Author Topic: What about a show your toolbox thread?  (Read 30523 times)
Offline WastedP
Re: What about a show your toolbox thread?
« Reply #30 on: June 28, 2016, 08:03 PM »
I wish doctors in ER using this type of system so they did not forget surgery knife in patient bodies. LOL.
In the hospital I worked in, every surgical tool and rag had a barcode on it that was scanned with a handheld Symbol unit when the item entered the operating theatre and scanned again when it was put in the bin for sterile processing.  Things that were intended to be left inside a patient were also scanned.  There were PC workstations in each OT where the surgical tech responsible for keeping track of inventory could double-check stuff, and even send the info to a monitor on a boom arm next to the cutting area.  They were big on lean manufacturing processes to cut costs and errors in surgery, but the enthusiasm for efficiency never made it to the managers of the on-site cabinet and countertop shop.
Online RKA
« Reply #31 on: June 28, 2016, 09:09 PM »
You know, it's funny, my auto related tools are in a large KRL toolbox, mostly organized neatly as Oliver's is.  And everything gets wiped down before its stowed.  The deeper drawers invite some chaos.  For years I had inadequate storage and things were all over the place and now everything for working on the cars fits in the box with room to spare.
But the woodworking tools...I only have a small tool box in the basement and everything else is scattered everywhere...complete chaos!  Like a hoarders episode.  Need to build some tool organization down there!  There is no horizontal surface that doesn't have stuff on it.
-Raj
« Reply #32 on: June 29, 2016, 10:35 AM »
Found a great video on Snap-On's ATC Level 5 - Just in case anyone else is interested.
Thanks for posting Oliver, I didn't know Snap-on offered this service.  [thumbs up]  It's pretty user friendly and transparent except for that nagging voice in the background. Strictly a vision system application.
Way better than scanning with a Symbol scanner all the time, that'd certainly become a PITA.
Offline BadRobot
« Reply #33 on: June 29, 2016, 07:02 PM »
This is my custom built Sys Port.  It built from 80/20 T-Slot Aluminum Extrusion.
Offline BadRobot
« Reply #34 on: June 29, 2016, 07:07 PM »
This is my woodworking measuring tools.  I don't have much space on my wall.  So I stacked them up.
Offline Knight Woodworks
« Reply #35 on: June 30, 2016, 09:34 AM »
Bad Bot,
Like that Sys Port built with 80/20, got any more pics?
John
« Reply #36 on: June 30, 2016, 11:58 AM »
@BadRobot
I also like 80/20 SYS Port. How are the shelves/drawers held in?
Offline BadRobot
« Reply #37 on: July 10, 2016, 05:24 PM »
@BadRobot
Here they are.
This is the first generation.  I am working on dual stack that can fit both Systainer and Harbor Freight storage boxes in the same rack without each horizontal t-slot for each rail.
« Reply #38 on: July 10, 2016, 05:46 PM »
Got it, thanks...so you're just fastening the slides directly to 80/20 side supports?
Offline BadRobot
« Reply #39 on: July 10, 2016, 05:55 PM »
Yes, based on this version, I just adjust the T-Slot side rail up or down.  So I don't have to pre-drill holes as plywood.  The second version does not use horizontal side rails.  It drives the cost down a lot.
« Reply #40 on: July 10, 2016, 06:00 PM »
Thanks for the show and tell, that's pretty cool.
John
Offline leakyroof
« Reply #41 on: July 11, 2016, 09:43 PM »
2 drawers only for now. Screwdrivers and Pliers or 'plier-ish'
Offline leakyroof
« Reply #42 on: July 11, 2016, 09:46 PM »
Pliers. Only the most used ones get the tidy-out in front location of the drawer.. [wink]
Offline typeshige
« Reply #43 on: July 12, 2016, 01:02 AM »
Regarding that 8020 one, what's your method of making accurate repeatable cuts to the T slots?
That looks great and hopefully you don't mind others borrowing some ideas!
Offline BadRobot
« Reply #44 on: July 12, 2016, 11:55 AM »
There are 2 methods that I can think of.
1. Buy t-slot from 80/20 with the length you need.  So it is pre-cut and square with pre-tab and counter bore as option.  Just kidding but it work if you don't do a lot of cutting, it might be cheaper.
