Reiska
Offline
Hackers build things, Crackers break them.
« on: January 26, 2012, 10:04 AM » |
I'm totally fed up with sawing everything that cannot be cut with my mitre saw with my jigsaw and handsaws so I've been looking into buying either a table or a track saw. If you can only have one which one would it be? I'm trying to build a nicely workable amount of power tools into my livingroom/backyard "workshop" but am badly constrained by dry & warm storage space and somewhat by money (max. 800-1000€ for the saw). My needs for portability are limited to carrying the gear from my living room out onto the terrace (6m) and back and in the winter time to the housing complex hobby room (30m) and back (you can't leave anything expensive there unsupervised). I must have all large sheet goods ripped to smaller dimensions at the wood store since they wouldn't fit my car and as a Honda Hybrid it can't pull a trailer. My projects for the next couple of years include mainly building back yard furniture (benches with storage boxes under the seats, dining table & chairs and some sort of a work table (got the UWB plans as one option) as well as I'm going to build some sort of a sysport like shelf system under the living room stairs to optimize my tool storage space. I don't believe that the TS+CMS-base combination is convenient and exact enough after my dismal experiences with Wolfcraft MasterCut 1000 "universal" circular saw table adaption that is impossible to get squared to the fence and I don't feel like going on my knees to adjust the height or tilt of a table saw, nor is it my price range at 1200€+ since you can't find those used anywhere. So I guess the question is can a track saw achieve the same things you can do with a table saw only on a track and a MFT/UWB-like workbench and what are plusses and minuses of each approach? Since I haven't used a table saw since middle school (and then they were the industrial ones) I'm a bit out of what all can be done on it so I would appreciate it if you can point out things that are impossible to with one or the other type of saw. I've been looking at options of either getting a TS55 Set or Mafell tracksaw or a used Festool CS70 or one of the new Bosch/ Makita "portable" table saws.
The sky's the limit in my workshop, literally.
zapdafish
Offline
« Reply #1 on: January 26, 2012, 10:14 AM » |
I would take a tablesaw. But I am taking my needs into consideration, not yours  I drive a honda civic coupe so always have sheet goods cut down when I buy it in order to get it home. On the few occasions when I need something larger I borrow my parents van. I am starting to use more lumber than sheet goods as well which is why I choose tablesaw. I don't have an mft or parralel guides so having those accessories may make a difference
« Last Edit: January 26, 2012, 10:16 AM by zapdafish »
Sparktrician
Offline
Location: Northern Virginia (That's in the USA, Pilgrim!) Member Since: Dec 2009
« Reply #2 on: January 26, 2012, 10:21 AM » |
I would suggest that if space and dust mitigation are criteria, the track saw is THE way to go. It stores very compactly and couldn't be easier to move around. Saw horses fold up to minimal sizes, and when used with a sacrificial sheet of rigid foam insulation, can support ripping and cross-cutting, which when terminally damaged, can be cheaply replaced. I have a table saw, and continue to use it for certain cuts, but the TS55 track saw is my go-to choice more and more. That's based on my current needs and space constraints. The MFT/3s and parallel guides are icing on the cake for me. YMMV...
« Last Edit: January 26, 2012, 03:40 PM by Sparktrician »
- Willy -
MFT/3 x2, TS 55, Guide Rails x5, Parallel Guide Set, CT 22 w/Boom Arm, CT Mini, RO 90, RO 125, ETS 125, RTS 400, RAS 115.04, C 12 + Centrotec Imperial Bits, CSX Set, TI 15, DF 500 Domino Set, SCG-10, Domino Plate from RonWen, MFK 700 Set, CMS-GE, OF 1010, OF 1400, OF 2200 Set, LR 32 System, MFS System, Syslite, Systainers, Sortainers, clamps.
Coming attractions: Carvex, Kapex, more "Stuff"-tainers...
Alex
Offline
« Reply #3 on: January 26, 2012, 10:41 AM » |
A tablesaw. There aren't any things you can do with one but not the other, the real question is through how many hoops are you prepared to do so. For smaller cuts the tablesaw is a lot more convenient. Since you have your sheet material cut at the store, you'll be mainly doing the small cuts yourself.
