Author Topic: New workshop build  (Read 98953 times)
Offline HAXIT
New workshop build
« on: November 27, 2016, 11:53 AM »
Hi Folks,
I bought my house about 12 years ago based on 30 years mortgage but I paid double any month I could and will close it less then 2 years from now. Since then, I have been working all over from kitchen to basement and doing the hardcore stuff in a garage.It has been for hobby but it seems like turning into the business now. Any new business involves risk but I must have a shop no mater what.
I have a two car garage which I could use for shop but I have no choice and I have to build the shop in the basement. I work with metal as well and I always add them to wood when I need to and I like to be independent. I have a full time job as a welder fabricator which I have been doing for 25 years and I could get the metal work done at work but do not want to do it so. I have to split the garage in half and I am planning to make the half for welding and lumber storage and make the other half as a spray shop.
I won,t use the whole basement for the shop so the space I have there would be 600 square feet only which is the same size as my garage and exact half the basement. I have been buying and looking into the shop plans and magazines but I do not like the Ideas!
I am doing this totally in the different way and because of being in the basement the maximum safety, noise and dust control is my priority and I do not care about the cost.
I will update the progress every weekend and most likely I will upload some pictures later to show you guys what kinds of nightmare  I have to deal with. I have to go now to find out why the snowblower does not want to work. [doh]
Please, feel free to comment or giving advise most likely any of you guys who has been working in the basement for the long time or share some pictures.
Offline HarveyWildes
Re: New workshop build
« Reply #1 on: November 27, 2016, 03:09 PM »
I have a basement shop and here are some of the basics for my shop.
What kind of access do you have to the basement?  I've got a French door walkout which enables me to get things into the shop that can fit through a 5'4"x6'8" (more or less) opening.  I also have easy pickup truck access to the back door.  Without that, I'm not sure how I would have gotten the bigger machines down there.
I ran a separate electrical panel for the shop.  That allows me to be flexible with outlets and lights as my needs change.  I also installed all outlets to outdoor code to keep as much dust as possible out of the outlets.
I ran good lighting to all parts of the shop, and made sure that there was direct light to where I needed it the most.  I used fluorescent fixtures, but if I were doing it today, I'd use the new generations of LED shop lights.
When placing outlets, I took bench locations into account, so that my benches have outlets slightly above bench level.  Unfortunately they poured the floor before I got around to putting conduit in the floor for outlets, but there's only one spot where I miss it.
For dust control I have the following:
*  Dust Collector, cyclone, 1300+CFM, HEPA cartridge filter, to the stationary machines that generate a lot of chips/dust.  I wish I could have isolated it from the rest of the shop, but it did not work out that way.
*  Two air cleaners, needed because of how my shop is laid out.  I have them set up so that I can use activated charcoal filters when finishing.  All of my finishing is rubbed, so I don't have to worry too much about explosive volatile hydrocarbons.
*  CT 36.  I switched from DeWalt sanders and a Fein vacuum to Festool sanders and vacuum, and it has made a significant difference in air quality in the shop when sanding.
*  About once a year when a wind comes up (and we get 50 MPH several times a year), I open the exterior doors and windows, start both air cleaners, grab my Milwaukee M18 blower, and blow out the shop.  Takes a half an hour or so, and some papers usually end up blowing around which is irritating.  The end result is that most of the stuff that cakes on over time gets cleaned out.
For noise, I have 32dB earmuffs, but at the same time I really try to pick the quietest tools possible.  I also put insulation for sound in the ceiling to keep the noise out of the main level as much as possible.
That's the part of shop setup that I think is independent of what kind of work you are doing.
Offline HAXIT
« Reply #2 on: November 27, 2016, 06:25 PM »
Thanks HarveyWildes,
My access would be from 8 steps stairs but I still can get a lot of stuff down there but not too big.
I am agree on LED lights but I did buy a lot of fluorescent fixtures long time ago and the lights which I am going to use but in the future I would change it to LED tubes. I am not sure but I think you can fit the LED tubes in the fluorescent fixtures if you bypass the starter and the ballast. I am going to find out about this tomorrow.
Offline rvieceli
« Reply #3 on: November 27, 2016, 07:25 PM »
@HAXIT there are couple of styles of led tubes. The ones that are direct wire where you bypass the ballast and the newer styles that can be a direct plug and play with electronic ballasts.
Offline HAXIT
« Reply #4 on: November 27, 2016, 07:55 PM »
Then my search is over. Thank you
Offline HAXIT
« Reply #5 on: November 28, 2016, 05:14 AM »
OK, I have been trying to post some pictures but I end up with no luck.
I do not know what I am doing wrong but I think the problem could be the size.
Now I am going to post only one picture for test and I am attaching as inline full size.
Is this a good size or it is too large?
Offline Tinker
« Reply #6 on: November 28, 2016, 08:25 AM »
For my screen, the pic is fine.  I have a small basement shop. My biggest problem is probably dust control.  I have two CT's. My CT33 is at permanent home at end of my MFT/3 work bench.  I can move the hose to most of my other machines.  The ones that cannot be reached I have a CT22 that is easy to move around as needed.  For my planer, I have a Penn State vac with 4" hose to the planer.  That is the only machine needing the 4" hose.
I don't do very much metal work, altho in the past i have done some work with sheet metal.  Because my shop is so small and crowded, any time i do any metal work that sets sparks (My grinder)into the air, i take that out to my barn where i work on and store my outdoor landscaping equipment.  I don't want any sparks or flame in my wood shop.
Richard/RMW has done/doing a great and informative thread on his very tight woodworking shop. Look for something like 10 pounds in a 5 pound box.  I don't have that quite right, but you will get the idea if you do a search.  He has a lot of pics of some very great ideas.
Good luck
Tinker
Wayne H. Tinker
Offline GarryMartin
« Reply #7 on: November 28, 2016, 08:40 AM »
http://festoolownersgroup.com/workshops-and-mobile-vehicle-based-shops/small-shopmodular-work-surfaces-(aka-how-to-cram-10-in-a-5-sack-)/
Offline CarolinaNomad
« Reply #8 on: November 28, 2016, 01:52 PM »
My shop is in the basement as well.  I have a couple fold able saw horses in the garage to break down the sheet goods before carrying into the basement.  Bill Mueller, utube poster, posted a video of a collapsible torsion box for this reason.
As for noise, I would also recommend
constructing a 2x4 wall along exterior walls and a small room for the dust collection and air compressor,
insulating the exterior walls,
hang either drywall or plywood (Plywood is great for holding up cabinets etc.)
box in the duct work and use either soundproof drywall or noise cancelling channels (not sure what the exact name is for the channel.  The duct work being made of metal creates a nice path for noise to travel upstairs.  More than likely, there isn't enough room between drywall and duct work for insulation to be effective, imo.
The entry door into the basement may need to be a insulated door if it enters into the house as well as a weather strip.  Weather strip is to keep dust from entering the house as well as noise.  there are probably better alternatives.
run 20 amp outlets and dont forget to add some outlets in the ceiling for air filter and possible tools, especially over the workbench.
FYI -  Jay Bates has a nice miter station that creates plenty of storage while providing wings for the miter.
  Also, he has a video of someone's garage setup which helps condense the work area by placing the workbench, planer, jigsaw, dust collection etc. in negative areas to maximize the space.  Cant seem to find the video.
Jeff
Jeff
resides in NAINA
Offline HAXIT
« Reply #9 on: November 29, 2016, 06:32 AM »
Thanks for the ideas and suggestions guys very appreciated. I am working till late time so the week ends are the only time that I can be online. I will post the whole plan that I have in my head over the weekend. Here is more pictures from the current situation.
Offline HAXIT
« Reply #10 on: December 02, 2016, 02:15 PM »
Finally Friday! I took off today and Monday to finish some stuff before weather gets very cold. If you look at these two pictures, here is where the shop will be and as you can see the house is double which means two hot water tank and two furnaces siting right there.
The hot water tanks are not too bad but the furnaces are junk but still work. Any way I don not want them in the middle of the shop so they will be replaced.
I always wanted to go with tankless water heater and this is the great time and I am doing it today. I just came up stairs for a cup of tea break and over the weekend I am changing the two furnaces as well. Both the tankless water heater and the furnace are 98% high efficient and have two pipes that goes outside the wall one for vent and another one for combustion intake. Now because chimney is not required, I am moving the system to the other side of the basement, completely outside the shop area which will be here in this picture.
In this case, not only I open a huge space, but I am sure that it is safer and they take the fresh air from outside for combustion not from basement.
Offline HAXIT
« Reply #11 on: December 03, 2016, 01:11 AM »
The two hot water tanks are gone and replaced with two tankless ones.
And here the new glass block windows and clean up all the wires. All the wires in the basement are going in the conduit.
Offline Dubcraftee
« Reply #12 on: December 03, 2016, 03:14 AM »
Keep going! it looks great so far. You've created so much more space. And the symmetry in the pictures really rustles my jimmies!
Offline HAXIT
« Reply #13 on: December 03, 2016, 04:41 PM »
I am already happy for what has been done here. The two monster furnaces are replaced with two 98% 2 stage and variable speed  ECM maintenance free blower. The furnace is sealed and was designed for residential and commercial. For me and where I live, I really do not need the AC but if I want to I can add it any time. The stand in the picture is not include the furnace itself. I made the stand from 1" square tube and paint it same color as furnace. I bought these two units about three months ago when they were agree to give me a best deal on two. When they arrived, I measured everything that I would need and made these stands. There is a paint store near where I work so I opened the door on the furnace and took it with me to show it to them. They scanned the color and mixed the pant for me.
It is working great right now. I just have to finish the drain pipe.
Offline HAXIT
« Reply #14 on: December 04, 2016, 04:49 PM »
I have been down there in the basement since 6am in the morning and it is about 4pm now. I just did some painting and closed the opening on the duct where the old furnaces were located but mostly I was working on electric and running conduit. And here is the shop area which is 23' x 26' just about 600SF but I will have storage area under the stairs as well.
About the power:
The shop will have 5 120v 20amp and 3 220v 20amp separate breakers and all the wires will be in the conduit dropped dawn from ceiling excluding one wall as you can see it in the picture. I will talk about this more later.
The walls.
What you see in the picture below, is not paint or drylock. It is a material that called Surface Bonding Cement (SBC) which is alkali resistant,fiberglass reinforced and cement mixed based material. It is much better then drylock. It takes 30 days to cure completely and during this time you have to spray it with water and it will get harder and harder. It is not as easy as you see in the videos on line to apply this product on the wall. I did this a month ago so it is cured now but it took me a long time to do it. I had to do this first before hanging the tankless water heaters and screw the electric boxes and conduits to the wall. Only the shop area will be paint over it but the other half will stay as is.
