Busy weekend in the shop & finishing one work area in my office/workshop. I had some old cabinets I built a long while back for the big shop before moving to the shore & the little shop. They got re-purposed into my office mainly because I did not have anywhere else for them. This area is dual purpose, during the day I have a place to spread out files (my work table/desk is nearby), while at night I can monkey around with my little gadgets or do leather work, tie flies, etc. The top does not need to be fancy but I wanted it to look okay, the cabinets probably need a fresh paint job. I finally got around to making the top for them this weekend and midway thru yesterday I thought it was going to be a disaster, in the end it turned out okay.
This relates somewhat to this thread because I used the the cutting extensions in a couple new ways for some awkward cuts. In this setup I needed to trim one leg of a mitered corner piece after I had glued up the miters:
These pieces were between 5-6' long so I used my 2700mm rail, the extensions also supported the end of the rail. I then had to cut them to length so I just flipped the material around and used the Woodpecker square to align the short rail:
Lastly, while the MFT is not a great platform for hand planing it works in a pinch, I have one oddball extension where I had tried gluing 1/2 by 1/2 maple strips to it before I settled on using the MDF, I use it for stuff where I need to clamp something to the side:
The net result worked out okay:
In case you didn't guess, the material is 5" Jatoba flooring I picked up on closeout. The cabinets sit 3" out from the wall so I have space to run wire/cable behind them, there are 2 sections that pop out for access.
Not bad for < $100 in material, pre-finished to boot!
RMW
