Author Topic: New workshop build  (Read 71822 times)
0 Members and 3 Guests are viewing this topic.
Offline HAXIT
Re: New workshop build
« Reply #120 on: August 12, 2017, 10:12 PM »
I also made this out of aluminum to add the second dust port for the hammer band saw.
It is a aluminum tube with tapper hole inside welded to a 3/8 plate and 6 small magnets at the face to keep it on the side of the machine safely.
The dust nozzle was made out of 2.5 x 6 inches round stock 6061 and is fully adjustable. The height of the nozzle can be change from 5" to 20" by moving the stainless steel plates and adjustable handles. It also gets connected to 27mm hose inside and 36mm outside. Here the pics
Offline HAXIT
« Reply #121 on: August 12, 2017, 10:32 PM »
How about test drive. [big grin]
Here is 35mm hole in 35mm or maybe 40 material without dust collector.
and with 27mm dust collector attached. Scary nice and very satisfied.
Offline HAXIT
« Reply #122 on: August 12, 2017, 10:41 PM »
Now back to woodworking. [thumbs up]
Got some poplar and soft maple. Making the mobile clamp storage.
Offline Poindexter
« Reply #123 on: August 13, 2017, 08:20 AM »
I'm still enjoying this thread.
Offline Bob D.
« Reply #124 on: August 13, 2017, 08:40 AM »
Beautiful setup and nice to have all the additional support and also to be able to utilize it with adjacent tools like your CMS.
Question about your drill press.
It looks like you can raise/lower the height of the head on the column as well as the table like most drill presses.
Offline HAXIT
« Reply #125 on: August 13, 2017, 10:02 AM »
Thanks and I am glad that you like the thread.
Offline HAXIT
« Reply #126 on: August 13, 2017, 10:11 AM »
Thanks for the comment and yes you can raise/lower both the head and the table and they both turn 360 degree around the column.
Offline HAXIT
« Reply #127 on: August 13, 2017, 10:26 AM »
Milling dawn the lumber for mobile clamp rack.
Offline HarveyWildes
« Reply #128 on: August 13, 2017, 10:34 AM »
Some really nice ideas for dust collection.  Looking forward to the clamp rack.
Offline HAXIT
« Reply #129 on: August 13, 2017, 12:30 PM »
Thanks, I have to paint it as well, so I think it will be done in two weeks.
Offline kelauben
« Reply #130 on: August 14, 2017, 04:29 PM »
I'm looking forward to these updates more than GoT episodes!   [tongue]
Where do I look to order the MegaWall slats?
Thanks.
Karl
Offline HAXIT
« Reply #131 on: August 16, 2017, 12:47 AM »
Thanks.
Karl
I thought I did post it here before but here is.
http://www.megawall.com/
Offline HAXIT
« Reply #132 on: August 16, 2017, 12:55 AM »
Boards are made and I will start put them together.
Offline HAXIT
« Reply #133 on: August 19, 2017, 12:03 PM »
Well, It is done.
It is made with domino, only 24 #12 screws were used for casters. This is just dry fit to make sure it fits nice and then I have to sand and paint. Oh and some hardware for both sides slot wall.
Now I opened everything to sand and finish.
Offline digger
« Reply #134 on: August 19, 2017, 03:42 PM »
That's one beautiful clamp rack. Can't wait to see it finished and full of clamps. Your workshop is awesome.
Offline Svar
« Reply #135 on: August 19, 2017, 03:58 PM »
This is what puzzles me. You made this rack and your shop still looks like surgery room. Where is the dust and random junk?
Great job.
Offline HAXIT
« Reply #136 on: August 20, 2017, 08:42 AM »
Thanks, painting goes slow because of the steps and sanding between the coats but I think will be done by next Sunday.
Offline HAXIT
« Reply #137 on: August 20, 2017, 08:47 AM »
Great job.
I promised myself to keep it this way but do not count on it. [big grin]
Junk usually gets clean up right after work and move to garage and sit there till garbage day.
Offline Redart
« Reply #138 on: August 21, 2017, 05:04 PM »
Very nice workshop, impressive !!
Festool: CTL midi.
Mafell: MT 55 CC, DD40 G, LO 50 E, EVA 150 E/5.
Nilfisk Alto attix 30 ... Makita, Bosch ,Fein and Lamello tools.
Offline HAXIT
« Reply #139 on: August 26, 2017, 01:19 PM »
OK folks, the clamp rack is done.
You might ask for the dimensions or how much space does it takes to park the rack?
Not much but will hold a lot of clamps and accessories. It takes a space just like you put three sys-port next to each outer with sortainer on the top. Look at the picture below.
Thanks for watching and the comments, I will load it up with clamps after breakfast and post some pics.
Offline HAXIT
« Reply #140 on: August 26, 2017, 02:51 PM »
It holds up to 40 bessey k body on both sides from 12" to 40" which I have 8 of each. I also have the 50" and 60" which will be stored under the stairs. The rest of the clamps and accessories are on both sides. The green blades or however you want to call it, is used as a handle to move the rack around easily.
Offline digger
« Reply #141 on: August 26, 2017, 04:21 PM »
That is one beautiful clamp rack. Great job !
Offline Vondawg
« Reply #142 on: August 26, 2017, 05:22 PM »
looks like a candy store display for us tool/shop addicts....very tastfull and sharp! thanks for sharing the build
Offline HAXIT
« Reply #143 on: August 26, 2017, 08:53 PM »
Thanks for the comments everyone.
I have to make 6 storage area here to finish the shop, not buying any tools or changing any ideas that I had at the beginning of the building this workshop just finishing what I had in mind.
I think I will work on storage area for all measuring, marking and scale tools next. I have to visit the garage tomorrow morning to see what lumber I have left.
Offline OXCanada
« Reply #144 on: August 26, 2017, 11:09 PM »
Nice job! That is fantastic.
It looks like you have some kliklamps on the side. What mount did you go with to hold them?
I am looking for a solution similar to what you did.
Offline HAXIT
« Reply #145 on: August 26, 2017, 11:53 PM »
Thanks, unfortunately there is no solution for kliklamps to hold them like this in the market to buy.
I made this holder myself in the shop. I just came upstairs but tomorrow morning I can take it off and take a picture of the holder if it would give you any idea.
Offline Dovetail65
« Reply #146 on: August 27, 2017, 01:11 AM »
Is that a hospital or a shop? It sure is gorgeous.
I don't know if I am envious, jealous, feel inadequate or lazy.
I guess I'll just tell myself   that I work 18hours a day with no help and possibly you don't do the volume of work I do(for me it my full time job and hobby) or you have some kind of helper.
My wife sees your shop and I am in for a world of hurt. My shop looked like that ONCE, the day I moved in. I really need to get this place cleaned up.
Offline HAXIT
« Reply #147 on: August 27, 2017, 08:47 AM »
Here is what I made. You just slide it in slat wall and drop the kliklamp in.
Offline HAXIT
« Reply #148 on: August 27, 2017, 09:13 AM »
@Dovetail65
Helper is almost a dream for me and I do this as hobby for right now, but I am busy with two businesses which makes me to work 18 hours a day. I only sleep 4 to 5 hours a day and I am just fine.
Cleaning the shop is easy and a must to do thing for me or I should say I got this just like any other habit that is hard to quit.
Offline OXCanada
« Reply #149 on: August 30, 2017, 01:37 PM »
@HAXIT  Thanks!
I will build something similar.  Appreciate the picture.
