Thinking about this further, maybe I should run a quick comparison of a Trion, a Carvex and a Mafell. I’d probably use the same new Trion blade on all 3 saws.
A dust removal comparison will be interesting.
That would be cool if you did that. Interesting too...
Hey
@leakyroof Yesterday I was cleaning up the Carvex & Trion so I could put them down the road. Then I remembered this thread from last year and decided to run a quick comparison of dust collection between them and the Mafell P1 cc.
Some standards were set:
1. A new Festool Trion S 75/4 FSG blade was used on each saw.
2. No orbital action was used.
3. All 3 saws were set to approximately the same speed.
4. No chip guard was used.
5. A triggered CT 22 on max suction was used on each saw, that way the length of time the vac was on was approximately equal.
6. A scrap 7" wide piece of 3/4" ply was used.
Carvex photos 1-3, Trion photos 4-6 & Mafell photos 7-9. The stunner is when you compare photos 2, 5, & 8 to each other. There's a channel inside of the base of the Mafell that blows the chips across to the extraction point on the other side. Photo 8 says it all.
Interestingly enough, the Carvex leaves the most amount of dust on the cutting surface while the Trion leaves the most dust on the floor. Also, the area of dust on the floor is similar between the Carvex & Trion.
