Svar - I really like some of those thinner profiles @ techno-isel.com, they look useful. I am too heavily invested in 80/20 1515 profile to switch to the Bosch, and 80/20 is easily available here on eBay.
Here is another setup used to extend the MFT for longer cuts. My little shop is 11'9" inside (@ widest) so there is no room for a permanent bench larger than the MFT. The work-around is this extension that attaches with 2 knobs/t-bolts. Height is adjustable so the extension arms (w/MDF) can be lowered to the same height as the MFT top.
Shown is cross-cutting 96" material:
There is plenty of room to work between the MFT and the built in drawers, however you can just squeak by 8' material to get in/out the door.
After cross-cutting the arms are removed from the MFT, clearing it for other operations like mitering with the Rip Dogs, while leaving the extension on the MFT to use for routing/sanding/painting.
When done the extensions knock down in 10 minutes and go back to their place on the wall, taking up very little storage area.
RMW