But if your budget is up to €1200, I don't see why you couldn't get both. Unless you only want to consider brand new Festools or Mafells. I don't know how the used market is in Finland, but here in Holland you could find a used CS70 for €600-700 and a used TS55 with rail for €250-300. And that price would go further down when you're willing to consider non-Festool options.
Btw, never compare a Wolfcraft to a Festool, that's just so wrong on so many levels .......
andvari
Offline
« Reply #4 on: January 26, 2012, 11:07 AM » |
I think Alex has it right. For 1000€ you should be able to do both a track saw and a small table saw, and that would give you a great setup.
Reiska
Offline
« Reply #5 on: January 26, 2012, 11:25 AM » |
Unfortunately the used Festool gear market is rubbish in Finland - you either get totally beaten up tools that I wouldn't touch with a ten foot pole @ 70-80% of new price (i.e. more expensive than mail-ordering new gear from Germany) or then you get one gem a year or two of an occational bankrupcy, retirement, etc. like the twice used bankruptcy CS70 today that's auction I lost @ 800€ (the seller just cut the bidding short after the first bid was laid down hours before the stated ending time of the auction... guess who would have been the 2nd bidder  ) I've seen two other beaten up specimens of CS70 E & EB within the last year or so to sell for about 900€ here. Mostly our hardware stores sell mainstream makes like Bosch, Makita and Dewalt and you need to find one of the two or three Festool stores in the country that actually even sell to non-company affiliated people. Also the new prices for Festool tools are ridiculous here (though with postage from Germany some extra parts are actually cheaper sourced locally like the FS1400/2 LR-32 rail for my router was 112€ locally and 120€ from Gerscwitch with postage, but then the LR32-Set was 452€!) but like the list price for a CS70 EB non-set is 2027€ here new and a FS55-CMS-Set will set you back 1417€ and a FS55-Set only a good 616€ new and the importer keeps a stranglehold on resellers to not differ from suggested retail price for normal non-company affiliated people  I've looked on eBay Germany and drooled over the used TS's there, but very few sellers are prepared to send anything outside of Germany. If I only could reasonably afford one I'd love to have a CS70-Set like Alex got by luck, but it doesn't look like it's going to happen any time soon since the importer doesn't even list the Set-version in their catalogue, so don't know if you can even buy one here. And yes, 1200€ is beyond my hobby spending budget for this year because i've got a CT-vac on the shopping list too (and no there are no packages with a TS-saw in Finland that I know of). And as a side note I do prioritise ease of use and the tools cut quality over portability since when I set up my garden terrace workshop I set it up in the morning and work till dusk and pack everything away for the night & clean the terrace at the end of the day (or when ever it decides to rain). Dust collection is important to me since I've inhaled my fair share of concrete dust during the renovations of this house a few years back, but since I work outside under the clear blue sky I can get away with a normal portable shop vac connected to my tools even non-Festool ones - winter time is different since we have a metre of snow in the yard at the moment so then I need descent dust collection in the hobby shop of our housing complex, but I rarely work on large projects in the winter anyway.
« Last Edit: January 26, 2012, 11:34 AM by Reiska »
GreenGA
Offline
Location: Marlton, New Jersey, USA Member Since: Oct 2007
JR
« Reply #6 on: January 26, 2012, 11:40 AM » |
I have both; table saw and track saw. If I were contrained by either money or space, I would lean towards the track saw.
While the table saw is very convenient and options abound to make it even easier to use (think Incra TS-LS), just about everything that you can do on the table saw, can also be accomplished using the track saw and advanced planing. It just takes longer.
Never use a 2x4 when a 2x6 will do just as well
SYS-Lite, CMS/GE, TS55, KAPEX, MFT/3, CXS Kit, C15 Set, TI 15 Set, C12 Set, CT48 w/Boom Arm, HL850, RO90, RTS400, DTS400, LS130, DX93, RO150, ETS 150/3, RAS 115/4E, RS2E, Domino Classic, OF1010 EQ, OF2000E+, OF1400, MFS700, LR 32-SYS+97" rail, 2011 Centrotec, Zobo Forstner Bit Set, Guide Rail Kit, Parallel Guides, Tradesman Cleaning Set, Shinex, lotsa 'tainers (Sorts, Attics, Classic, New and Blue). Coming Attractions: MFK700 Kit, Workcenter, Domino XL Kit, Carvex 420 & Accessory Kit
SRSemenza
Global Moderator
Offline
« Reply #7 on: January 26, 2012, 12:15 PM » |
The answer to your topic question is that it will depend on the situation of the user.