Offline HAXIT
« Reply #15 on: December 08, 2016, 01:06 AM »
All the wiring and lights are done. Hopefully I will build the wall and put the door up over the weekend.
The shop will have 12 fluorescent fixtures. Each one will hold 4 4' T8 tubes.
Offline Kev
« Reply #16 on: December 08, 2016, 03:00 AM »
Am I alone in thinking this could be more shrine than workshop??  [big grin] [big grin] [big grin]
Offline HAXIT
« Reply #17 on: December 10, 2016, 01:41 AM »
 Today,the old stairs which was good for nothing came out and replaced with the new one which is more stable as well. Finished the wall and the door. As you can see in the picture, there will be some storage area under the stairs which is great. I have to cut that post and move it to the right for about 10" to open up my way.
Offline Tinker
« Reply #18 on: December 10, 2016, 02:26 PM »
@HAXIT have you checked the floor thickness at the location to whih you will move the post?  The appearance of the overall original construction looks like there is no problem.  However, whenever a row of posts  ar installed, there should be either a continuos footing or a footing under eack post.  I don't know how much weight is involved or even the thickness of the floor.  If i were doing the job, i would very definitely check before moving the post.  In previous pics, it appeas the beam is steel, but I am not certain. Checking is just an old habit.  A few years ago, i looked at a job that was going to support five fireplaces and a couple of support beams at two floors.  The first thing I noticed was there was a side wall that had been constructed because the builder had made a 8 foot error in placement of the wall.  The concrete floor had already been poured.  I told the builder I would not do an estimate until i had proof the chimney footing was in the right place.  After considerable argument, I walked away.  Ten years later the main part of the house was torn down. I never checked on why.  It was not in my town.  I just thought that maybe that chimney could  be the culprit and just maby it was creating a major problem starting at cellar floor level. >>> or below.
Tinker
Wayne H. Tinker
Offline Ironmantrev
« Reply #19 on: December 10, 2016, 03:29 PM »
Project is looking great. Everything is nice and clean and organized looking. I suspect you may have OCD as I do😀
Thought about what you are going to do with the floors? Polished and then possibly stained would look great and would be easy for cleanup. I'm thinking of doing this with my garage workshop (once I finally get it cleaned and organized). If you put in a big Festool logo maybe they will sponsor some of your renovation??? Yeah I know, probably wishful thinking, haha.
Following your progress.
Offline HAXIT
« Reply #20 on: December 10, 2016, 07:34 PM »
Tinker
Yes, I would never dare to do it before checking it with people that I can trust. I did this few years ago and even brought some of them here and showed them that what is going on but I never got the time to do it, now I have no choice and it has to be done. The beam is steel and thank for your concern.
Offline HAXIT
« Reply #21 on: December 10, 2016, 07:54 PM »
Thanks, the floor is going to be 100% solids epoxy and I will explain everything I do. This is not what people think or buy about epoxy flooring.
Offline HAXIT
« Reply #22 on: December 10, 2016, 10:56 PM »
Well, today I finished filling inside the wall and between the joists with Roxul safe n sound and boxed all the duct work.
Offline HAXIT
« Reply #23 on: December 11, 2016, 12:36 PM »
It Looks like every time I try to post 6 pictures same time I go over the limit and it does not work, so I stay on 5 in several posts.
Here is the last pic from yesterday work.
I tried everything they claimed about this Roxul safe n sound and it does it well. I filled in every openings including under the stairs. It comes in 3" thickness only but I double it up where ever it needed to cover everything up.
I am not a huge fun of what manufactures said about their product unless I try it myself and not effected by reading the reviews.
The result is already very impressive without having any type of drywall here! Yesterday, when I was almost finished but not completed, I opened the door to go upstairs for the short break and a cop of tea and I saw three people were standing behind the door and talking, I asked them when did they come down stairs and respond was 5 minutes ago. Not only I did not hear the footsteps but I could not hear the conversation too. Now they told me that they were thinking I was in the garage because it was quite up stairs.[eek]
I was listening to Iron Maiden all day, I think this Roxul already passed the test for me.[big grin] [thumbs up]
« Last Edit: December 11, 2016, 12:39 PM by HAXIT »
Offline RobBob
« Reply #24 on: December 11, 2016, 12:37 PM »
How did you attach the wood to the metal ductwork?
Offline HAXIT
« Reply #25 on: December 11, 2016, 12:45 PM »
I did not. They are only screwed to the joists and each other.
Offline HAXIT
« Reply #26 on: December 11, 2016, 01:22 PM »
The next step is to hang the soundproofing drywall and painting. I have no past experience about the soundproofing drywall and after a long time research I was going to order the quiet rock 530. At the last minute I met a contractor that had a lot of experience on this and he told me I better be buying soundbreak xp instead of quiet rock. And he mentioned that it is very important to leave a 1/4 inch gap between the wall and the floor where the drywall is about to be attached and fill the gap with OSI SC175 draft and acoustical sound sealant. OK, now I started to asking people I know again for this two products and nobody gave me a single negative answer and they encouraged me to go for it. What they did not tell me was none of them are easy to work with and most of the time they do not want to sell it to you if you do not have account with them or not willing to buy a whole skid. But I was able to get what I need by help and yes it is bloody expensive and not easy to use.
« Reply #27 on: December 11, 2016, 05:19 PM »
Habit,  have you slept any since the project started?  It seems like yesterday you got started.  Great work!
Hope you placed some plastic or something under the bottom plate of wall.
Jeff
resides in NAINA
Offline Dovetail65
« Reply #28 on: December 11, 2016, 05:26 PM »
I am using the 5/8" XP for the next layer of my entire shop, ceiling too and its fire rated Type X. I dont think the 1/2" XP is.  I think thats your basement, I might consider using the 5/8", at least on the ceiling.
My brother is telling me the Georgia Pacific is better and this Purple XP stuff is prone to very easy edge breakage.
This product cost a heck of a lot more money than regular drywall, I am hoping it works out for me.
« Last Edit: December 11, 2016, 05:33 PM by Dovetail65 »
Offline HAXIT
« Reply #29 on: December 11, 2016, 06:02 PM »
Forget about the sleep and help the hunger! It is unbelievable how fast the time goes by down there. Since I started, I have been on two meal a day keep forgetting the lunch.
The bottom plate and the three stringers for new stairs are pressure treated.
Offline HAXIT
« Reply #30 on: December 11, 2016, 06:17 PM »
Yes,it is the fire rated 5/8" xp that I am using. The few places that I called, they said they do not sell the 1/2" due to lack of customers. If this won't work, then I wasted a big money.
Offline HAXIT
« Reply #31 on: December 14, 2016, 01:18 AM »
Hi Folks,
The wall and ceiling is done. I have been working on this since Sunday. This is just primer and one coat of paint but I will put another coat all over the shop after grinding the floor is done.
Floor is next, Tomorrow, I am leaving at lunch time and I called the local hardware store to deliver the concrete grinder at 1pm for me. If nothing goes wrong, I think I will finish it about 5 hours. The floor is going to be 100% solid industrial epoxy and will be done in 4 steps. Another good news that I had today was, my two machines are finally here and will be deliver to me on Friday morning.
Offline Tinker
« Reply #32 on: December 14, 2016, 03:50 AM »
@HAXIT Don't forget to seal all duct openings and doorways.  The dust from grinding of concrete can permeaeevery room in the house.  Don't ask how I know.
Oh, what the heck, I can't resist.  I once ran into a delivery problem with a floor pour in cold weather. First load came right on time. first  delivery in morning from supplier.  second was supposed to arrive at 8:30 or 9 o'clock.  It finally arrived, after burning phone lines, at around 4pm and getting dark with temp plummeting into the twenties.  Needless to say, some serious repairs were required later on. I rented a grinder for a day during Christmas/New Year week while owner would be away on Ski trip.  I sealed all doorways into the main house and proceded to grind away. A dayor so after New Years Day, I got a call from the builder on the job to call the owners.
The owners happened to be a pair of Cranky Yankees from the  hills of Vermont.  I had really hit it off with them as they were he sort of people and humor that I had grown up with in he Berkshire hills of Massachusetts.  I liked them and he felig was reciprocal. I called as directed.  Isthmus they had jut gotten home about two hours earlier and from the ton of he man's voice and the ringing in my ears, I could sense a little, this is a story about a Cranky Yankee, remember!. That phone was exploding in my ear.
It seems they were greeted with a hin film of white dust over everything in the house. The dut had permeated to even between bed sheets and all closeted clothing. I offered to come over to help with the cleaning.
"Tinker!!!  If you show your face in this house, I'll kill you!!!!!"
We did end up as friends once again, but it was my good forune they were the sort of family who did not carry a grudge.  I did many more jobs for them.  when i retired from mason biz, i even took care of their yard for a few years until they moved away.
What had caused the dust problem? Even though i sealed all doorways, i had forgoten about closing off heating return duct covers.
I can immagine that with your attention to detail, you would not make a mitook like that, but just thought i'd remind you. ::)
Tinker
Wayne H. Tinker
Offline HAXIT
« Reply #33 on: December 16, 2016, 12:59 AM »
Tinker,
Your reminding is much appreciated.
Offline HAXIT
« Reply #34 on: December 16, 2016, 01:28 AM »
Even though, I was sure that my concrete floor had no moisture but again I did the test before order anything just to make sure.
I taped dawn a 2' x 3' plastic on the floor and opened it up after 24 hours. If you can see any concrete discoloration, moister or water dripping from the plastic, then epoxy flooring would not be a good idea but the test result was very promising.
Here is how the floor is looks like before.
Offline HAXIT
« Reply #35 on: December 16, 2016, 02:04 AM »
Step 1: Concrete prep
I know that the most popular and cheapest way is acid wash but I do not like the method. The concrete prep is the heart of this process and should not be undertaken if good flooring result is desired.
This is how I set it up to minimize the dust. I changed the regular filter in the shop vac and replace it with the universal concrete dust filter and put two fans in the front of the windows. I took this picture before covering the duct opening and electric panel but they will be closed. The duct opening will stay closed all the time till end of the project because I want to maintain the even temperature and humidity.
I finished grinding in 4 hours and vacuumed three times to make sure there is no dust left on the floor. Here how it is looks like now.
Offline HAXIT
« Reply #36 on: December 16, 2016, 02:17 AM »
Step 2: The floor is covered with epoxy primer and checking for desired  humidity and temperature.
Offline HAXIT
« Reply #37 on: December 16, 2016, 12:00 PM »
It is finally here.
Offline Tinker
« Reply #38 on: December 16, 2016, 12:14 PM »
I'm assuming that is a garage, and not that you tore everything apart.  [scared]
BTW Your floor, as everything else you have done, looks great. As long as the floor is not wet underneath the concrete, you should have no problem except possibly from condensation. If the subfloor is wet (it appears not to be) you can xpect condensation problems.
Tinker
Wayne H. Tinker
Offline RENO
« Reply #39 on: December 16, 2016, 04:55 PM »
Your workshop is gonna look great Haxit  !!
OF900-TF900-PS2-TS55-DR7,2-DX93E-RO90DX-CS50-KAPEX120-basis1&expansion-and some more non Festool stuf to work my way in woodworking
Offline HAXIT
« Reply #40 on: December 17, 2016, 05:52 AM »
Tinker
Yes, it is the garage or more correctly the old shop in the past, transit for new tools at the time and welding shop in the future.
Isn't garage was made to park the car? Not when I own it. [big grin]
Offline HAXIT
« Reply #41 on: December 17, 2016, 05:54 AM »
Thanks and let's hope so. [wink]
Offline HAXIT
« Reply #42 on: December 17, 2016, 06:26 AM »
Step 3&4 and the result.
After primer the base coat went on the top then I had to broadcast the color chips and after 12 hours put the top coat on.
So, the floor is three layer and the color that I chose was mid gray with three colors white,black and neon green chips.
Here is the close up pic.
And the result.
Offline Tinker
« Reply #43 on: December 17, 2016, 06:55 AM »
@HAXIT My first thought was "Ah ha, He wants to hide the dust"  And then i realized who was doing the job and for whom. After looking/reviewing all of your progress, I can't imagine any spec of dust hanging around for any measurable time on that floor. [blink]
All kidding aside, I really like that idea for your floor. It looks great. Can't wait to see all of your toys in there.
Tinker
Wayne H. Tinker
Offline Poindexter
« Reply #44 on: December 17, 2016, 06:40 PM »
This is my favorite thread on this board!
Offline Kev
« Reply #45 on: December 17, 2016, 11:30 PM »
It is finally here.
(Attachment Link)
@HAXIT
Happy days [smile]
Hopefully that'll be me soon ... just made an offer on a property (fingers and toes are crossed) with a newish 3 and a half bay workshop that I'd line and floor seal. Though I'm likely to be less detailed than you [embarassed]
Are you just filtering the air or are you going to A/C the space?
Offline HAXIT
« Reply #46 on: December 18, 2016, 08:34 AM »
It is finally here.
(Attachment Link)
@HAXIT
Happy days [smile]
Thanks Kev, I wish the best of luck for you for the property. Without having the space we are almost paralyzed.
I will just filtering the air.
Offline HAXIT
« Reply #47 on: December 18, 2016, 08:54 AM »
The room is almost done and the floor needs to be cure from 10 to 14 days before any heavy machines move in but light foot traffic is ok. Next week is Christmas and new year which both arrive on weekends and after that I will move in and do the shop tour. I would say in 3 weeks I will be up and running the shop. Thanks everyone for comments and following this post.
Offline Tinker
« Reply #48 on: December 18, 2016, 09:15 AM »
The only experience I ever had with Epoxy on a concrete floor I had to allow  NO TIME for curing.  The floor was full of cracks, holes and spalts from being  used as a dairy.  The floor  had to be steam cleaned every day.  The dairy was bringing in milk from local farmers before  8 am every day, processed, bottled and shipped out befor  noon every day. We had to wait until the steam cleaning was completed by around 4pm before we could start doing anything.  We were using a type of epoxy that we mixed with sand base and would  be cured within an hour or so.  i had three helpers who did the mixing and feeding the lone mechanic (me) who was working on hands and knees all night.  Someimes i was lying on my belly and stretching out under tanks and machinery.  By the time we finished, i was like half drunk.  The floor was no longer full of holes and spalting, but there were  a ton of tooling ridges.  the owner was happy even tho i was not.  I don't know why he had us do the floor, as he closed the business within a very few months.  I think the job was a necessity to satisfy milk inspectors so he could finish his obligations until the property could be sold.  I vowed to never do another epoxy floor again.  From what i am seeing of your floor, and from others, there have been big improvements in the overall process.
Tinker
Wayne H. Tinker
Offline Peter Halle
  • Another Avatar Coming Soon
« Reply #49 on: December 18, 2016, 09:31 AM »
@HAXIT
Congratulations on the amazing workspace metamorphosis!  The results you have shown in such a short period of time is amazing.
I will offer one tiny piece of advice.  Once you start woodworking and there will be some sawdust on the floor, do not make sudden movements or turns.  The epoxy floors can get very slick with the sawdust acting as cornmeal on a pizza peel.  I learned the hard way - OUCH!
I can't wait to see more of your shop as it continues.
Offline HAXIT
« Reply #50 on: December 18, 2016, 09:16 PM »
Tinker
If this story is more then three years ago, then you are right it has been a huge improvements since then. Of course type of epoxy used has a big impact as well. One of the main reasons in these days is the easy care and long lasting that some people prefer  epoxy flooring. Only time will tell how good this floor would stay the way it is now.
Offline HAXIT
« Reply #51 on: December 18, 2016, 09:18 PM »
@HAXIT
Thanks Peter, I will remember your advice.
Offline Tinker
« Reply #52 on: December 19, 2016, 04:06 AM »
Tinker
The dairy closed in the early 1970's.
Tinker
Wayne H. Tinker
Offline HAXIT
« Reply #53 on: December 26, 2016, 01:08 PM »
Hi Folks
The room is done and getting ready to move in. [thumbs up] [thumbs up] [thumbs up]
It is hard to believe it but no pain no gain seems like is true. Here is the last pics from the cured floor. It just got hard like rock and it is so shiny that you can count the florescent tubes on the floor. [scared]
I got my both hands up and must admit that I am not even close to a professional floor installer, I just learned my lesson from people's mistakes. I am not even a woodworker, I am a welder. [big grin] [big grin] [big grin]
The past pics from the room, the walls (excluding the one that I made) were not painted yet. The whole shop is painted with ultra pure white eggshell enamel now.I bought two rechargeable 10 pound ABC fire extinguisher and installed them on the wall. One at the end of the shop and one near the door.I hope that I would never need to use them, but you got to have them.
Here is the last pic of the completed and finished empty room with door frame and fire extinguishers on the wall.
Offline RobBob
« Reply #54 on: December 26, 2016, 01:12 PM »
Wow, that is an incredible transformation.
Offline HAXIT
« Reply #55 on: December 26, 2016, 01:21 PM »
I forgot!
Tomorrow morning, the security company will be here to update my security system at house and give me the wireless remote and add the shop and the garage to the system as well. So the door will have security and Thursday morning the movers will be here to take the larger machines down and I will do the rest.
Offline HAXIT
« Reply #56 on: December 27, 2016, 01:53 PM »
Well, the security is updated and I just had my first false alarm experience. [bite tongue]
After the security installer left the house, I armed the system then left the house to eat something. When I came back I did not want to go upstairs but I went to garage to move some tools down stairs and I completely forgot that garage door and the shop has security now since 2 hours ago. [sad]
I came down stairs and I left my phone in the car and security company is trying to contact me but they cannot reach me. First the siren went off and the noise traveled almost to end of my street. I already know what I did, now the police showed up at the front of my door and my home phone is ringing same time again the security company trying to reach me.
Conclusion:
The system works great. [big grin]
If it happen again,I might pay $500 fine. [scared]
Offline Tinker
« Reply #57 on: December 28, 2016, 08:08 AM »
Conclusion:
I'm glad somebody else has those problems  [unsure]
One time  we left our security system on while we took a trip to Germany.  We  came back to house and had forgotten how to disarm the system.  Ten minutes later the police AND fire department showed up.
Tinker
Wayne H. Tinker
Offline HAXIT
« Reply #58 on: December 29, 2016, 07:19 PM »
Ladies if any and gentlemen, welcome to my workshop. About 80% is done and the 20% is all about making some storage area and clamp rack and etc...
The Hammer A3 31 is right front the door and is set up to cut anything up to 10' or I can open the door and move the machine to right and go up to 18'. At the end you can see the cms-ge set next to the drill press. Again from wall to the cutting point is 7' and can be change quickly to 9' if I have to.
Drill press is my beloved Swedish made Solberga. No belt and no maintenance, it is a gear head drill press. The top mounted motor is dust and water proof. 2 horse power with 8 speed setting which is done with two handles at the left side. The choices are 130-260-420-535-840-1070-1745-3480.Both the drill head and the table arm are adjustable 360 degree around the column and can be raised and lowered.
Tormek  T8 water cooled sharpening system with the complete jigs and accessory,rotating base and ts 740 station.
No detail on this one but I love it and it won't stay at the corner always.
The whole wall is covered with festool accessories. The Kapex is in the perfect location, from the end of the wall under the stairs to kapex blade is 18' so for long lumber there is no problem here. Ignore the wires that hanging. It is for the project in the future.
Offline Richard/RMW
« Reply #59 on: December 29, 2016, 07:25 PM »
Oh for goodness sake would you just toss a couple handfuls of sawdust somewhere around there??? Looks like a darned operating room!
Seriously thought, incredible project in what must be record time. I'd still be moving the washing machines.
Enjoy the new shop.
RMW
Offline neilc
« Reply #60 on: December 29, 2016, 07:36 PM »
Fantastic!  Great space with wonderful lighting and layout.  I'm sure you will love doing work there and no doubt, your work will be raised due to the inspiration of the space.
Thanks for sharing!
Offline RobBob
« Reply #61 on: December 29, 2016, 07:46 PM »
@HAXIT   Where did you get the slat wall for hanging the Festool accessories?
Offline HAXIT
« Reply #62 on: December 29, 2016, 08:14 PM »
Here is a close up pic from that slatwall. You can not see it from faraway, it is not plastic or MDF. It is interlocking aluminum with green pvc strips inserted to cover the screws.
Here is the Hammer n4400 band saw wich is connected to Laguna dust collector and when I need it, I just roll it for A3 31. This dust collecter is just for this two machines. At the center I have my TS 75 and the ct sys on sys-roll so I can quickly grab it and go to garage just to cut the sheet good to bring them down here.
It was a large open area in the first picture and I moved what was there just to show how much space I can have if I want to but I have two Felder FAT 300 lifting tables that goes there.
