Author Topic: System Workshop Build  (Read 10574 times)
Offline blaszcsj
« on: March 26, 2018, 12:58 PM »
My tool collection has grown past my current setup and storage capacity. I have also been thinking about redoing my work flow and Timothy Wilmots System workshop fit the bill. So I have begun adapting it to my workshop. First up is my workbench and adding a mitersaw station. I am currently about 85% complete. I have to make the top drawers and get the timber this weekend for the front dog/clamping system. Hope you enjoy. Cabinets are next.
The Before:
Making the sysdrawers and cabinet carcass:
Assembly:
Worktop laminating with HPL top:
Top and miter saw installed (need to make the front track and dog mounting system):
OF1010 EQ Router | MFT/3 | DF500Q | Carvex 420 | ETS EC 150/3 | CT 36 Auto Clean | TSC55 | LR32 | OF1400 EQ Router | ZOBO Metric Set | CXS Li 2.6 - 90 Limited Edition | Universal Cleaning Set | HKC55 | Centrotec CE-SORT | RO150 FEQ | DTS 400 | RO90 DX | CTSYS | C18 Drill | SysLite KALII | Syslite STL 450 | RAS 115 E | OF2200 EB
Offline mattbyington
Re: System Workshop Build
« Reply #1 on: March 26, 2018, 09:32 PM »
Nice work it looks great!!
Matt
Offline Don T
  • Phoenix, Az
« Reply #2 on: March 26, 2018, 11:00 PM »
Looks nice. Sometime in the near future I’m going to try and add my systainer in some existing garage cabinets. Unfortunately they are cheaply made.
Offline Max Fracas
« Reply #3 on: March 27, 2018, 12:05 AM »
Really looks great. I've been thinking about adapting Timothy's system to my shop. Will you put upper cabs above the miter station?
Offline neilc
« Reply #4 on: March 27, 2018, 07:55 AM »
Those look really nice.  Quite a transformation.  I like the drawer bottoms.  Had seen Timothy’s videos but never noticed the details in design.
Looking forward to seeing more as you progress.
Offline jobsworth
  • Festool Baby.....
« Reply #5 on: March 27, 2018, 10:30 AM »
Very nice, clean and well organized. Are you going to add a extension fence to the miter saw?
Offline blaszcsj
« Reply #6 on: March 27, 2018, 10:15 PM »
At some point, first will be the tall systainer floor cabinets. Going to do two pods with a work surface in between. Then put wood storage cubbies behind them.
Yes. I just purchased the dominofix jig and will add a 20mm grid. Then use the holes to set up a grid. I’m eying those new RUWI hold downs for rail.
Offline Ves
« Reply #7 on: April 01, 2018, 12:45 PM »
Looks like a nice setup you got there
Offline blaszcsj
« Reply #8 on: April 01, 2018, 10:47 PM »
Busy weekend but I managed to get, mill up some ash, and machine the grooves for the t-track.
Test fit on bench:
Offline Gr8trim4u
  • I did it all!! The woodwork I mean.
« Reply #9 on: April 04, 2018, 06:51 PM »
Nice flooring for a workshop!!  Very Nice set up!!
Not my first rodeo!!!
Offline blaszcsj
« Reply #10 on: April 04, 2018, 10:16 PM »
Thanks! It is just cheap engineered flooring. Because its in the basement, when I finished the room, I wired it as a "media room" that so happened to have 220V... its a slick when it gets alot of dust on it from the table saw. However, it makes for super easy clean up and is a nice thermal break from the concrete.
Offline Max Fracas
« Reply #11 on: April 04, 2018, 11:51 PM »
@blaszcsj Looking good.  Where did you get the HPL?
Offline blaszcsj
« Reply #12 on: April 05, 2018, 12:39 PM »
Formica plant is in Cincinnati. My wife's father worked there and I just picked it up.
Offline ghjaxman
« Reply #13 on: April 05, 2018, 01:21 PM »
That looks great, I am in the middle of building one myself.  Fun to build.
Offline blaszcsj
« Reply #14 on: April 19, 2018, 12:32 AM »
Been working on the vertical work hold down/dog rails:
Made a jig to accurately/repeatably index the domino for the dog supports:
Indexing:
I made a jig for the making repeatable thru mortises with the domino as the 500 will not reach thru in one pass. I used the front dog slots to index on the jig. Then use the Domino to mortise from both sides.
It was really nice outside so I had a cold one.
Turned out really nice:
Offline blaszcsj
« Reply #15 on: July 24, 2018, 02:01 PM »
Had some changes in the shop recently. I purchased a K3 Winner from @RobZ . I got it installed and built an outfeed table for it and now turned my attention to finishing the system shop and organization in the shop.
How to get a K3 in a basement:
Step1: Get your father in law to help.
Step 2: Make a sled (no good picture of actual sled) and get truck in front of stairs.
Step 3: Slowly push the saw to the edge of the stairs, kick it over, and use truck to slide it down.