I assume that since you are considering a table saw that you have space for one including infeed / outfeed. Is the working space for the table saw only outside? Do you have space inside the hobby room to operate a track saw? If the table saw will only be used outside, and there is room to use the track saw inside, I think the track saw will extend your work time. The track saw can truly be used inside the house with very little clean up.
As you have clearly stated you are only considering one or the other due to space and money issues. The track saw will need less space when stored. The vac , cutting table, and other track saw accessories work with many other tools, so they can't really be counted as part of the storage space for the track saw.
Another consideration.... if you go with a Festool track saw, then you would already have the saw to put in a Festool CMS (?) or other stationary set up, in the future when funds allow.
Festool Service 800-554-8741
waho6o9
Offline
Location: San Fernando Valley, Los Angeles California Member Since: Dec 2009
« Reply #8 on: January 26, 2012, 12:20 PM » |
In your situation Reiska I would use a Track saw. Here's why, your supplier will rip your sheet goods to fit in your car. Therefore, all you have to do is crosscut. So I would get the track saw. If and when you need to rip stock, or sheet goods, the track saw will do that. And it's safer to crosscut with a track saw than on the table saw. Good luck Reiska on your choice.
CDM
Offline
« Reply #9 on: January 26, 2012, 12:28 PM » |
I use a TS 55 and MFT/3 in my living room most of the year. The TS 55 is out of sight in a closet when not in use, and the plug-it cord is separately secured, since I have kids in the house. When the weather is nice I work just outside on a deck. There I don't get all-day work windows and I do bring them inside if I have to leave for any great length of time. Either way the dust control is excellent and safety is too. I could get a contractor table saw for a lower or comparable price, but I would have to store it in view somehow and it wouldn't have full health and safety features that I want without jumping up a lot in cost.
One possibility you might try is finding a local hobbyist, woodworking group, or shop with better space and tools than you have. You might be able to use tools you don't have for rent, for free, or as a service trade (table-saw access for steam-bending help, for instance).
davee
Offline
« Reply #10 on: January 26, 2012, 12:31 PM » |
My build list looks much like yours - various furniture, cabinets, etc. I have both a table saw and the Festool track saw. I am just starting a month between shops and had to pick only one in a very limited space. I selected the track saw and MFT. I did so because of versatility, safety and dust control. I will be glad to get my table saw back, but as backup not primary.
Kev
Offline
« Reply #11 on: January 26, 2012, 12:52 PM » |
I have a KAPEX, TS55, CARVEX and MFT/3. (I'm only talking about Festools, I have various other brand tools for sawing, but I'm changing over)
I'll get a table saw soon, but I purchased in the above sequence based on my theory of what I'll need the most in the near future.
Kev
NoBreyner
Offline
« Reply #12 on: January 26, 2012, 01:28 PM » |
I have yet to use my tablesaw again since getting the MFT/3 TS 55 combo two weeks ago. Maybe I'm just plain tired of using my CT Mini/Dust Deputy combo as a floor sweep rather than catching it at the source.
jtwood
Offline
« Reply #13 on: January 26, 2012, 02:10 PM » |
The reason that I got into Festool was the TS75, hoping it would replace an aging table saw. It didn't, because of what I use it for. I am a retired guy whose hobby is building furniture in my garage. The TS is great for ripping sheet goods and making cross cuts on smaller pieces, but it won't do everything I need to do for furniture when cutting pieces to size, doing dadoes and a few other things. The precision for making repeated cuts for multiple identical parts is easier, for me, on a table saw, too.
CAN you get by with a TS, a miter saw and a circular saw, etc.? Yes, but it depends on how important your time is to you and how important things like fine furniture are to you. The table saw makes a lot of things easier and faster for me.
