Author Topic: Sys 32 and Drawer slides - CONFUSION  (Read 3645 times)
Offline fritter63
« on: June 18, 2017, 11:13 PM »
Hey all, I'm getting ready to CNC a couple of base cabinets for the shop. I'm of course going to base them off
system 32 to make it easy. I'll have the CNC actually drill the holes for me.
But looking around, I get a little confused on the drawers slides and where the system holes should be.
Of course, that front row should be at 35 mm in, but for the back of the slides, I find conflicting implementations.
Example: there his this one at McMaster-Car (which is nice because I can grab the CAD model and insert it into my 3D drawing:
https://www.mcmaster.com/#11435a26/=1843qav
Then there is this one at CS hardware (a good source for cheap slides, which I've used in the past).
http://www.cshardware.com/500mm-19-69-soft-close-box-or-file-slide-side-mount-full-extension-65-pound-capacity.html
Comparing the two, you can see the the McMaster--Carr slides have a hole WAY at the back of the slide (453 mm from the front) which seems to make sense.
But the CS hardware one has it's last hole at...323 mm from the front (you can see it when you download the spec PDF), i.e. way forward of the back of the cabinet.
I have this CAD program parameterized so I can just change some overall dimensions and have it adjust for different cabinet sizes, but I'm not sure which of these "standards" to use.
Any insights on which I should code to? The CS hardware ones seem to be some logical multiple of 35 mm + 64mm + 32mm + 96mm, etc. So those almost look like they are the best.
Is this "True 32" vs "System 32" vs "Process 32" standards ?
Offline Bohdan
Re: Sys 32 and Drawer slides - CONFUSION
« Reply #1 on: June 19, 2017, 12:12 AM »
Actually the front row should be at 37 mm in, and the position of the back row depends on the length of the slide. There are several common middle rows and the choice is up to you. Choose whichever will suit the most common length of slide that you will use.
Have a look at http://benchmark.20m.com/tools/Festool/32mm/festool_32mmholes.html.
« Last Edit: June 19, 2017, 12:20 AM by Bohdan »
Offline Richard/RMW
« Reply #2 on: June 19, 2017, 07:18 AM »
@fritter63 - not sure this will help but you can find some info comparing the various 32mm systems here:
http://www.davelers.com/32mm/files/4988_What_all_32mm_systems_have_in_common.pdf
Full disclosure - I don't fully understand this stuff myself.
RMW
Offline clark_fork
« Reply #3 on: June 19, 2017, 10:43 AM »
This post by Sparktrician is a keeper for the distances:
It addresses another issue entirely, that of using parallel guides for boring the holes but the distances etc are relevant to your search. Also, the drawer slide sites have PDF copies of the hole layout and distances within  the cabinetry and from the front of the cabinet.
http://festoolownersgroup.com/festool-how-to/boring-panel-holes-using-the-festool-lr-32-and-the-parallel-guides/msg271153/#msg271153
Note: Sometimes, a FOG member will post a message that is so helpful, that it becomes method worthy and this is one such post.
« Last Edit: June 19, 2017, 10:48 AM by clark_fork »
Clark Fork
"A lot of people are afraid of heights. Not me, I'm afraid of widths."  Stephen Wright
"straight, smooth and square" Mr. Russell, first day high school shop class-1954
" What's the good of it?" My Sainted Grandmother
"You can't be too rich, too thin or have too many clamps." After my introduction to pocket joinery and now the MFT work process
"Don't make something unless it is both made necessary and useful; but if it is both necessary and useful,
don't hesitate to make it beautiful." -- Shaker dictum
Offline GarryMartin
« Reply #4 on: June 19, 2017, 01:21 PM »
37mm is only the standard "in" dimension for most "outer drawers". There is no standard "in" dimension as it depends on many variables including whether the cabinet will use a face frame or not, what the thickness of the drawer front will be, whether it's an internal drawer etc.
You need to select your drawer slides first, and then take the dimensions from the installation instructions for them. Although there may be some commonality of dimensions between manufacturers, don't take it for granted.
Different slides will advise different dimensions, and even the same slide used in differing conditions (overlay or inset drawer fronts) will use different (even sometimes multiple) hole positions from the option of hole locations provided, and will use more or less of those holes depending on the type of screw being used and the load rating of the slide!
Standards? We don't need no stinkin' standards!!!  [crying]
For example, from a popular Blum undermount slide...
