »
I just did the same.  I hope it works as well as the Minwax.
Seth R. Semenza
Kodi Crescent
Offline Offline
« Reply #12 on: November 13, 2011, 10:02 AM »
I'll go buy some of that today and try it.  That Minwax is just too irritating to the respiratory system to continue to use.
junk
Offline Offline
« Reply #13 on: November 13, 2011, 10:09 AM »
I originally was using Famowood fillers but after a while they developed really off smells in the container. I've been using the Timbermate for about 8 months now and the product works great, only problem is the antibacterial agent they use in it has a unique odour and the smell is hard to get off your skin.
John
JLB builders LLC
Offline Offline
WWW
« Reply #14 on: November 13, 2011, 10:44 AM »
I use this. Works great on PVS trim out doors, filling nail holes on interior paint grade trim. I also have used it to fill hinge routes and latch plate routes when taking a single door frame and putting in a french door style. The door on my sig pic had a screen door at one time and I filled the hinge mortis, sanded and painted and they are gone. Inside the same door I removed an old deadbolt that mounts on the door and the trim was notched, I cut a piece of trim to fill the space then used this stuff to fill and sand, unless you are 3-6 inches you can't even tell with one coat of paint.
http://www.homedepot.com/h_d1/N-5yc1v/R-100398387/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
Assorted Playskool tools and some Bob the builder vids,
Kapex,TS75,CT26E,Domino,Kreg jig,Fein MM,Fein 6 inch sander, many Systainers,Porter Cable 6" joiner/13 inch thickness planner and Bosch tools etc.
http://www.facebook.com/pages/JLB-Builders-LLC/118746931490281
Pages: [1]   Go Up
  Print
Jump to:
