Author Topic: New workshop build  (Read 72071 times)
Offline neilc
Re: New workshop build
« Reply #60 on: December 29, 2016, 07:36 PM »
Fantastic!  Great space with wonderful lighting and layout.  I'm sure you will love doing work there and no doubt, your work will be raised due to the inspiration of the space.
Thanks for sharing!
Online RobBob
« Reply #61 on: December 29, 2016, 07:46 PM »
@HAXIT   Where did you get the slat wall for hanging the Festool accessories?
Online HAXIT
« Reply #62 on: December 29, 2016, 08:14 PM »
Here is a close up pic from that slatwall. You can not see it from faraway, it is not plastic or MDF. It is interlocking aluminum with green pvc strips inserted to cover the screws.
Here is the Hammer n4400 band saw wich is connected to Laguna dust collector and when I need it, I just roll it for A3 31. This dust collecter is just for this two machines. At the center I have my TS 75 and the ct sys on sys-roll so I can quickly grab it and go to garage just to cut the sheet good to bring them down here.
It was a large open area in the first picture and I moved what was there just to show how much space I can have if I want to but I have two Felder FAT 300 lifting tables that goes there.
The next picture shows one at lowest 400mm and one at highest 1030mm and can be set at any point between by using the hydraulic lift. The tabe top is glue, solvent and scratch resistant and is almost same size as MFT3 just 20mm wider and 100mm longer.
Online HAXIT
« Reply #63 on: December 29, 2016, 08:47 PM »
Here is some usage of the lifting tables. I put one at each end of MFT3 which helps to support a very long lumber and for some projects the vac sys is a bit high for me, so I just remove it from plate and drop them on lifting table. Oh life gets much easier.
Here is the example.
Setup for joining.
setup for thickness.
And finally just two pics from corners for whole shop.
Offline duc996
« Reply #64 on: December 29, 2016, 09:12 PM »
That is a beautiful shop! Awesome setup!
Online HAXIT
« Reply #65 on: December 29, 2016, 09:29 PM »
Finally something about lights and use it in the efficient way.
When I started this project, I know the layout in my head and wired the lights half and half. If you take a marker and put a line in the middle of the chimney to the front and the end wall, you would split the shop in half. There are 12 florescent fixtures in the shop and each one holds 4 T8 4' tube. So each side of the shop has 6 fixtures which has separate breaker and switch.I can turn the half shop off to be more efficient and still get great lighting with no shadows.
For example, If I work on the festool side, I can turn the lights off on the other half or opposite. I just took two pictures by standing at the end of chimney.
Work on the festool side.
work on the Hammer side.
Thanks everyone for following this thread and I hope I could be useful for others and feel free to leave you comments or questions.
Online HAXIT
« Reply #66 on: December 29, 2016, 09:36 PM »
Let me find the receipt, I will post it soon I do not remember the web site but I have it.
Online HAXIT
« Reply #67 on: December 29, 2016, 09:42 PM »
Thanks folks for the good words and comments.
Online HAXIT
« Reply #68 on: December 29, 2016, 10:13 PM »
http://www.megawall.com/
Offline Don T
  • Phoenix, Az
« Reply #69 on: December 29, 2016, 10:33 PM »
Awesome shop you have.  That is definitely a dream shop..
RO150, C12, DF 500 Q, CT33, TS75, MFT3, Kapex 120, MFT3/Kapex, MFK 700, RO 90, ETS150/3, CT22, Centrotec Installers Kit, Parallel Guides & Ext, Carvex, OF1400, LR32 Set, MFS400 w/700 rails, KA UG Set, First Aid Kit, RTS 400 EQ, Vecturo OS400 Set, CT Wings, CT Drill Guide, Pro 5, CXS
Offline Rhino1789
« Reply #70 on: December 29, 2016, 10:37 PM »
WOW!!
Offline ScotF
« Reply #71 on: December 30, 2016, 12:37 AM »
Amazing workspace....thanks for the share!  I would love to hear more on the Felder tables - I have seen them and they look very versatile. Not cheap, but useful nonetheless. I have thought about buying one for exactly the same purpose.
Offline HMR
« Reply #72 on: December 30, 2016, 01:25 AM »
Great job!  Thanks for sharing.
Offline vuongnuce
« Reply #73 on: December 30, 2016, 01:38 AM »
like hotel than a workshop  [thumbs up]
Bosch GST135 BCE, Festool TS55, Domino DF500, ETS 150/3, 150/5, RTS 400EQ, Rotex 150, Festool CMS, CTL Midi
Online HAXIT
« Reply #74 on: December 30, 2016, 01:51 AM »
Thanks, I did not buy both of them at the same time. I bought the first one 9 months ago and when it arrived it was build much better then what I was thinking. It is 250 bound and holds up to 600 pound and all 4 rollers get locks. I was moving it under the MFT3 and every cut I was making I could put it on the top and keep the MFT3 ready for another cut. I started moving much faster and easier I ended up to buy another one 3 months ago and I am glad I did. Unless you pick it up,this is heavy and comes on skid so it is not a ups or fedex item and shipping cost approximately $250 depends on where you live.Let me know if you need any more info.
Online HAXIT
« Reply #75 on: December 30, 2016, 01:56 AM »
One more time if I missed anyone, thank you very much for the words and comments. [smile]
Offline Ironmantrev
« Reply #76 on: December 30, 2016, 02:11 AM »
Well done. Shop looks great. Enjoy it now after all your hard work.
Which megawall profile did you use?
Did megawall provide the green screw cover or was that your custom touch?
Will any standard slat wall hooks, etc work, or do you need special ones?
I've been leaning towards some type of metal peg board vs slatwall, but this looks great and will be much better than any plastic/mdf variant I've only seen up,until now. This is a great find.
Thanks for sharing the project from beginning to end with all the little details. Now go break in all that new equipment.
Offline VW MICK
« Reply #77 on: December 30, 2016, 02:34 AM »
@HAXIT
This is an amazing workshop. I have been following this avidly. My favourite thread in a long time
Those photos would have been at least 18 months apart if it was me
You must have another area for all your crap
You have inspired me. I'm going to try and get my workshop floor painted in the next couple of days
And again amazing
Mick
Offline Tinker
« Reply #78 on: December 30, 2016, 04:32 AM »
This has been an amazing  project in just the time it took.  There is just one thing you have not shown. Your scrub area for when you are about to perform surgery.
I love the clock.  Do you pour water on those tiny tools to make them useful and then shink them when finished?
All kidding aside, your planning and vision have been great. You have a terrific work space.
Tinker
Wayne H. Tinker
Offline Poindexter
« Reply #79 on: December 30, 2016, 07:17 AM »
Wow wow wow!  So many things I'm drooling over.  But I'm imagining the handiness of those Felder tables to be almost invaluable.
Online HAXIT
« Reply #80 on: December 30, 2016, 07:23 AM »
Thanks for the comments, much appreciated.The megawall profile that I used called 1 3/8" flat back A138-1s-96.
They only sell the tracks, for green screw cover and hooks look here.
https://www.storesupply.com/vinyl-slatwall-insert-green-45239.aspx
The standard hooks work on this one which I mixed match to get what I needed but I am not sure if they would work with other tracks that they have.
Online HAXIT
« Reply #81 on: December 30, 2016, 07:29 AM »
@HAXIT
And again amazing
Mick
Thanks and good luck with floor. [smile]
Online HAXIT
« Reply #82 on: December 30, 2016, 07:34 AM »
Thanks, I always work alone and these two tables act like an employee.
Online HAXIT
« Reply #83 on: December 30, 2016, 07:46 AM »
Tinker
Thanks Tinker and much appreciated. The clock was my idea, I designed and there is a website that they made it for me. It is made out of 1/4" acrylic.
Offline sheperd80
« Reply #84 on: December 30, 2016, 08:22 AM »
Nice laboratory haxit. Looks great
Sent from my SAMSUNG-SM-G890A using Tapatalk
Offline egmiii
« Reply #85 on: December 30, 2016, 09:45 AM »
This is quite possibly the nicest shop transformation I have ever seen, never mind the fact you did it in just over a month. I'm also going through the process of building a shop in my basement, so I can appreciate the sheer amount of time you've invested thinking this through and getting it done. I have a feeling there are tons of little details you agonized over, but will never be noticed by the casual observer since they seem obvious now. Laying out each machine to have proper in/out feed areas, especially around all of the obstructions is a brain twister in itself.
Kudos to a job well done. You have truly inspired me and likely many others on this forum.
Mind if I ask where you are located?
Offline Duck76
« Reply #86 on: December 30, 2016, 10:26 AM »
Your build is inspirational...both in looks and speed of execution. All of your equipment choices (A3-31, N4400, CMS...) have been on my wish list for a while. Seeing them all together in one space increases the want.
Well done! [cool]
Offline Billedis
« Reply #87 on: December 30, 2016, 11:54 AM »
That is a piece of art.  Thank you so much for sharing.  Bill
Offline mike_aa
« Reply #88 on: December 30, 2016, 12:25 PM »
@HAXIT
This is one of the threads that I know I will refer back to from time to time for all the great ideas you've presented.
Your build is truly amazing and it's astonishing how quickly you completed it!  I only wish I could have half your energy. LOL
One question - What's the main ceiling height?  It looks low and I wondered how that affected some of your decisions.
Thanks, Mike A.
Offline Motown
« Reply #89 on: December 30, 2016, 02:27 PM »
Wow. This is one of my favorite posts, very excited for you Haxit.
I had a few questions about your epoxy floor. I have just re-did my garage/shop and want to do an epoxy floor in 2017 so I was hoping you could provide some insight with a couple of things:
- Looks like you did the grinding and finish yourself. Can you provide some feedback on the difficulty/skill set needed to achieve that finish? I've redone hardwood floors but never concrete.....I am thinking "it's my garage/shop, so why not give it a shot".
- What brand of epoxy did you use?
Thanks in advance and congrats on a beautiful work space. Can't wait to see future project posts.
