Ha, I'm the market as well for rebuilding a TDK 15.6 pack.
I've taken it apart already and it contains (as expected) 13 unmarked Sub-C cells.
Welding those lips would be nice, but getting the equipment to do that...
I guess one can just as well solder them together with copper wires, with the use of a huge solder iron. The bigger and more powerfull it is, the shorter you have to put it on, the less heat will go into the cell.
Since the TDK was also sold in a Ni-Mh version and since both had the same charger, there shouldn't be a problem when you swap them out for Ni-Mh. Don't really know why you would want to do that though, except for the higher capacity. Isn't Ni-Cd more suitable to deliver high currents?
For €2.80 I can get Sanyo 1900 mAh Ni-Cd cells, for €3 I can get the 2500 mAh ones, while the 3000 mAh Ni-Mh ones would cost me € 4 a piece.
Times 13 that would be €36.40 / €39 / €52
A brand new Festool pack (3000 mAh Ni-Mh) would cost me € 142
So.... the latter isn't gonna happen
