Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
June 19, 2013, 01:06 AM
Home
Search
Login
Register
Festool Websites
Festool USA
Festool UK
Festool Canada
Festool Australia
Festool Netherlands
Festool Germany
Festool International
Spare Parts Catalog
Product Websites
CMS Router Table
Cordless Drills
DOMINO Joiner
HEPA Dust Extractors
Jigsaws
Planex Drywall Sander
Rotex Sanders
SysLite Work Lamp
Track Saws
Woodworking & Power Tools Forum - Festool Owners Group
GENERAL DISCUSSIONS
Various Woodworking & Crafts Topics
Trimming rifle stock with TS 55 and MFT
Pages: [
1
Go Down
« previous
next »
Print
Author
Topic: Trimming rifle stock with TS 55 and MFT (Read 975 times)
Kodi Crescent
Offline
on:
June 08, 2012, 10:20 PM »
Hi. I'd like to adjust the length of pull on a rifle stock. I could pay a gunsmith a couple hundred bucks to do this, but I thought with all my Festools I could do it just as well myself and save myself the money and hassle of taking it in.
I was thinking about wrapping the cut area with tape, marking it, aligning my cut marks with the rail on the MFT, clamping the rifle so it didn't move, and then making the cut with the TS 55.
Does anyone see any problems or pitfalls with doing this? I believe the stock is walnut. I've never worked with walnut before, so I don't know what to expect? Any warnings before I try it?
Thanks!
Henning
Offline
Re: Trimming rifle stock with TS 55 and MFT
Reply #1 on:
June 09, 2012, 04:27 AM »
I've done something similar, but with the TS I would build a softwood frame around the buttstock the same height and use that to support the rail. Then making sure everything is clamped tight, cut. Please be aware of the following though:
1. Is the stock straight on the shoulder side? If not, best leave it to someone else.
2. Figuring out how much you need to take off isn't always as easy as it looks. Doublecheck is in order!
3. Make sure you do a test run before committing and thinking through the whole job.
It is not rocket science, but there are some things which can go wrong so best think it through properly.
Take a wide blue masking tape around the stock to mark your cut. Make sure it's tight and flat all around. This will also help against break out on the back.
A lot of shiny new Festool and no money!
TS55EBQ, OF1400EBQ, DF500EBQ, PS400EBQ, WT-PS400, HL850EB+, RE125FEQ, BS75E+,CTL36E, ETS125EQ+, MFS, OF-FH, LED-FX C/T-HL, SYS 3-Sort/9 and almost all possible accessories...
Next to buy: OF1010EBQ or OF2200 and 700mm. MFS profiles
SRSemenza
Global Moderator
Online
Reply #2 on:
June 09, 2012, 11:17 PM »
Also do a trial run on the actual stock by making a test cut that removes significantly less than you want to take off. That will reveal any potential problems while leaving plenty of room for the real cut.
Seth R. Semenza
S. R. Semenza Woodworking
Festool Service 800-554-8741
Pages: [
1
Go Up
Print
« previous
next »
Jump to:
Please select a destination:
FESTOOL DISCUSSIONS
=> Festool Tools & Accessories
=> Festool Tool Reviews
=> Festool How To...
=> Festool Tool Problems
=> Festool Jigs & Tool Enhancements
=> Festool Wish List
=> Festool and Tanos Systainers
=> Ask Festool
=> Sales & Dealer Area
=> Fun, Games, Diversions
GENERAL DISCUSSIONS
=> Member Projects
=> Other Tools & Accessories
=> Other Tool Reviews
=> Hand Tools
=> Building Materials
=> Finishing and Painting
=> Various Woodworking & Crafts Topics
=> Home Improvement & Other Projects
=> Member Connections
FORUM TECHNICAL
=> Gallery & Attaching Images
=> Forum Features & Functions
=> Forum Rules, Guidelines, & Suggestions
OFF-TOPIC
=> Computers, Gadgets, Technology
=> Photography
=> Sports & Recreation
=> General Friendly Chat
=> Classifieds