The next picture shows one at lowest 400mm and one at highest 1030mm and can be set at any point between by using the hydraulic lift. The tabe top is glue, solvent and scratch resistant and is almost same size as MFT3 just 20mm wider and 100mm longer.
Offline HAXIT
« Reply #63 on: December 29, 2016, 08:47 PM »
Here is some usage of the lifting tables. I put one at each end of MFT3 which helps to support a very long lumber and for some projects the vac sys is a bit high for me, so I just remove it from plate and drop them on lifting table. Oh life gets much easier.
Here is the example.
Setup for joining.
setup for thickness.
And finally just two pics from corners for whole shop.
Offline duc996
« Reply #64 on: December 29, 2016, 09:12 PM »
That is a beautiful shop! Awesome setup!
Offline HAXIT
« Reply #65 on: December 29, 2016, 09:29 PM »
Finally something about lights and use it in the efficient way.
When I started this project, I know the layout in my head and wired the lights half and half. If you take a marker and put a line in the middle of the chimney to the front and the end wall, you would split the shop in half. There are 12 florescent fixtures in the shop and each one holds 4 T8 4' tube. So each side of the shop has 6 fixtures which has separate breaker and switch.I can turn the half shop off to be more efficient and still get great lighting with no shadows.
For example, If I work on the festool side, I can turn the lights off on the other half or opposite. I just took two pictures by standing at the end of chimney.
Work on the festool side.
work on the Hammer side.
Thanks everyone for following this thread and I hope I could be useful for others and feel free to leave you comments or questions.
Offline HAXIT
« Reply #66 on: December 29, 2016, 09:36 PM »
Let me find the receipt, I will post it soon I do not remember the web site but I have it.
Offline HAXIT
« Reply #67 on: December 29, 2016, 09:42 PM »
Thanks folks for the good words and comments.
Offline HAXIT
« Reply #68 on: December 29, 2016, 10:13 PM »
http://www.megawall.com/
Offline Don T
  • Phoenix, Az
« Reply #69 on: December 29, 2016, 10:33 PM »
Awesome shop you have.  That is definitely a dream shop..
Offline Rhino1789
« Reply #70 on: December 29, 2016, 10:37 PM »
WOW!!
Offline ScotF
« Reply #71 on: December 30, 2016, 12:37 AM »
Amazing workspace....thanks for the share!  I would love to hear more on the Felder tables - I have seen them and they look very versatile. Not cheap, but useful nonetheless. I have thought about buying one for exactly the same purpose.
Offline HMR
« Reply #72 on: December 30, 2016, 01:25 AM »
Great job!  Thanks for sharing.
Offline vuongnuce
« Reply #73 on: December 30, 2016, 01:38 AM »
like hotel than a workshop  [thumbs up]
Bosch GST135 BCE, Festool TS55, Domino DF500, ETS 150/3, 150/5, RTS 400EQ, Rotex 150, Festool CMS, CTL Midi
Offline HAXIT
« Reply #74 on: December 30, 2016, 01:51 AM »
Thanks, I did not buy both of them at the same time. I bought the first one 9 months ago and when it arrived it was build much better then what I was thinking. It is 250 bound and holds up to 600 pound and all 4 rollers get locks. I was moving it under the MFT3 and every cut I was making I could put it on the top and keep the MFT3 ready for another cut. I started moving much faster and easier I ended up to buy another one 3 months ago and I am glad I did. Unless you pick it up,this is heavy and comes on skid so it is not a ups or fedex item and shipping cost approximately $250 depends on where you live.Let me know if you need any more info.
Offline HAXIT
« Reply #75 on: December 30, 2016, 01:56 AM »
One more time if I missed anyone, thank you very much for the words and comments. [smile]
Offline Ironmantrev
« Reply #76 on: December 30, 2016, 02:11 AM »
Well done. Shop looks great. Enjoy it now after all your hard work.
Which megawall profile did you use?
Did megawall provide the green screw cover or was that your custom touch?
Will any standard slat wall hooks, etc work, or do you need special ones?
I've been leaning towards some type of metal peg board vs slatwall, but this looks great and will be much better than any plastic/mdf variant I've only seen up,until now. This is a great find.
Thanks for sharing the project from beginning to end with all the little details. Now go break in all that new equipment.
Offline VW MICK
« Reply #77 on: December 30, 2016, 02:34 AM »
@HAXIT
This is an amazing workshop. I have been following this avidly. My favourite thread in a long time
Those photos would have been at least 18 months apart if it was me
You must have another area for all your crap
You have inspired me. I'm going to try and get my workshop floor painted in the next couple of days
And again amazing
Mick
Offline Tinker
« Reply #78 on: December 30, 2016, 04:32 AM »
This has been an amazing  project in just the time it took.  There is just one thing you have not shown. Your scrub area for when you are about to perform surgery.
I love the clock.  Do you pour water on those tiny tools to make them useful and then shink them when finished?
All kidding aside, your planning and vision have been great. You have a terrific work space.
Tinker
Wayne H. Tinker
Offline Poindexter
« Reply #79 on: December 30, 2016, 07:17 AM »
Wow wow wow!  So many things I'm drooling over.  But I'm imagining the handiness of those Felder tables to be almost invaluable.
Offline HAXIT
« Reply #80 on: December 30, 2016, 07:23 AM »
Thanks for the comments, much appreciated.The megawall profile that I used called 1 3/8" flat back A138-1s-96.
They only sell the tracks, for green screw cover and hooks look here.
https://www.storesupply.com/vinyl-slatwall-insert-green-45239.aspx
The standard hooks work on this one which I mixed match to get what I needed but I am not sure if they would work with other tracks that they have.
Offline HAXIT
« Reply #81 on: December 30, 2016, 07:29 AM »
@HAXIT
And again amazing
Mick
Thanks and good luck with floor. [smile]
Offline HAXIT
« Reply #82 on: December 30, 2016, 07:34 AM »
Thanks, I always work alone and these two tables act like an employee.
Offline HAXIT
« Reply #83 on: December 30, 2016, 07:46 AM »
Tinker
Thanks Tinker and much appreciated. The clock was my idea, I designed and there is a website that they made it for me. It is made out of 1/4" acrylic.
Offline sheperd80
« Reply #84 on: December 30, 2016, 08:22 AM »
Nice laboratory haxit. Looks great
Sent from my SAMSUNG-SM-G890A using Tapatalk
Offline egmiii
« Reply #85 on: December 30, 2016, 09:45 AM »
This is quite possibly the nicest shop transformation I have ever seen, never mind the fact you did it in just over a month. I'm also going through the process of building a shop in my basement, so I can appreciate the sheer amount of time you've invested thinking this through and getting it done. I have a feeling there are tons of little details you agonized over, but will never be noticed by the casual observer since they seem obvious now. Laying out each machine to have proper in/out feed areas, especially around all of the obstructions is a brain twister in itself.
Kudos to a job well done. You have truly inspired me and likely many others on this forum.
Mind if I ask where you are located?
Offline Duck76
« Reply #86 on: December 30, 2016, 10:26 AM »
Your build is inspirational...both in looks and speed of execution. All of your equipment choices (A3-31, N4400, CMS...) have been on my wish list for a while. Seeing them all together in one space increases the want.
Well done! [cool]
Offline Billedis
« Reply #87 on: December 30, 2016, 11:54 AM »
That is a piece of art.  Thank you so much for sharing.  Bill
Offline mike_aa
« Reply #88 on: December 30, 2016, 12:25 PM »
@HAXIT
This is one of the threads that I know I will refer back to from time to time for all the great ideas you've presented.
Your build is truly amazing and it's astonishing how quickly you completed it!  I only wish I could have half your energy. LOL
One question - What's the main ceiling height?  It looks low and I wondered how that affected some of your decisions.
Thanks, Mike A.
Offline Motown
« Reply #89 on: December 30, 2016, 02:27 PM »
Wow. This is one of my favorite posts, very excited for you Haxit.
I had a few questions about your epoxy floor. I have just re-did my garage/shop and want to do an epoxy floor in 2017 so I was hoping you could provide some insight with a couple of things:
- Looks like you did the grinding and finish yourself. Can you provide some feedback on the difficulty/skill set needed to achieve that finish? I've redone hardwood floors but never concrete.....I am thinking "it's my garage/shop, so why not give it a shot".
- What brand of epoxy did you use?
Thanks in advance and congrats on a beautiful work space. Can't wait to see future project posts.
Offline HAXIT
« Reply #90 on: December 30, 2016, 05:59 PM »
@HAXIT
Thanks, Mike A.
Thank you very much for great comments and yes the ceiling height is not the best here but not too bad compare to the some very low ones. The open areas now after hanging the drywall is few inches under 8' and other areas where there is duct work is  10" shorter but it did not effect any of my decisions. The worst would be the band saw but it fits nice without any problem.
Offline HAXIT
« Reply #91 on: December 30, 2016, 06:01 PM »
Thanks for the comments and I will send you a PM. [smile]
Offline HAXIT
« Reply #92 on: December 30, 2016, 06:21 PM »
Thanks and yes I did the whole floor myself and it has nothing to do with hardwood flooring. Some processes are rather critical then difficult.You can buy everything you need to finish the job here.
 http://www.originalcolorchips.com/
I have no problem to share and help anytime you ready to start. Go to this web site and read some of the processes and watch the clips as well and see if you are comfortable to do it yourself. This is where I really wish that I could get some help because having a very short pot life make it much harder to work alone.
Offline RKA
« Reply #93 on: December 30, 2016, 06:30 PM »
Very nice transformation!  I love those tables, very handy and versatile.  Question, how did the movers get the planer down there?  Any issues with the table alignment after they finished?  How did you find movers that would handle small machinery in residential settings?  I've got a saw and J/P sitting in my garage.  When the warm weather returns I need to rebuild the basement stairs, then I need to find someone to get them downstairs.  And of course this entire thread had polluted my brain with more ideas that hurt the wallet and timeline.
Great job, enjoy the new shop!
-Raj
Offline HAXIT
« Reply #94 on: December 30, 2016, 06:37 PM »
Once again,thank you very much everyone for comments and feedback.
I kind of getting embarrass if I really deserve all these great comments from you guys. [embarassed]
Offline HAXIT
« Reply #95 on: December 30, 2016, 06:55 PM »
Thanks and I am glad to see that my ideas can be used by others in the future. [smile]
No issues with table alignment at all. They were 4 people with small industrial moving experience. I called many places for this but I was keep getting  answers like no we do not do it or they did not bother to call back till I found these guys. They had some kinds of moving cart that I have never seen before. They came in went in the garage and just look for few min and chat then all three machines were down in the basement less then half hour safely. I was very happy about this and tip them for lunch.
Offline duburban
« Reply #96 on: December 30, 2016, 08:30 PM »
These low budget shops are so boring...
helper: i used a festool "circular saw" to do something simple and it made it really hard
me: exactly, it makes simple cuts complicated and complicated cuts simple
Offline alkaline
« Reply #97 on: December 31, 2016, 05:35 AM »
@HAXIT
That work with the floor is amazing, so I'm not surprised a great sequel. Great look. Congratulation for workshop and wish the happy new year for you.
I have several boxes Festool, one MTF, four guide rails and big taste to play. )))
Offline HAXIT
« Reply #98 on: December 31, 2016, 10:31 AM »
@HAXIT
Thank you very much and you are a fantastic maker as well. Happy new year and wishing the best for you my friend.
« Reply #99 on: December 31, 2016, 10:53 AM »
One of the best organized shops that I've seen.
Where's the dust?  I think if you told us that the shop was self-cleaning, we would probably believe you!
Seriously, if I did a shop that looked like that, I'd think twice before I started my first project because it would never look that pristine again.  I hope that you enjoy making dust there for many years to come (and of course, capturing as much of it as possible with your dust collection system before it hits the floor).
Offline Picktool
« Reply #100 on: December 31, 2016, 11:01 AM »
Ok @HAXIT,
where you located? I'd like to bring some sawdust for goodluck.
You like those FAT tables? Best purchase I made. I got rid of
my MFT/3. No more lifting & setting up that beast. You have
the room for it though.
The Festool wall is beginning to look like a store setup.
Great inspiration and it looks incredible for the amount
work put into it.
So when will the Kappa 550 be coming in?
Ok then, have a safe Happy New Years & prosper well
with the new shop!
Well Dogey
Offline Boone32
« Reply #101 on: December 31, 2016, 12:21 PM »
Awesome! You've done a great job with the shop. Love following along!
Offline HAXIT
« Reply #102 on: December 31, 2016, 10:37 PM »
Thanks again folks and happy new year to all.
Offline HAXIT
« Reply #103 on: January 07, 2017, 06:40 PM »
Hi Folks,
It has been great since I got everything the way I wanted and I am spending more time here then upstairs.
If this is not the craziest, then one of the craziest projects on the planet that I just finished as a first project in the shop. The way I am and grown up, I must say that I hate waste even if I did not pay for and the question always is why if I could use it?
When my hammer machines arrived, they were packed great and I have a lot of scrap left that I did not want to throw away and I had the steps from the old stairs that was just screwed to 2x4 which came out easy without braking them. So I ended up to this project which is useful now because I have no table in the garage anyway.
This project is completed entirely from scraps left over and I just build it as I was thinking. Here we go:
The 50 years old stairs
The hammer shipping skid
And the result
So the table top is made out of the old stairs and finished with festool heavy duty oil and the table itself is the scrap skid. The stain on the table was the left over from a project that I had 3 years ago. The 120v 20amp outlet is the last one left from the shop wiring and the cover came from old bathroom, cable is left over from the spool I bought to wire the machines and the plug is from old tablesaw, wall mount towel dispenser came free with the big box shop towel that I ordered long time ago. The both sides of the table are slatwall to hang tools and was finished with festool heavy duty oil and everything is put together with domino.
Offline HAXIT
« Reply #104 on: January 07, 2017, 06:53 PM »
More pic from table.
Offline Tinker
« Reply #105 on: January 08, 2017, 05:43 AM »
How long did it take for you to build that table? 5 or 10 minutes?
Tinker
Wayne H. Tinker
Offline HAXIT
« Reply #106 on: January 08, 2017, 10:48 AM »
Tinker
I have to say no because I have no choice! If I say yes, then somebody from wood magazines will be knocking on my door for interview. [big grin] [big grin] [big grin]
Offline mcooley
« Reply #107 on: January 08, 2017, 10:59 AM »
I have the same limited ceiling height and I find it pretty discouraging. It helps having such a clean clinical space to work in though. I am grateful to be starting work on a new ground floor shop with an apartment above which will give me enough workable height downstairs. I've always been in small workshops and found I was never able to get those spaces under such severe control as the images above. More room definitely helps. But organization is obviously not size contingent. Big shops as well as little shops get cluttered. Kudos to you if you can maintain such an efficient space.
Offline HAXIT
« Reply #108 on: January 08, 2017, 11:27 AM »
Thanks, We have to think how to use the space we have in the best way regardless of the size and be happy and productive. [smile]
Offline Tinker
« Reply #109 on: January 08, 2017, 08:25 PM »
Tinker
No matter, you have done a great job on the renovation AND making fine use of the space AND a great use of leftovers and what otherwise might have been thrown away or burned.
Tinker
Wayne H. Tinker
Offline Mismarked
« Reply #110 on: January 09, 2017, 02:50 PM »
Not sure how I missed this thread until this morning, but the transformation and results are absolutely stunning.  A real inspiration.
Offline HAXIT
« Reply #111 on: March 19, 2017, 02:31 PM »
Folks,
Just wanted to update what is going on now before this thread gets too old. I still have to make some storage area for the hand tools finishing and measuring stuff I have which I would post it here, but I am not able to finish it yet. Most of them are  involve some machining aluminum and welding and if it was up to me, It was done now. I cannot do this in my shop because my boss told me that you do not like small project and every time you start something nobody does his job but they want to watch you. The machine shop that has to do it for me is very busy now and I have no choice but to wait till next month.
Offline curiousdork
  • I code and woodwork.
« Reply #112 on: March 21, 2017, 11:47 AM »
I just saw this thread.  I gotta say, beautiful shop.  So cool to see Hammer and Festool stuff on the wall.  That's a lot of woodworking bling right there.   [eek]
I'm in the process of rebuilding my 1 stall garage.  It's too small for my Ford F150 and old enough to be a grandparent if it were a person.  Since I'm rebuilding I might as well expand it slightly to have some woodworking space.  I would love to have a shop like that some day.  Maybe when that one app I write or that long-lost rich uncle somehow pushes money in my direction, I'm stuck with my TS75 and handtools for woodworking.  At the very least my neighbors won't hate me for having too loud of a machine.
Offline HAXIT
« Reply #113 on: April 15, 2017, 08:49 PM »
I had a good news from machine shop that I would able to use it very soon. The first thing that I have to make is the table for drill press and then move on. This is the prototype and the white paint was the left over from bathroom paint but will be made completely from aluminum then glassblowing and anodizing. This is the close up picture of the table and as you can see I am using the festool quick clamp on the back fence with the stop flag that comes with mft/3. The back fence moves across the table and can be locked on the back quickly with small adjustable handles. The bessey  auto adjust toggle clamps are mounted on the block and easily can be move or remove completely without any tool. I will add more stuff with pics to this when I start with aluminum. I have 4" square hole in the center and always can be filled with wood if it has to.
At each end I add the rails from hammer so I can use their table extension on each end. Not only it gives me the total of 6 feet table for drill press, it also can be used for extra outfeed table for cms without moving anything around. I already tried out and it works fantastic.
Then the dust control which will be fully adjustable and would work with both, the 35mm and 50mm hoese. More on this wit pics later.
Offline Poindexter
« Reply #114 on: April 16, 2017, 06:19 AM »
Where's the Like button? :)
Offline rvieceli
« Reply #115 on: April 16, 2017, 07:57 AM »
@HAXIT very nice as usual.
For the table consider Alcoa MIC6 cast aluminum plate. Manufactured to tight tolerances and very flat. comes in 1/4 to 4 inch thicknesses. easy to machine. Readily available.
http://www.arconic.com/aap/europe/en/product.asp?parent_cat_id=1847&cat_id=1847&prod_id=619
I have found that for most operations I prefer a lower fence. So i use another piece of mic6 that I had machined straight and flat on the edge. I installed a t track about 1-2 mm off the edge to use with a stop. When I'm doing something that needs a higher fence like a work piece on edge operation, I use the Woodpecker's fence. You can use it with regular clamps to hold the piece.
http://www.woodpeck.com/dp3.html
Consider dropping a couple of threaded holes in the area directly between the quill and the front edge of the table to be able to use a stop to keep the work piece tight against the fence. Doesn't have to be a t track, just put a slot in the long dimension of the stop for adjustment.
Ron
Offline HAXIT
« Reply #116 on: April 16, 2017, 08:41 AM »
@rvieceli
Thanks, I was thinking about cast as well so I am going to try the MIC6. I just sent an e-mail for supplier that I have been dealing with for over 15 years and he will get back to me tomorrow.
Offline HAXIT
« Reply #117 on: April 16, 2017, 09:57 AM »
I do like the hammer n4400 a lot and I would not ask for more for a long time at least to be said but not too happy about the dust port. I know felder and other machines have two ports but again they located too far from cutting  point. I just changed my setup and add the 2 port myself. I could not sleep last night so I thought about this and did it this morning. I have to tell you that I would not ask more and it works great! Again prototype but will be fixed.
Offline HAXIT
« Reply #118 on: July 30, 2017, 04:12 PM »
Greeting [big grin]
It has been a very busy year for me and I just came back from Vancouver.
Before anything, I would like to thanks to rvieceli for recommendation on mic6. The T6061 is a stronger material and get nicely anodized but considering flatness and machining and available at any time from my supplier, the mic6 was the material of choice.
Here is the pic from everything I need and has been waiting for me to come back. I am doing some drilling and taping and get it finished and put it together.
Offline HAXIT
« Reply #119 on: August 12, 2017, 09:31 PM »
Finally the forever wanted project is over. I took all the parts from anodizing shop yesterday and was able to put them together this afternoon. As I wrote about this before, I am not going to repeat everything again but feel free to ask anything that I might have missed. The table is mic 6 and the rest are 6061 aluminum. The black square blocks are to connect the bessey toggle clamps on the top and move them quickly and luck them dawn. There are three sizes of thickness, 3/8 1 and 2 inches. I can use one or two or all together to have a capacity of clamping dawn up to 5" thick material. In one picture you can see that I have the 1" at left and all together at right and you also might see that one block is hanging from the drill press cast table at the front. Each block has a magnet at the bottom that let me store them around the drill press's cast iron table so I do not have to look for them when I need them.
Everything get changed within one minute without any tool.
Here are the pics.
Offline HAXIT
« Reply #120 on: August 12, 2017, 10:12 PM »
I also made this out of aluminum to add the second dust port for the hammer band saw.
It is a aluminum tube with tapper hole inside welded to a 3/8 plate and 6 small magnets at the face to keep it on the side of the machine safely.
