Author Topic: Senco 1010 in a Sys 5  (Read 16670 times)
Offline D Wood
« on: August 23, 2014, 06:02 PM »
Picked up a Sys5 yesterday to put my Senco 1010, Grex and a 25' air hose in. I think there is even room for another Grex [eek] 200170-0200176-1200174-2
« Last Edit: August 24, 2014, 09:36 AM by Dunn wood »
Offline duburban
Re: Senco 1010 in a Sys 4
« Reply #1 on: August 23, 2014, 08:52 PM »
nice. Too bad my jc10 won't fit in one of those. I used a friends 1010 once and found it slow… but great for smaller guns.
helper: i used a festool "circular saw" to do something simple and it made it really hard
me: exactly, it makes simple cuts complicated and complicated cuts simple
Offline BBuild
« Reply #2 on: August 23, 2014, 09:29 PM »
Are you sure that isn't a sys5? I just tried my 1010 in a sys4 in that configuration and I couldn't close the lid. I also had to remove the rubber feet and it still seemed to bow the front a little.
Kapex w/MFT-k &  crown stops,  TS 55,  MFT-3,  MFT-800,  CT 26 w/ rrp HEPA,  CT 22 w/ LL bag,  CT Midi,  CXS,  RAS 115 w/ plug it,  RO 90,  ETS 150/5,  ETS 125,  RS 400,  EHL 65 w/ plug it,  HL 850 w/ bench unit,  OF 1010 w/LR32
Offline D Wood
« Reply #3 on: August 23, 2014, 10:03 PM »
I stand corrected, Sys 5. Although it would fit into a sys 4 without the hose. I did cut the handle on the compressor and welded it back on to prevent the bowing. It fits in with the rubber feet at the back. I figured since it had to be on all feet to drain the tank once in a while, there was no use mounting it into a sys. And besides, where would all the moisture go? I only use this one for a 23ga pinner, so it is more than capable, and quiet.
2 bars = sys 3
3 bars = sys 4
4 bars = sys 5
This thanks to Shane's post about how to tell which sys from a distance. always one short.
Offline Samo
« Reply #4 on: August 24, 2014, 12:08 AM »
Yeah Wood,
Nice tool to have for small air tools on install jobs because it fits in a Systainer.  Most guys cut the bar off and put it in right side up  [scratch chin]
Cheers, Sam
It's The FOG!  Just rotate the screen.
Offline D Wood
« Reply #5 on: August 24, 2014, 12:15 AM »
Yeah Wood,
Cheers, Sam
Thanks Samo
Offline Samo
« Reply #6 on: August 24, 2014, 12:20 AM »
You are very welcome  [smile]
I like your sig. and your aviator too  [big grin]
Offline D Wood
« Reply #7 on: August 24, 2014, 12:23 AM »
That's my faithful helpers. They keep me sane.
« Last Edit: August 24, 2014, 12:25 AM by Dunn wood »
Offline wow
  • Inactive Member
« Reply #8 on: August 24, 2014, 02:08 AM »
I hadn't noticed your signature until now:
"Kapex, MFT, CT22, CT33 and boom, CT36, TS55, TS75, PSB420, MFK700EQ, OF1400EQ, Domino, RO90FEQ, ETS125EQ, 5 rails and case, Systainers, Cooltainer, T-shirt, Festool mat, Tanos, Mirka, WOW first aid kit."
I have to tell you that brought a smile to face, and gave me goosebumps all over! Thank you for that!
Offline D Wood
« Reply #9 on: August 24, 2014, 09:33 AM »
You are welcome for that, the first aid kit is pretty impressive.
« Last Edit: August 25, 2014, 01:45 PM by Dunn wood »
Offline woodbear
Re: Senco 1010 in a Sys 5
« Reply #10 on: November 11, 2014, 03:49 PM »
I have a senco 1010 in a systainer classic 4 for over 10 years and with the handle cut off, i fit a 25' urethane hose and a grex 23 gauge pinner and a ridgid 2 1/8" brad nailer.  i guess the classic has more room in the right places to accomplish this. i did have to put the compressor in a certain way otherwise it bulged the side out, i put in 180 degrees and it fit.
Offline @linesbymiguel
« Reply #11 on: April 04, 2015, 11:09 PM »
218314-0218312-1
got my senco and cut the round ends in the tank and welded a flat piece , now I'm able to fit the compressor sideways.
so now I fit the compressor, two air hose, two nail guns
plus I replace the top lid with a lid that has an attic so it allows me to store my nails.
everything is so compact that I may even be able to use a sys4 and save space on my shelves.
@LINESBYMIGUEL
« Last Edit: April 11, 2015, 10:05 PM by @linesbymiguel »
Offline joiner1970
« Reply #12 on: April 05, 2015, 04:44 AM »
I got my senco and cut the round ends in the tank and welded a flat piece , now I'm able to fit the compressor sideways
Now that's extreme modding :)
Used my new setup the other day on site for the first time and it was great. Wish I'd just bought a senco years ago when I first saw one.
I just need to notch out the sys5 for the power cable and maybe put a grommet around the cable
Offline MGB
« Reply #13 on: April 10, 2015, 09:00 PM »
have you guys made any provisions for ventillation? those little guys can get pretty warm.
Offline Mkholdings
  • @mkholdings123 (instagram)
« Reply #14 on: April 11, 2015, 12:02 AM »
I puta small compressor in a sys #5. And I put the sys mft top lid for ventilation
Offline johnesher
« Reply #15 on: May 22, 2015, 09:07 PM »
Have you had any trouble running the compressor in the Systainer? Just picked up a Senco 1010 and thinking about putting it and the hose in a Sys5 and my guns and nails in Sys4. Even maybe going so far as to run an electrical port though the side for the compressor. My concern though was ventilation, so the MFT top is a great idea!
« Last Edit: May 22, 2015, 09:17 PM by johnesher »
« Reply #16 on: May 22, 2015, 10:02 PM »
I have the compressor two brad nailers and a 50 foot and 25 foot hose and it all fits in the sys5, I have not had any heating issues
Offline joiner1970
« Reply #17 on: May 23, 2015, 03:39 AM »
Same here and no problems so far. I put an inline connector on my cable so this and the hose all fit through the central mft lid hole. Not sure but guessing your US style plugs fit through that hole anyway so no need for a connector
Offline Mahomo59
« Reply #18 on: May 23, 2015, 05:10 PM »
Does the handle have to get cut off?
Midi, TS55, 2x 1400 rail, Kapex, UG stand, Carvex 420, EHL65, ETS125, Domino df500 Cleaning kit...
Offline joiner1970
« Reply #19 on: May 23, 2015, 07:12 PM »
No just took the feet off mine
Offline Mahomo59
« Reply #20 on: May 24, 2015, 11:55 AM »
Brilliant I'll get a sys 5 when my Senco is back from repair! Only 6 months old, developed air leak under on:off switch box thingy. Assuming there will be enough room on top for two guns and a mini sys or two for nails?
Offline joiner1970
« Reply #21 on: May 24, 2015, 01:05 PM »
A bit tight I'd have thought. All I have in my sys5 is the compressor , hose and lead. I could probably squeeze one gun in . Better to keep them in another sys on top
