Had to take some time away from the shop but was finally able to get the cabinet boxes built and mounted. Used maple plywood and edge banded it in walnut. Time to start building the drawers.
Quick question on these if you have a moment. I am new to woodworking and am working on various sysports myself, including considering a multi column sysport. Here is what I have been wondering in planning this and what I think about when looking at your design...
1. It looks like your end panels are the same length as your center dividers. Whereas I had in mind that cabinets are best constructed where the end panels run the full height of the cabinet. So the top and bottom would attach to the inside face of the end panels, rather than rest on the top of the end panels as your do. Was this done for a particular reason? Is one design better than the other?
2. How are your stretchers in the back attached? It seems that if pocket screws are used that the pocket screws would interfere with each other where the stretchers meet at each interior vertical panel. Hope this makes sense.
Great finished product and thanks for your comments, or anyone else who would not mind commenting.
Thanks!