The dust nozzle was made out of 2.5 x 6 inches round stock 6061 and is fully adjustable. The height of the nozzle can be change from 5" to 20" by moving the stainless steel plates and adjustable handles. It also gets connected to 27mm hose inside and 36mm outside. Here the pics
Offline HAXIT
« Reply #121 on: August 12, 2017, 10:32 PM »
How about test drive. [big grin]
Here is 35mm hole in 35mm or maybe 40 material without dust collector.
and with 27mm dust collector attached. Scary nice and very satisfied.
Offline HAXIT
« Reply #122 on: August 12, 2017, 10:41 PM »
Now back to woodworking. [thumbs up]
Got some poplar and soft maple. Making the mobile clamp storage.
Offline Poindexter
« Reply #123 on: August 13, 2017, 08:20 AM »
I'm still enjoying this thread.
Offline Bob D.
« Reply #124 on: August 13, 2017, 08:40 AM »
Beautiful setup and nice to have all the additional support and also to be able to utilize it with adjacent tools like your CMS.
Question about your drill press.
It looks like you can raise/lower the height of the head on the column as well as the table like most drill presses.
Offline HAXIT
« Reply #125 on: August 13, 2017, 10:02 AM »
Thanks and I am glad that you like the thread.
Offline HAXIT
« Reply #126 on: August 13, 2017, 10:11 AM »
Thanks for the comment and yes you can raise/lower both the head and the table and they both turn 360 degree around the column.
Offline HAXIT
« Reply #127 on: August 13, 2017, 10:26 AM »
Milling dawn the lumber for mobile clamp rack.
« Reply #128 on: August 13, 2017, 10:34 AM »
Some really nice ideas for dust collection.  Looking forward to the clamp rack.
Offline HAXIT
Re: New workshop build
« Reply #129 on: August 13, 2017, 12:30 PM »
Thanks, I have to paint it as well, so I think it will be done in two weeks.
Offline kelauben
« Reply #130 on: August 14, 2017, 04:29 PM »
I'm looking forward to these updates more than GoT episodes!   [tongue]
Where do I look to order the MegaWall slats?
Thanks.
Karl
Offline HAXIT
« Reply #131 on: August 16, 2017, 12:47 AM »
Thanks.
Karl
I thought I did post it here before but here is.
Offline HAXIT
« Reply #132 on: August 16, 2017, 12:55 AM »
Boards are made and I will start put them together.
Offline HAXIT
« Reply #133 on: August 19, 2017, 12:03 PM »
Well, It is done.
It is made with domino, only 24 #12 screws were used for casters. This is just dry fit to make sure it fits nice and then I have to sand and paint. Oh and some hardware for both sides slot wall.
Now I opened everything to sand and finish.
Offline digger
« Reply #134 on: August 19, 2017, 03:42 PM »
That's one beautiful clamp rack. Can't wait to see it finished and full of clamps. Your workshop is awesome.
Offline Svar
« Reply #135 on: August 19, 2017, 03:58 PM »
This is what puzzles me. You made this rack and your shop still looks like surgery room. Where is the dust and random junk?
Great job.
Offline HAXIT
« Reply #136 on: August 20, 2017, 08:42 AM »
Thanks, painting goes slow because of the steps and sanding between the coats but I think will be done by next Sunday.
Offline HAXIT
« Reply #137 on: August 20, 2017, 08:47 AM »
Great job.
I promised myself to keep it this way but do not count on it. [big grin]
Junk usually gets clean up right after work and move to garage and sit there till garbage day.
Offline Redart
« Reply #138 on: August 21, 2017, 05:04 PM »
Very nice workshop, impressive !!
Festool: CTL midi. RO 150 FEQ
Mafell: MT 55 CC, DD40 G, LO 50 E.
Nilfisk Alto attix 30 ... Makita, Bosch ,Fein and Lamello tools.
Offline HAXIT
« Reply #139 on: August 26, 2017, 01:19 PM »
OK folks, the clamp rack is done.
You might ask for the dimensions or how much space does it takes to park the rack?
Not much but will hold a lot of clamps and accessories. It takes a space just like you put three sys-port next to each outer with sortainer on the top. Look at the picture below.
Thanks for watching and the comments, I will load it up with clamps after breakfast and post some pics.
Offline HAXIT
« Reply #140 on: August 26, 2017, 02:51 PM »
It holds up to 40 bessey k body on both sides from 12" to 40" which I have 8 of each. I also have the 50" and 60" which will be stored under the stairs. The rest of the clamps and accessories are on both sides. The green blades or however you want to call it, is used as a handle to move the rack around easily.
Offline digger
« Reply #141 on: August 26, 2017, 04:21 PM »
That is one beautiful clamp rack. Great job !
Offline Vondawg
« Reply #142 on: August 26, 2017, 05:22 PM »
looks like a candy store display for us tool/shop addicts....very tastfull and sharp! thanks for sharing the build
Offline HAXIT
« Reply #143 on: August 26, 2017, 08:53 PM »
Thanks for the comments everyone.
I have to make 6 storage area here to finish the shop, not buying any tools or changing any ideas that I had at the beginning of the building this workshop just finishing what I had in mind.
I think I will work on storage area for all measuring, marking and scale tools next. I have to visit the garage tomorrow morning to see what lumber I have left.
Offline OXCanada
« Reply #144 on: August 26, 2017, 11:09 PM »
Nice job! That is fantastic.
It looks like you have some kliklamps on the side. What mount did you go with to hold them?
I am looking for a solution similar to what you did.
Offline HAXIT
« Reply #145 on: August 26, 2017, 11:53 PM »
Thanks, unfortunately there is no solution for kliklamps to hold them like this in the market to buy.
I made this holder myself in the shop. I just came upstairs but tomorrow morning I can take it off and take a picture of the holder if it would give you any idea.
Offline Dovetail65
« Reply #146 on: August 27, 2017, 01:11 AM »
Is that a hospital or a shop? It sure is gorgeous.
I don't know if I am envious, jealous, feel inadequate or lazy.
I guess I'll just tell myself   that I work 18hours a day with no help and possibly you don't do the volume of work I do(for me it my full time job and hobby) or you have some kind of helper.
My wife sees your shop and I am in for a world of hurt. My shop looked like that ONCE, the day I moved in. I really need to get this place cleaned up.
Offline HAXIT
« Reply #147 on: August 27, 2017, 08:47 AM »
Here is what I made. You just slide it in slat wall and drop the kliklamp in.
Offline HAXIT
« Reply #148 on: August 27, 2017, 09:13 AM »
@Dovetail65
Helper is almost a dream for me and I do this as hobby for right now, but I am busy with two businesses which makes me to work 18 hours a day. I only sleep 4 to 5 hours a day and I am just fine.
Cleaning the shop is easy and a must to do thing for me or I should say I got this just like any other habit that is hard to quit.
Offline OXCanada
« Reply #149 on: August 30, 2017, 01:37 PM »
@HAXIT  Thanks!
I will build something similar.  Appreciate the picture.
Offline VW MICK
« Reply #150 on: August 30, 2017, 03:05 PM »
@HAXIT
Nice job
That really appeals to me
I wish I had the room for something like that
Cant wait to see what you come up with next
Mick
Offline some1 like me
« Reply #151 on: August 31, 2017, 02:22 PM »
 [eek] Wow...
I had to pinch myself to make sure I'm not dreaming. What a workshop or a ...... don't know how to name it.
Just amazing. Everything from A to Z looks perfect. I have never seen a workshop so "pimped up".
Offline Kev
« Reply #152 on: August 31, 2017, 06:02 PM »
[eek] Wow...
@some1 like me I think "shrine" is the word you're looking for [wink] [big grin]
Offline Tinker
« Reply #153 on: September 01, 2017, 09:20 AM »
That floor is so clean one should take off their shoes before walking on to it
Wayne H. Tinker
Offline Cochese
    • The 144 Workshop
« Reply #154 on: September 01, 2017, 10:04 AM »
Holy cow, I am jealous a thousand times over.
Offline HAXIT
« Reply #155 on: September 02, 2017, 10:22 AM »
The whole week I worked till 12 midnight and I am home for few days now and want to work another 70 hours. [big grin]
Next is scales and marking storage. I have some scrap that I believe I could use and I am working on it right now after this post and a hot cup of tee. If no, I am on my way to lumber guy. I just called him and his there till 4 pm today which is very good for me.
As always thank you very much to every one for comments.
Offline fotojoe
    • Really Right Stuff
« Reply #156 on: September 11, 2017, 12:17 AM »
Your super 5-S'ed shop and clamp rack are nothing short of brilliant. Thank you for sharing. Question? How do you wrangle lumber and finished projects in and out of the basement (pardon me if I missed that detail). Does the stair lead into the middle of the house? Thank you again.
Have: TS 75 EQ, RO 150 FEQ, CXS Set, CT 36E
Want: DF 700 EQ, MFT/3, more Systainers
Offline HAXIT
« Reply #157 on: September 11, 2017, 08:59 AM »
Thanks for the comment, That was the most important point that I think I was lucky about the house layout to going in and out without any problem. All I have to do is come down and going up 7 stairs and the door at the end of the stairs open up to my driveway. There is no turn, straight down and up.
Offline HAXIT
« Reply #158 on: September 30, 2017, 12:06 PM »
And when I was thinking that I could finish one project every weekend since labor day!
But the main tool was down right on labor day. [sad]
I was just planing some scrap when I felt pain in the lower back and try to ignore it because I want to work. The pain just got worst and now I know for sure what was that and I ended up to emergency room and could not do anything for almost three weeks now.
Today is the first day I am going to do some work.
Well who ever I called the answer was that I work too much or my hand was in the machine without knowing what was going on.
Well folks, it was kidney stone. [crying]
And who ever had it, knows what is it looks like and if you did not do not even think about it.
I am good now and thought to give some update and will post as I go.
Health is your main tool that you should love and care most.
Offline Bert Vanderveen
« Reply #159 on: September 30, 2017, 12:42 PM »
Did you save it? I have used mine to cut leather (just joking. but it was sharp enough to use for that purpose).
Good to hear that you are back in the saddle!
Cheers, Bert Vanderveen
TS55 · TS55R · OF1010 · DF500 Mk2 · MFT/3 + VL + CMS TS55 + CMS PS300 + LA-CS 70/CMS · CTL Midi · RTS400 EQ · 2 x CXS Li 1,5 · T15+3 Li 4,2 · TI15 Impact Li 4,2 · Centrotec Sets 2008 + 2015 · PSB300 · LR32-SYS · RO150 · Kapex KS120 · 2 x MFK700 · RO90 · OFK700 · BS75 · OFK500 · OF2200 · CMS-GE … | Mirka 1230L P&C | Hammer A3 31 Silent Power · Hammer N4400
Offline VW MICK
« Reply #160 on: September 30, 2017, 01:20 PM »
@HAXIT
Glad you are ok mate
They could have done the surgery at home in your shop! Probably cleaner
Mick
Offline RobBob
« Reply #161 on: September 30, 2017, 01:26 PM »
As painful as kidney stones are, it is still better to have a kidney stone than back problems.
