Author Topic: Rolling Festool Transit  (Read 10671 times)
Offline Jostein
« on: December 21, 2015, 05:37 PM »
Thought I´d start to share some of my work in progress far up north in Norway.
Got my new Transit 4x4 about 2 months ago, and finnaly started to build racking for it.
Its gonna be 6 custom drawers under the racking to support the wheight.
Havent worked out exactly how yet, but the Kapex, cs50 and mft in the front.
235083-0
235085-1
235087-2
235089-3
235091-4
Offline Jostein
Re: Rolling Festool Transit
« Reply #1 on: December 21, 2015, 06:03 PM »
Got my mini into the rack to. CTL 26 also going in the opposite rack.
Now waiting for the CTL, Vecturo, Rotex 150, TSC 55 REB, DRC 18, BHC 18, 2 x Syslite and lots of systainers.
235101-0235103-1
Offline neeleman
« Reply #2 on: December 22, 2015, 05:10 AM »
Although it looks very nice and neat but Festool doesn't recommend the SYS-AZ drawer slides to be mounted in a vehicle!
And the maximum load is 20 kg.
But you must have read that already in the manual.
Festoolian since 1998.
FESTOOL:
SYSROCK BR10 | SYSLITE KAL II | SV-SYS D14 | DSC-AG125FH | CDD9.6 | SYSLITE DUO | DF700 | HKC55 | TXS2.6 | CTL SYS | CXS2.6 | DWC18 | CTWings | BHC18 | CS50 | CMS-OF | MFT/3 | MFT/3-VL | KS120 | TS55 R | PSC420 | PS420 | BS75 | RAS115 | RO90 | RO150 | DTS400 | RS400 | RTS400 | RS300 | LS130 | DX93 | ETS150/5 | ETS150/3 | OF1010 | OF1400 | OFK500 | MFK700 | T18 | EHL65 | CTL26 | CTL22 | CTL MIDI | WCR1000 | D27-AS Plug-it | D36 UNI-RS | D36x7 | D50x2.5 | FS800 | FS800/2 | FS1080/2 | FS1400/2 (2x) | FS3000/2 | FSK250 | FSK420 | Gecko Dosh | Toolie | CE-SYS-2010 | RB-SYS CART (2x) | LEV1400 | LEV350 | SYS-MFT
PROTOOL:
Offline Andy UK
« Reply #3 on: December 22, 2015, 11:32 AM »
Who reads the manual anyway?  [big grin]
[TS55 REBQ] [OF 1010 EBQ] [MFT/3]
Offline Kevin D.
« Reply #4 on: December 22, 2015, 05:30 PM »
(Attachment Link)
I wonder if it becomes an issue you could simply create some kind of flip-stop that harnesses along the vertical each bank of drawers to deal with the drawers tending to slide out while in motion.  Seen people do similar in the past for mobile drawers setups.
Keep it coming.  Looks like a nice job so far.
Kapex, CT36AC, TS75, MFT 1080, MF-SYS/2, PS300 EQ-Plus, Parallel Guides Set, LR32 SYS, RO 150FEQ-Plus, OF1400 EQ Plus, DOMINO 500 Q-Plus,  MFK 700 EQ-Set, FS-SYS/2, CT22 w/hose storage, D36HW-RS-Plus, FS 1900/2, FS 3000/2, FS 1080/2-LR32, FS 1400/2-LR32, Gecko, Festool Hat, Festool T-Shirt (2), Festool Floor Mat, Festool Stein, Multi-Tool, tape measure, large and small Festool floor mats (foam rubber).
Offline Jostein
« Reply #5 on: December 23, 2015, 07:36 AM »
I am well aware that its not recommended, but it works great. They are thight and wont come out. As you probably know, you have to lift the green handle to pull them. In a crash its another story, but hopefully I´l never find out.
If they cant handle the weight over thime, i just replace them with fixed shelves:)
Have to get most of the structure done before the beginning of januar, then i can add things here and there along the way.
Any suggestions on where to but the 2700 guiderail?
Offline Jostein
« Reply #6 on: January 01, 2016, 06:19 PM »
Used scrap from oak countertop to make rails. I let the Kapex do all the work;)
235730-0
235732-1
Now all the weight is on the floor.