2. Buy aluminum blade and put it in TS 55 REQ.  Then cut to specific length on MFT/3.
I don't want to steal this thread.  I will create a new post for 80/20 Sysport after I take an exam this week.  I have 2 versions of 80/20 Sysports.  One is what you saw here.  Another one is double stack.  I can put either Systainers or Harbor Freight storage boxes in the same rack.  I also made 80/20 gig to drill counter bores and holes for end fasteners on a drill press.
« Reply #45 on: July 12, 2016, 12:52 PM »
Here are 2 more...put a Festool aluminum blade (495385) on a Kapex or invest in a low RPM chop saw and cut all metals including stainless.
« Last Edit: July 12, 2016, 12:56 PM by Cheese »
Offline BadRobot
« Reply #46 on: July 12, 2016, 05:30 PM »
This is mine.  If the aluminum extrusions are long, I just connect one side to my Sysport which has a horizontal bars so I can cut up to 110" long.
Offline Kevin C.
« Reply #47 on: July 15, 2016, 04:53 PM »
My first toolbox. Built in 2006. Maple veneered baltic birch. Walnut handles and full extention drawer slides. Holds all my mechanics tools, and plenty of woodworking tools as well.
Offline HarveyWildes
« Reply #48 on: July 19, 2016, 12:29 PM »
When I built my bench, I built a tool box to fit underneath.  When I first built it, there was plenty of room, but now it's crowded and I need to figure out what I want for my next toolbox.
248024-0
248026-1
Offline Michel
« Reply #49 on: October 30, 2016, 12:21 PM »
I think this is my first post on the FOG. Ive built this toolbox to bring the handtools I use in school everyday. I also bring a combi systainer with a cxs, hearing protection, drills, bits etc. Ive been a carpenter for 10 years, and back problems made me start in school again. If everything goes well, im an educated cabinetmaker/furnituremaker in march 2018. And now to the toolbox ! :)
The box is inspired by Tom Fidgens Cabinetmakers Toolchest, from Unplugged Workshop. It is made from danish oak and american walnut.
« Last Edit: October 30, 2016, 12:28 PM by Michel »
Offline SRSemenza
« Reply #50 on: October 30, 2016, 12:24 PM »
The box is inspired by Tom Fidgens Cabinetmakers Toolchest, from Unplugged Workshop. It is made from dansih oak and american walnut.
Hi Michel,
    Very nice and great first post!!  [thumbs up]
Offline RickyL
« Reply #51 on: November 12, 2016, 05:35 PM »
This is my "home" toolbox. In the workshop I have, 9 boxes!  :-[
TXS, TSC 55REB, CTL Midi, BHC 18, C18Li, T18+3, PSC 420EB, Kapex KS120 EB, OF1400, EHL 65 EQ, ETS EC150/5, RO150 FEQ
Offline Michel
« Reply #52 on: November 13, 2016, 11:50 AM »
That my friend, is either a very large toolbox, or a very small workshop ! :)
Offline RickyL
« Reply #53 on: February 26, 2017, 04:46 AM »
Heres one wall at work the other wall is the same.
Offline demographic
« Reply #54 on: June 18, 2017, 02:09 PM »
Toolbox eh?
Main one is the van, then there's a large toolsafe in it.
this is pretty much the van contents...
Everything in this stack in the centre of the photo fits into the toolsafe...
and this, although its my old van that I no longer have (sames true for the dog sadly) it shows the toolsafe.
That toolsafe holds a fairly serious amount of kit, its not always easy to get at but its always pretty secure, which matters a lot to me.
Offline Trevin
« Reply #55 on: June 19, 2017, 03:32 PM »
Well this is still work in progress but have some of the drawers done.  I really like the Kaizen foam.
Thanks,
Trevin
Festool: MFT3 (x2), OF1010, OF1400, LR32, Domino DF500, Domino XL DF700, Kapex KS120, TS-75, Carvex 420, CXS, C-18, Vecturo OS 400, DTS 400, Pro 5, Rotex 125, VAC-PMP, VAC-SYS-1, VAC-SYS-2, CT-26 (x2), CT-SYS, SYS Light DUO, SYS-ROCK
Other: Minmax FS41, Sawstop PCS (3HP, 52"), Laguna BX14, Jet 17" Drill Press, Rikon 70-220VSR Lathe, Incra LS Router Station, Laguna P/Flux 3 Dust Collector
Offline Mitchewd
« Reply #56 on: June 20, 2017, 12:15 AM »
Added my take on a Dutch tool chest HERE
I am working on a rolling sys-port cart with a fold up tray...almost done!