By the way, I still ended up with 4 Festool sanders, a couple of Festood drills, a Festool router, MFT, parallel guides for the saw, etc., so I am not anti-Festool in any way
Reiska
Offline
« Reply #14 on: January 26, 2012, 03:06 PM » |
SRSemenza: The hobby rooms is large enough (an old oil tank room for the housing complex boiler, about 8m x 3m) for a track saw as well as a table saw if it has detachable in-feed/out-feed tables to get it through the door (3' wide). The worst part of the hobby room are the two "work tables" i.e. old solid core doors on saw horses. I'm seriously thinking of finding some cheap ply from somewhere and building a couple of downsized UWB's there and donate them to the housing complex to get better clamping there myself. My significant other won't allow me to work in the house with any power tools unless it involves drilling a hook into the wall nor am I allowed to run power tools while the kids are playing outside. Can one work on lumber like 2x4's & 2x8's and planks like ½"x3" and cutting joints with a track saw - doesn't it get a bit unstable if the track is balanced across the end of a 2x4 to cut the tennons? I guess you could work around that with various jigs and sacrificial pieces & clamping to an MFT-top, but jigs take space as well to store. This sort of stuff would logically be trivial on a table saw with the height adjustment and sliding table. I seem to be getting a mild track saw favourable response from you all, though many of you do state that in the long run both would be better (logical, but impractical since I don't have heated dry storage for a whole lot of gear). I do very little cabinet sort of building at the moment - if I ever get good enough at finishing I might attempt building book shelves into the library at a later date, but for now I'll just buy the inside furniture instead. If I was to go down the table saw route it would need to be a modular and carriable system that can function on it's basic set-up outside maybe even attach it to my Bosch mitre-saw bench if the bottom attachment holes would line up with the Bosch quick clamps for the GTA3800 that I have or have it's own legs. When it or the track saw's systainer are stored they are stashed under the stairs inside the house in a triangular space of about 1700mm x 1120mm x 940mm (l x h x d) on slide-out shelves or roller boards since I'm done with breaking my back lifting the mitre saw out from under there or a even worse location under the stair platform next to it that's 1120mm high as well but a larger square cubby (I always bang my head on the ceiling there)  . We have a city funded woodworking shop at a school a good 20min drive away with teachers present and all. You can rent time for about 15€/h and get to use the schools big machinery, but that adds up surprisingly fast and you can't store projects there for extended periods of time. I've been considering going there to take some classes on finer woodworking skills once I have time to relax and indulge myself in stuff I personally want to do vs. what need to be done to get a functioning back yard. I guess I'm haunted by my grandad who was a carpenter and an electrician and used to always tell me as a kid when we used to build stuff together that you can save in everything else in life but never save on your tools. I guess that's the main reason I took the green pill last summer when I bought my OF1400 and going down that slippery slope...
rookie08
Offline
« Reply #15 on: January 26, 2012, 03:15 PM » |
Hi Reiska, I used to have a table saw but it took up too much room in my garage and to try to get it moved down the stairs down to my basement shop...(let's just say my wife was checking to see if our health and life insurance was up to date). I've been extremely happy with the TS55 set up. Not only is it super accurate, glue ready cuts, but it takes up such little room I can take it anywhere I need to if the situation arises. Upstairs, downstairs, on site, to my mother in laws;  There are lots of threads on here re building your own work bench (Ron Paul's comes to mind). With the extra money you could purchase an Incra LS positioner or Incra tracks. Sure beats carrying a quality (read heavy!) table saw in and out of your storage space , IMHO. Just my  /markka/euro  Cheers James
Mac
Offline
A Scotsman living abroad
« Reply #16 on: January 26, 2012, 03:20 PM » |
TS 55 and large bandsaw (still takes up very little space in the workshop) cover everything I've ever needed to do. My  . Cheers, Rick
Reiska
Offline
« Reply #17 on: January 26, 2012, 03:53 PM » |
Thanks Mac, a bandsaw as well as a planer/thicknesser would be lovely bits of equipments, but since they have to be carriable by myself alone and packed away in the evening they are just way too heavy and bulky equipment to have.  P.S. sorry all if my responses are a bit long and not so logically progressing - I'm currently "enjoying" a good spell of influenza A with a healthy 39C temperature so keeping my thoughts totally logical is a bit tough at times...
