Here's my old MFT setup from 8 years ago. Something I've talked about but haven't really shown until now with the help of SketchUp.
On Edit:
Turn Closed Caption ONSpecial Thanks for SketchUp models:
Brice Burrell for his MFT and TS55 model
Jonathan S. for his Festool Clamp and Systainer models
judedouch for the Incra Tracks and Stops
Da Addicts for the Rockler Cam Clamps
The cam-clamp dogs were something I had made working prototypes of, but hadn't made the part as you see in the animation. This style of dog will be useful in attaching anything to your MFT's grid of 20mm holes.
The fenced sled can be used for narrow rips, pieces narrower than the Rail, and also to align your Guide Rail square to the fence. I also use this type fence in conjunction with
my Parallel Jig to make those longer rips.
The zero-clearance fence is the 'old-school' type where you have a replaceable middle section. Here it can be swapped-out with one for the thickness material you are cutting. I make 'stock' to cut the various sizes from.
Initial setup of the Incra Incremental Tracks is to set the left-hand track 2" back from the Guide Rail (using a machinist's 1-2-3 block) to provide clearance for the saw.
The Incra Tracks on this fence can be swapped-out for the Tracks used with their FlipStop, Tracks that are longer, or Tracks setup with metric scales and racks.