Kidney stones are usually acute.
Back problems are usually chronic.
Offline HAXIT
« Reply #162 on: September 30, 2017, 02:51 PM »
Till now, I did not even know that it is looks like star and just compare it with regular stone, always thought it was round.
Nooooooo it was not.
Offline HAXIT
« Reply #163 on: September 30, 2017, 02:58 PM »
@HAXIT
Mick
You make me laugh Mick. [big grin] [big grin]
Offline HAXIT
« Reply #164 on: September 30, 2017, 03:00 PM »
I agree and just hope that won,t be the next.
« Reply #165 on: September 30, 2017, 06:36 PM »
In my case the largest kidneystone that showed up on an xray was 20 mm long, 9 to 10 mm wide and around 1 to 1 and a half mm thick, with the shape of an ellipse and extremely sharp edges. I was admitted to an Emergency Ward of the local hospital and the lady who did the xray said that in her opinion giving birth was less painful than passing a kidney stone (for what that is worth…);
After treatment they (the docs) had me pee thru a strainer for a few days -- days passed in the pure bliss of opiates -- and sure enough bits of that one, and others, showed up. I did not keep them.
Not the nicest experience I have ever had. Although hurtling down an iced hill head down while skiing came close.
Offline Peter Halle
« Reply #166 on: September 30, 2017, 06:52 PM »
Kidney pain is let's just say acute.  Seems you have weathered it as well as can be expected.  Wish you didn't have to go thru it.  Hoping that you aren't one of those who will have them continuously.
Offline HAXIT
« Reply #167 on: October 07, 2017, 04:24 PM »
I am afraid to say I am fine now then I will get hit by tractor. [big grin]
Working on the storage area under the stairs which I had the plan for long time that what would go there. There is nice space there if used correctly. Here is pic when it is empty now.
First back wall would be the storage for all marking, gauges and measuring tools hanging on the slat wall.
I have some scrap that I can use to take care of that. So here we go.
Offline HAXIT
« Reply #168 on: October 07, 2017, 04:48 PM »
Offline HAXIT
« Reply #169 on: October 07, 2017, 05:02 PM »
And the result. I will load it up later, I have to make some hanging hardware and order some stuff as well but I want to mill down more lumber today and keep going.
Thanks for watching and have wonderful weekend. [smile]
Offline digger
« Reply #170 on: October 07, 2017, 09:18 PM »
Happy to hear you're feeling better. It must feel great to be back in the shop.
Offline Tinker
« Reply #171 on: October 08, 2017, 03:18 AM »
@ HAXIT  Sorry to hear about your setback.  Our daughter suffered with kidney stones for several years.  She finally started squeezing a half lemon into a glass of distilled water every morning and drinking (with no sugar added) She uses lemon juice on her salads and in her tea. Since she started with that regimen, she has not had any more problems with the stones.  They all seem to dissolve.  I have a cousin who had the same problem and used the same method.  No more problems.  I'm no doctor, but it seemed to work with two people in my own family. That's good enuf for me.
Tinker
Wayne H. Tinker
Offline HAXIT
« Reply #172 on: October 08, 2017, 06:18 AM »
Thanks, it feel good and I missed the shop big time.
Offline HAXIT
« Reply #173 on: October 08, 2017, 06:30 AM »
Tinker
Tinker, are you sure you are not a doctor? because I think you are. [big grin]
The doctor at hospital told me the same thing. He said lemon juice in everything as you can and you will be fine. He also said cranberry juice and apple vinegar does the same thing as well.
Offline RobBob
« Reply #174 on: October 08, 2017, 06:37 AM »
@HAXIT  Tell me about that digital gauge you have on your A3 31.
What does it do and who makes it?  I have the same machine and might need one, too.   ;D
Offline HAXIT
« Reply #175 on: October 08, 2017, 07:17 AM »
@RobBob
It is Aigner Distometer and does many things. Here I use it to mill dawn exact at 1mm and I use this to measure and check the thickness of the material or set up the cutting tools height and many things.
I got this from Germany and in U.S Martin would be the one to have it. Here is the link:
 http://www.martin-usa.com/products/distometer/
Offline RobBob
« Reply #176 on: October 08, 2017, 07:32 AM »
@RobBob
Very interesting.  That's a new one to me.  Thanks for the info.
« Reply #177 on: October 08, 2017, 11:58 AM »
@HAXIT  What is the advantage of doing precise planing when you can achieve precision in the thicknessing part of milling (I think I saw you have the 'digital' wheel installed - which offers .2 mm precision)?
Offline HAXIT
« Reply #178 on: October 08, 2017, 02:43 PM »
Yes, you can do it in the thicknessing part and I did installed the digital wheel. You can use the aigner when your material is wider and won,t fit in machine if you do not want to take the work piece to the saw for the last cut but my situation here was different.
The width of the scrap I had was very close and I did not want to go under size to won,t have problem with the hanging hardware that they sell it for standard panels. I only used it for one side of the board to joint and maintain the standard size.
Offline Tinker
« Reply #179 on: October 08, 2017, 03:25 PM »
Tinker
I know cranberry juice is good for several urinary problems.  Apple Cider vinegar is good for kidney stones, but for some people there is a reaction.  Since the lemon juice (from fresh lemons) and distilled water seems to cause no reactions, I think one has to be carefull with vinegar, but no worries from lemon juice, I did not get into researching the vinegar method.  I sometime read up on something, and find another source that advises something different. I am somewhat of a nut as I will go with the idea most appealing to my thinking. It's sort of like weather reports.  If you don't like the first forecast you find, keep looking until you find the site with the report your like.  I like lemon juice. ::)
And I have observed within my on family that it does work.
Tinker
Wayne H. Tinker
Offline HAXIT
« Reply #180 on: December 26, 2017, 09:45 PM »
I am very busy at work and that is the only reason I just work over the weekends now but this week I am off till January 10th and I am in the shop every day. So sometimes I cannot post because I am coming back from work too late and I have to go back early in the morning. But it will change soon and I can be in the shop for longer hours.
So far I did a lot in three days, I made some hardware for slat wall and I just have to paint it and it will be done.
At the same time I am working on the storage area for under the stairs which is a nice space to store cleaning stuff, paint and etc...
I had to make some large boards and I had two choices, use how ever I have because I have to clean up the garage and it gets painted any way or visit the lumber yard which would be faster.
I just used what I had and here were I am now. It is moving forward so far so good.
Offline HAXIT
« Reply #181 on: December 26, 2017, 09:55 PM »
And today was a very good day. [smile]
Offline HAXIT
« Reply #182 on: January 01, 2018, 04:50 PM »
I finally finished today after working almost everyday.
The idea was to use the under stairs to store mostly cleaning,painting glue...etc and some not everyday use tools and after the thought this is what came up to my mind. If you just screw few shelf on the wall, then center stays open because you have to walk in to get the stuff. How about use the whole space and bring the stuff to you and put them back quickly?
The dark gray one is the deepest and one side only but the other two are two- sided.
Here is the pic from the other side.
Offline RobBob
« Reply #183 on: January 01, 2018, 05:08 PM »
Great idea!
Offline HAXIT
« Reply #184 on: January 01, 2018, 05:11 PM »
OK, let's go for ride now. Here is all three of them stored under the stairs and you just have to pull it out take what you need and put it back like in the second pic.
I also hanged a thread verifier right there and working on the back wall for storing marking and measuring tools only. It just a quick look but not done yet.
Happy new year to all and wishing the best in coming year.
Offline Tinker
« Reply #185 on: January 01, 2018, 06:03 PM »
Haxit, You are terrific.
Tinker
Wayne H. Tinker
Offline egmiii
« Reply #186 on: January 01, 2018, 10:59 PM »
Every time I revisit this thread, I am still amazed at how nice your shop turned out. Tons of great ideas, and more every month it seems.
I’m curious, have you ever considered selling the Festool router table and one MFT, then using the reclaimed space for a short stroke Hammer sliding table saw/shaper combo?
Offline grobkuschelig
« Reply #187 on: January 02, 2018, 01:49 AM »
Great design and use of space!
The only thing I would have changed would be the access side of the big/one sided drawer to give access from where you come from...
But really great work! [emoji1319]
Thanks for sharing!
Offline Dick Mahany
« Reply #188 on: January 02, 2018, 12:08 PM »
A little late to the party here, but I only discovered this thread yesterday.  What a jaw dropping transformation and incredible shop set up!  Thanks for sharing.
Offline live4ever
« Reply #189 on: January 02, 2018, 12:25 PM »
I have no idea how I missed this until now.   [eek]
I'm speechless.  [eek]
Unbelievable.  In a good way of course.   [eek]
Offline VW MICK
« Reply #190 on: January 02, 2018, 02:24 PM »
@HAXIT
I like this a lot. Really cool
Do you have a spray shop somewhere ?
What’s next ?
Mick
Offline HAXIT
« Reply #191 on: January 03, 2018, 06:24 AM »
Not yet because I use the cms in the garage as well but I would like to have a shaper in the future. Thanks for the comments.
Offline HAXIT
« Reply #192 on: January 03, 2018, 06:27 AM »
Thanks for sharing!
It was the original plan but I made a mistake and it was too late. As far as it is not a big problem I just let it go.
Offline HAXIT
« Reply #193 on: January 03, 2018, 06:34 AM »
@HAXIT
What’s next ?
Mick
The spray shop is not done yet, hopefully the end of this year. Right now I use the garage and the next project will be the storage for all cutting tools if I get my parts by weekend.
Offline HAXIT
« Reply #194 on: January 03, 2018, 06:50 AM »
Thanks to all of you folks for following this thread and comments are much appreciated. For some of us who is full time employee, it is not easy to be on line all time and progress goes slow sometimes. So that is why you see gaps between my posts but hopefully it is getting better.
« Reply #195 on: January 03, 2018, 09:57 AM »
I love how you used the space under the stairs. Very clever.  [thumbs up]
Offline HarveyWildes
« Reply #196 on: January 03, 2018, 10:32 AM »
Thanks for taking the time to share your work.  Very nicely done!  What a great idea for using space under the stairs.