SRSemenza
Global Moderator
Offline
« Reply #18 on: January 26, 2012, 06:14 PM » |
When you are cutting things that are narrow or potentially unstable for the guide rail you need to set up like thickness material to support the rail. Tasks like cutting tenons are better suited to a table saw, but can be done with a track saw. Some of this decision really depends on what you will be building, the joining methods used, and what other tools you have. I don't cut tenons in the traditional way for joining. I use the Domino or other methods. So I don't need the table saw for that purpose. If I did need to make a traditional tenon, I could certainly make it happen with a track saw, Kapex, and router table at my disposal.
Reiska
Offline
« Reply #19 on: January 27, 2012, 03:33 AM » |
To illustrate my "workshop" this is a picture of it when I built it last summer:
Kev
Offline
« Reply #20 on: January 27, 2012, 04:07 AM » |
One day someone is going to produce a compound mitre saw that swivels in a way that the head can present the blade parallel to it's back fence (with adjustable distance, depth, angle) ... imagine being able to use it like a safe upside down table saw  Even if you had to disconnect and reposition the head module in it's 90 degree opposed position - could be handy. Then all you need is a router sticking up from below  ... the Festool Super Combi
Jerome
Offline
« Reply #21 on: January 27, 2012, 04:32 AM » |
One day someone is going to produce a compound mitre saw that swivels in a way that the head can present the blade parallel to it's back fence (with adjustable distance, depth, angle) ... imagine being able to use it like a safe upside down table saw  Isn't that a a radial arm saw?
Jerome TS55, OF1400, Elu MOF96, Rotex150, DTS400, ETS150/3 Domino, MFK700, Trend T11, Makita LS1212, Original Mini CV06 Cyclone & Workshop supplies drum sander. Wish list WoodRat http://www.flickr.com/photos/nui-jerome/
Kev
Offline
« Reply #22 on: January 27, 2012, 04:49 AM » |
One day someone is going to produce a compound mitre saw that swivels in a way that the head can present the blade parallel to it's back fence (with adjustable distance, depth, angle) ... imagine being able to use it like a safe upside down table saw  Isn't that a a radial arm saw?  Many radial arm saws can rip and dado ... but they're bulky beasts! My history isn't great here - isn't the radial arm saw DeWalt's claim to fame?
rdesigns
Offline
« Reply #23 on: January 27, 2012, 11:34 AM » |
I vote for the table saw. I have had the TS55 for about 6 months, and it is a fine tool which you will no doubt want to buy sometime, but I recommend the table saw to start with. You are like many of us who have to fit woodworking time into a busy schedule with many other demands, like wife and kids, etc, etc. Speed is what you will gain with the table saw so that you can better use the limited time available to you. You can build a sliding crosscut table for the table saw to increase its capacity for crosscuts. You'll have the cutting capacity of a 10" blade compared to 6-1/2". You'll be able quickly and accurately dial in bevel angles. Dados and rabbets are quick and easy with a table saw. (I prefer it over the router for most cuts of this type.) The TS55 excels at breaking down sheet goods, but you already have that from your wood store.
Also, I compliment you on your enviable ability to write clearly in a language other than your native tongue.
builderbob
Offline
« Reply #24 on: January 27, 2012, 11:53 AM » |
For me, it would be a tough choice. I don't have the space for a large cabinet saw or 30" fence any saw for that matter. I use the TS55 for breaking down sheet goods and I use a portable 16" fence dewalt table saw for narrower rips. You could always buy the table saw and use any circular saw with a shooting board to get zero clearance (on one side of the blade). On the other hand, the rails in the Festool system leave so many opportunities to use other tools accurately (routers, domino (creatively)).
I'm curious to see how you fare with this decision!
Bob
Kapex, TS55, Domino, MFK 700, OF 1400, OF 1010, RAS 115, RTS 400, ETS 150/3, ETS 125, CT 22 (2), C 12 (2), T-15+3, T-12+3, PSB 300 & more MFT's than i can count!