235734-2
Offline BMAC
  • BMAC Construction & Consulting Ltd.
« Reply #7 on: January 01, 2016, 09:49 PM »
Nice job @Jostein
How did you end up fastening the shelves to the van walls? I'm asking as I haven't got to that sat age yet on my build and I'm looking for ideas that will survive the rigours of a moving vehicle over time.
Bruce
Support services for the Fire and Flood Restoration Industry. Specializing in custom cabinetry restoration and millwork.
Offline WelshWood
  • www.facebook.com/WelshWoodworks/
    • Welsh Woodworks
« Reply #8 on: January 02, 2016, 03:54 AM »
Nice job @Jostein
If it's already been ply-lined, I normally pocket screw them,
~WW
TS 55 REBQ-Plus | CXS Li 2,6-Set | CTL Midi Cleantec | BHC 18 Li 5,2-Plus | Carvex PS 420 EBQ-Set | OF 1400 EBQ-Plus | DRC 18/4 Li 5,2-Plus | Domino DF 500 Q-Plus Set | ROTEX RO 125 FEQ-PLUS | Kapex 120 UG-Set, Base Frame & L/R Extensions
Offline Jostein
« Reply #9 on: January 02, 2016, 06:00 AM »
Nice job @Jostein
40x40mm L-brackets and self-drilling screws. Used that on my previous build, and never had problems so far.
Offline Jostein
« Reply #10 on: January 04, 2016, 04:30 PM »
Its comming along. Got my scissor jack´s and floodlight mounted. I also put in the sortainers on fixed shelves.
236059-0
Gonna get the front worked out in the comming days.
Offline BMAC
« Reply #11 on: January 05, 2016, 09:15 PM »
@Jostein
The build is looking good Jostein! I feel like a slug compared to what you've achieved so far!
I've had my Promaster since December 15th and all I've done is the floor. I have a decent sized shop but I can't bring my van inside so all upfit work has to happen outside in the cold...its -10 Celsius outside right now and the forecast shows in the next couple of days it supposed to go down to -20C (with a possible windchill of -28 Celsius). Brrrr....!
Keep the photos coming!
Bruce
Offline 3PedalMINI
    • Signature Sound & Video
« Reply #12 on: January 09, 2016, 10:36 AM »
I plan on using the AZ shelfs in my van. They wont withstand a crash and im sure festools lawyers made the put that in there because they knew most of us would put them in our vans! But honestly, in a crash im not sure anyones racking system would withstand it! As long as you have a quality headache rack, you will be alright in a wreck, your tools may not but you will atleast be ok!
The Bitterness of poor quality remains long after the sweetness of low price is forgotten -Benjamin Franklin
Professional Custom Audio Video System Designer/Installer serving Southern - Middle NJ, Eastern PA & the Surrounding Shore Points.
www.sigsv.com
Kapex 120,TS55,RO150,ETS125,CT-26,CT-MIDI,Tradesmen Cleaning Kit, Festool Ratchet Kit, Sys-lite, Sys Roll Cart, T18 +3, 2013 Centrotec Kit, Carvex 420, Carvex Accessory Kit, CXS,RO90, TI15 and Various Festool Systainers
Offline Billy stray
« Reply #13 on: January 12, 2016, 08:58 PM »
Looking good jostien, I'm curious about the bottom drawers,  what do u use them for ?
Billy
Offline sofa_king_rad
« Reply #14 on: April 02, 2016, 05:25 AM »
(Attachment Link)
Do you have any updates?
TS55, MFT3, OF1010, RO 150, KAPEX, CT Mini
Offline demographic
« Reply #15 on: May 01, 2016, 04:36 AM »
I like that scissor jack mounting board, they can take up a lot of space otherwise.
Offline Jostein
« Reply #16 on: July 07, 2017, 06:32 PM »
Some pictures taken this spring. The first employee got the van, and I got myself a new VW T6. Now i start all over again.
That said, this layour have been working great so far. Got a wokshop now, so i wont need all the tools in the van all the time. That factor and having aut.trans led me to VW. This time I´m making racking simular to Ron Paulk´s design. Its modular and easy to move drawers around as i go.
Maby this can help some of you to deciding where to put your tools.
Cheers!