What are silver and black knobs on the wall next to the stairs?  At first I thought they were a display of knobs, then a rack of sockets, but I looked more closely and it doesn't seem to be either of those.
How are you supporting the shelves in the storage units?  It looks like you have routed slatwall grooves in the vertical panels and inserted supports for the shelves, so that you can reconfigure the shelves or use other slatwall accessories.  What bit(s) did you use to route them?  It looks like an undercutting bit of some sort.  Also, it also looks like you routed grooves in the dark gray unit at regular intervals, while only routing slats for the shelves that are visible in the lighter units.  How did you decide where to route the grooves on the different panels?
« Reply #197 on: January 03, 2018, 10:48 AM »
A Reid badged, wall mounted thread checker.
http://www.swmanufacturing.com/parts-catalog/thread-checkers/the-wall-mounted-thread-checker/
« Last Edit: January 03, 2018, 10:51 AM by Cheese »
« Reply #198 on: January 03, 2018, 11:48 AM »
Thanks - totally new to me :).
Offline rvieceli
« Reply #199 on: January 03, 2018, 12:25 PM »
Harvey you'll usually see those at the hardware store or big box store near all the threaded fasteners.
Offline HAXIT
« Reply #200 on: January 06, 2018, 01:22 PM »
Hi Harvey,
Sorry for late reply, I was in and out for few days. The folks here answered your first question and it is available all over at hardware stores. You very much got the concept here and the shelves are supported by hardware that I made which I had time otherwise I had to buy and there are a lot of choices. If you need I can post some web sites but if you google hardware for slat wall you will see the few pages would pop up.
For slat wall grooves I have about 10 different sizes but for this I used the [Freud #52-522] this bit is the best when you want to buy the support and accessories that is already made. The bit is long and can go very deep, so make sure to try it on a scrap to ensure everything are at 90 degree. Dark gray is the deepest rack and I routed it out standard which is 3" from center to center the slat just in case if I want to change something in the future so I do not have to make the rack again. The other two are going to be used only for glue, polish,stain and caulk and it would be waste of time if I would route it out like the dark gray one. I made the location of the shelves based on how this stuff are sold. If it is too short, then some stuff would not fit and if it is too long, that would be waste of space.I used 1gal,1qt paint and caulk to decide the location for shelves.
OK, I going dawn in shop again.
« Reply #201 on: January 06, 2018, 01:29 PM »
Thanks for the explanation and the bit reference.
Offline swhite88
« Reply #202 on: February 12, 2018, 12:19 PM »
This shop looks incredible!!
I have recently purchased a Hammer A3-41 and need to move it into my basement shop as well. Do you have any tips on how to do this safely based on your experience?
Offline HAXIT
« Reply #203 on: February 14, 2018, 06:16 AM »
Thanks for the comment. I hired a industrial movers to do the job and did not touch anything. It is not easy to find one for a small job and you call 12 companies and only three of them called back.
Good luck and enjoy your new machine.
Offline HAXIT
« Reply #204 on: May 13, 2018, 01:38 PM »
OK folks, anything that I ordered is back order and it does not let me to start my next project in hope this is the last year I am working  my way out to finish this shop. I have no choice but to wait and I am going to change my plan right now to do some small projects which I had left them for the end but to stop the anger and get busy it is what it is for now.
I finally got one of this waxed paper and shop towel dispenser for the shop to stop using the paper towels from up stairs and to protect the table from complex gluing the waxed paper works great.
The clamp storage that I made is good for clamps up to 40" long and I do have 50 and 60 inches as well. I bought 4 of each and if I need anything longer I will use the extensions that I have. I would like to keep this longer stuff out of my way and this is what I did.
Here is the 4x60" under the stairs.
When I was working on this just found out the nice place for the 4x50" and also made a hanger for brooms and dust pan and all together came up great and completely out of my way. Also you can see in the picture that the back wall is getting filled up.
Now I am thinking about the shop stool so I do not have to seat on the floor anymore.
Offline HAXIT
« Reply #205 on: May 13, 2018, 01:44 PM »
How can I turn that picture now?! I never had that problem before.
Thanks.
Offline six-point socket II
  • aka @the_black_tie_diyer
« Reply #206 on: May 13, 2018, 02:33 PM »
Hi!
Simply amazing, I love coming back to this thread time and time again!
Kind regards,
Oliver
Kind regards,
Oliver
Offline HAXIT
« Reply #207 on: May 28, 2018, 10:28 PM »
I am not a big fun of sit down and work but I need a stool for shop anyway.
I got this left in the box for almost 3 years now and there is no chance that it will be used.
So I think I will make something identical to MFH 1000 to be more then just a stool and use this black blue foam before it rot in the box.
Offline HAXIT
« Reply #208 on: May 28, 2018, 10:37 PM »
Offline HAXIT
« Reply #209 on: May 29, 2018, 11:54 AM »
OK, Here is the tray for the foam the inside and the outside cut. The box is ready as well and I will post a pic before painting I just have to leave the house now.
Offline HAXIT
« Reply #210 on: May 29, 2018, 04:01 PM »
I am done for today and tomorrow back to work after few days off. The tray and the box is done and will be sanding and painting over the weekend.
Offline neilc
« Reply #211 on: May 29, 2018, 05:40 PM »
What are the orange strips you used in post #209?  Looks like they screw down.
Offline jpmeunier
« Reply #212 on: May 29, 2018, 06:07 PM »
Offline HAXIT
« Reply #213 on: May 29, 2018, 07:25 PM »
Yes it is flexible template and it is not intended to be used like I did. It makes it easier and faster to make the template and use but not to screw it directly into the work piece. However my work piece is only one and will be filled and painted so I just screw down to save time.
Offline HAXIT
« Reply #214 on: June 03, 2018, 04:10 PM »
I had to cut a slut on each side of the box and round it up for hardware that I made for lifting.
For the table top I was going to use a corian and right before I start asking around for drop offs if someone had anything left over I was in lumberyard for walnut and right when I waked in I saw this beautiful quartersawn mahogany 17" x 43" and just could not resist and I bought it. Here is the pic and the table top that I made.
Offline HAXIT
« Reply #215 on: June 03, 2018, 04:22 PM »
lifting hardware that I made.
Laser cut from 304 stainless then time saved.
Formed hardware and weld.
Offline HAXIT
« Reply #216 on: June 03, 2018, 04:40 PM »
This will be few things, lifting table, small work station, storage and of course you can sit on it. some pics before I finish it.
Here is how it is looks like when it is a stool. It is exact size as MFH 1000 and because I add a table to it so I just got smaller casters by 25mm not much and I am right on.
And when it is all the way open. You can lock it up from 14" up to 39".
Offline HAXIT
« Reply #217 on: June 29, 2018, 02:51 PM »
Finally done after painting every weekends. In first picture as stool next to MFH 1000
In order to remove the green tray, just take out the foam and loose 4 screws and it comes right out and now you got a small workbench.
Offline HAXIT
« Reply #218 on: June 29, 2018, 03:04 PM »
Now the table is open up all the way which is 40" and two sys1 is in the box. You can also see the tool tray in the back inside the box in blue black which is hold by a magnet. Three sys1 or one sys4 fits in the box perfect and you can move up to 6 systainers around.
« Reply #219 on: June 29, 2018, 03:09 PM »
Very interesting, thanks for sharing! And a flawless build as always :)
Kind regards,
Oliver
Kind regards,
Oliver
Offline HAXIT
« Reply #220 on: June 29, 2018, 03:14 PM »
Here the table hight is exact with mft3 with ct sys in the box so we got the dust collector and the tool tray and hardware with some tools.
I will post more pics tomorrow as I have to leave now. Thanks for watching and happy Friday.
[ Specified attachment is not available ]
Offline HAXIT
« Reply #221 on: June 30, 2018, 12:32 AM »
Kind regards,
Oliver
Thanks Oliver, your comments are much appreciated.
Offline HAXIT
« Reply #222 on: June 30, 2018, 12:39 AM »
Just got home from work. Looks like one attachment had a problem so I try again.
Offline neilc
« Reply #223 on: June 30, 2018, 09:00 AM »
Very cool table/stool.  Execution is just fantastic!
Do you have a mill and metal brake for the metal forming?
Thanks for making us all jealous with this shop!  You do great work.
Neil
Offline HAXIT
« Reply #224 on: June 30, 2018, 12:15 PM »
Neil
Thanks Neil. [smile]
I do not own any mill or brake but I am a full time employee at welding and metal fabricating shop for a long time and this is my bonus that my boss let me do anything I want with the respect to the business. So when shop is busy I have to wait till machine become available.
Just finished the outdoor work and going down in the shop. Will post few more pics soon.
Offline HAXIT
« Reply #225 on: June 30, 2018, 04:46 PM »
Just few more pictures. Here the set up for DF500 joiner. The tray can be removed and the hangers on each side can stay on.
The ct sys and assorted tenon systainer on the top open.
Set up for HL 850 planer.
Offline HAXIT
« Reply #226 on: June 30, 2018, 05:03 PM »
There is a 8mm hole at the center of the table from both sides and here is 2000mm homemade compass. [big grin]
I made this two years ago and now I do not need the 2x4 to do this. It already worked great now just easier.
And finally a cool place to park.
« Reply #227 on: July 01, 2018, 11:14 AM »
I was going to ask who did your laser cutting, but after reading a bit further, I now know...You. [cool] That's a nice perk to have in your back pocket. I really miss not having access to the Engineering Model shop.  [crying] [crying]
I really enjoy this thread and your work.  [smile]
FWIW...if you were to attach 2 custom turned aluminum/stainless dogs to the bottom of the green tray, you could then remove the seat/tray assembly without needing to remove the 4 screws. I did that for the Vac Sys and I can now place it anywhere on the MFT.
« Last Edit: July 01, 2018, 11:21 AM by Cheese »
Offline HAXIT
« Reply #228 on: July 01, 2018, 02:11 PM »
FWIW...if you were to attach 2 custom turned aluminum/stainless dogs to the bottom of the green tray, you could then remove the seat/tray assembly without needing to remove the 4 screws. I did that for the Vac Sys and I can now place it anywhere on the MFT. (Attachment Link)
Thanks for the comments, and my idea about securing the green try is exact what you did but machine that I had to use got busy with 1100 pieces of work and got the Stainless round stock left over for now but can be done later. I am using the split dogs from lee valley for now and the screws does not have to be removed. Just a turn and it comes right out.
http://www.leevalley.com/us/Wood/page.aspx?p=59754&cat=1,41637
I had this for something else and used them for now, but in the future I will replace it with dogs as far nothing will be changed.