Step 4: Reinstall the bits and pieces (I am pretty sure my shop exploded in this process):
I then made an outfeed table/bench:
Then, this past 2 weekends I started tidying up the shop with a wood rack/tool wall combo:
Tool wall cabinet holes:
Stage 1 complete (time for doors and drawers):
« Reply #16 on: July 25, 2018, 01:48 AM »
Wow looking awesome !!!
Offline jroth33139
« Reply #17 on: July 31, 2018, 10:31 PM »
Clever way to get it down the stairs! I hope you are not moving any time soon!  [big grin]
Offline blaszcsj
« Reply #18 on: August 08, 2018, 11:09 PM »
Yes I hope so!
Minor detour side project...Installed shop dust collection. Oneida V3000. Tomorrow I will install the ivac auto switch for the table saw. Came out pretty well. The floor sweep is amazing! It took about 2 hrs to assemble the unit and 3-4 hrs to fab the wall brackets and do all the duct work.
Back to the syscabinet tool wall build!
« Reply #19 on: August 09, 2018, 10:28 AM »
DC looks awesome and very professional!
Matt
Offline jyarbrou
« Reply #20 on: August 09, 2018, 10:31 AM »
Where did you source your duct work and what gauge did you end up using?
-Eric
Offline Dick Mahany
« Reply #21 on: August 09, 2018, 10:41 AM »
Great job and the shop is coming along nice!  I used to have a steel Oneida V3000 and it was excellent.  I have read that the conductive plastic models are supposed to be quieter.  Keep the pics coming.
« Reply #22 on: August 10, 2018, 11:38 AM »
Nice job on the jigs & fixtures. Clever solution. [big grin]
That K3 looks sweet. I'm Festool green with envy. [smile]
How did the 3M 90 work for the laminate? Is it tough to get uniform spray coverage?
Offline greg mann
« Reply #23 on: August 10, 2018, 12:13 PM »
Amazed at how much it warped after install (fisheye shot)! How did you get it all straightened out again? [poke]
Greg Mann
Oakland, Michigan
Offline blaszcsj
« Reply #24 on: August 11, 2018, 01:33 PM »
Ducting was sourced thru Oneida (24ga spiral duct) with unions from Rockler. Both have similar costs but I went with Oneida because shipping was marginal when buying the system. The floor sweep is super fun to use. It sucks dirt from like 6 inches from the opening.
I use the fastcap speed roller.
Thanks! I have since ditched the spray opting for the gallon bucket of the 3m adhesive. I found it was much easier just to roll it than spray. Coverage was not too bad with the can because the nozzle was adjustable. just a pain after it starts getting low or the nozzle gets clogged.
It is surprisingly quite. One reason why I opted for this one. This past week I added the ivac pro contactor kit and added an inductance switch on the tablesaw for auto start. Works like a charm.
Offline JBag09
« Reply #25 on: August 12, 2018, 10:05 PM »
Very nice. I just installed the V5000. Used all pvc, and blast gates from Lee Valley. Oneida was great to deal with.
Offline mike_aa
« Reply #26 on: August 13, 2018, 04:41 PM »
@blaszcsj
Excellent build.  I really like how you built the roll-around tool cabinets right into your wall.  Did you just run the kickboard across or remove the casters and mount them on a base?
Nice installation for the dust collector.  It looks like the V3000 can be mounted lower (my clearance is about 7 feet).  How high is your ceiling?
Thanks!  Mike A.
Offline Kevin D.
« Reply #27 on: August 13, 2018, 11:18 PM »
Nice work.  Keep it comin'!
Kapex, CT-SYS, SYS-Cart, Pro 5 Sander, CT36AC, TS75, MFT 1080, MF-SYS/2, PS300 EQ-Plus, Parallel Guides Set, LR32 SYS, RO 150FEQ-Plus, OF1400 EQ Plus, DOMINO 500 Q-Plus,  Domino XL, MFK 700 EQ-Set, FS-SYS/2, CT22 w/hose storage, D36HW-RS-Plus, FS 1900/2, FS 3000/2, FS 1080/2-LR32, FS 1400/2-LR32, Gecko, Festool Floor Mat, Festool Stein, Multi-Tool, tape measure, large and small Festool floor mats (foam rubber).
Offline blaszcsj
« Reply #28 on: August 14, 2018, 11:23 AM »
@blaszcsj
@mike_aa
Thanks!  Mike A.
Yep pretty much. Base with the cabinets, no casters, and screwed it to the lumber racking behind it. I did have to make a spacer because it was two lower cabinets.
My ceiling height is 89”. You could probably get away with 86-87 if you cut a little bit out of the vacuum tube between the collector and bin. You need one inch clearance from ceiling. Went with the wall mount so I could adjust the setup a bit more.
Quick tip if you do get one, install motor/fan on inlet section before installing the inlet section. You will also need the ivac pro contactor version if you want tool activated dust collection.
Offline mike_aa
« Reply #29 on: August 14, 2018, 12:36 PM »
Thanks for the response!  Sadly, my ceiling height is only about 84 inches so it might be too tight.  It's going to be a while before I'm ready to upgrade so no rush on this purchase for me.
Thanks, Mike A.