Dan Clark
Offline
« Reply #25 on: January 27, 2012, 12:40 PM » |
Reiska, I have a TS55 and a bunch of other Festool. I've been looking around for a small table saw, like a Bosch or Dewalt. Given your portability requirement, your table saw options are limited. Cabinet saws and larger contractor saws won't work. Here's a decent contractor saw: http://www.amazon.com/gp/product/B00005OQM6/ref=pd_lpo_k2_dp_sr_2?pf_rd_p=486539851&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B000022365&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=00ZBFJ778Q9PPYN8HQM5 . It weighs 390lbs shipped. Yes, you could probably break it down in pieces and lug it in and out, but I doubt you want that. Something like the Bosch 4100 might work: http://www.amazon.com/gp/product/B000S5S5CW/ref=pd_lpo_k2_dp_sr_1?pf_rd_p=486539851&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B000022365&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=00ZBFJ778Q9PPYN8HQM5 . But with the rolling stand it's about 100lbs. That's fine if you always leave it on the stand and don't take it up and down stairs (it doesn't like stairs). Otherwise, you'll need to go even smaller. One point to consider is infeed and outfeed space for a table saw. If you're ripping a sheet of ply with a TS55, you need maybe 10-11 feet of space. On a table saw, you need something like 18-20 feet of space. IMO, a small tablesaw like a Bosch or Dewalt, plus a Festool TS55 would be the best combo for you. Regards, Dan. p.s. My constraints are somewhat different, but my space is limited and tools need to be stored away at the end of a weekend. That's one of the attractions of Festool.
Jerome
Offline
« Reply #26 on: January 27, 2012, 08:36 PM » |
I have a very old "micro table" table saw. The table moves not the blade and there is no tilt I also have an Elu circular saw that can be fixed to a table. But I had to make a similar choice to yours. Upgrade to a nice table saw or go to a track saw. I decided that the track saw was the way to go. That was 4 years ago. If I was in the same position today I would make the same choice again.
With a table saw you can certainly make repetitive cuts more easly but you need much more space. Also unless you have a very big table there are quite a few cuts that would difficult or dangerous on a table saw. I don't want to move 2 metre pieces past a blade. With the reverse (track saw) that is simple.
ScotF
Offline
Location: Southern Orange County, CA, USA Member Since: Jul 2009
« Reply #27 on: January 27, 2012, 10:18 PM » |
I have a large cabinet saw and a TS75/MFT-3 and the last two projects I have made I did with limited/no use of the TS -- this is for furniture --one desk and two cherry 5 shelf bookcases. The Parallel Guides work surprisingly well and are very, very accurate once calibrated. The cuts from the TS are very near glue ready and it was a breeze to cross-cut the big thick slabs for the tops of the bookcases and the 32 inch wide desktop with the TS75. Having both types of saws, I have options. But honestly the speed, flexibility and accuracy of Festool has greatly diminshed my need for the large cabinet saw. In fact it has so much stuff on it now (clutter, furniture parts, etc...), it would take some time to clear everything off to be able to use it. I am trying to make more and more without using it and seeing what my limitations are for what I do. So far I have not come across any...maybe the speed of setting a rip fence vs. adjusting the guides is one big advantage, but so far I have been able to easliy replicate what I used to do on a tablesaw with my TS75 and other Festools. and having the dust collection and ability to store tools away in a small footprint is a real plus. I may very well end up selling my cabinet saw at some point and regain all that space...what a treat that would be. But I am also going to continue to build some other projects with just Festool and see how it goes.
Good luck with your choice, but it sounds like your space constraints and need to move tools in and out of locked storage would lend itself to the TS55/TS75 option.
Scot
Reiska
Offline
« Reply #28 on: February 06, 2012, 04:28 AM » |
Well, so I took another sip of coolaid and got me a new TS55 EBQ + FS1400/2 rail package off our local auction site... Thanks for all your comments - I'll be putting the saw through its paces next summer and see how well it fairs  Now I just need to acquire a CT-VAC to go with it ... Hmm... CTL26 or 36
Kev
Offline
« Reply #29 on: February 06, 2012, 04:36 AM » |
Well, so I took another sip of coolaid and got me a new TS55 EBQ + FS1400/2 rail package off our local auction site... Thanks for all your comments - I'll be putting the saw through its paces next summer and see how well it fairs  Now I just need to acquire a CT-VAC to go with it ... Hmm... CTL26 or 36  Congrats on the new family member  Personally - go the 36 if it's staying local ... a lot of extra volume for a little more $'s.
