I am quite a bit different. I have two biscuit joiners and havent used either is 8 years or so. For edge joining for panel glue up, I much preferred using the router table and a 5/32" slot cutter. I found that to give better alignment. And I havent used that since the arrival of the Domino which I find gives me a tighter alignment and glueup.
John,
Is your shop, hobby, or business? What have you built in that time period?
A cabinet maker without a biscuit joiner, will make about as much money, as a Mechanic who chooses to use a crescent wrench instead of an incremental set.
In the case of the "Domino" or the "Biscuit Joiner"
First, I admit, I do not own a Domino (yet) But my experience with the Lamello machine goes back a long way. IMO the Lamello machine changed the way we make things out of wood, and it has become a must have in a commercial shop. I can't see how the Domino can match the Lamello in speed and material cost in some applications.
Mirko
Now that I have the Domino I would like to bump this thread, and share my thoughts on having used both machines now.
When I quoted this: "I can't see how the Domino can match the Lamello in speed and material cost in some applications." I could'nt have said it anymore diplomatic.
For me, it is more convenient to have BOTH. #1, i've been using the Lamello machine for 20 years so I can't give up the comfort and confidence I have in that machine.
Others have mentioned the issues when using thinner stock and I much prefer the Lamello. If I need some play in the face of a joint, I like to hammer the biscuits on a piece of steel, or a concrete floor to crush them. And lastly the Lamello is a tough little machine, I would trust anyone to use it and understand its functions.
The Domino,
I would NEVER lend out, or let an employee touch, because it seems delicate. I am extra carefull to unplug dangling cords that could trip up and pull the Domino off a bench... Ouch!! not looking forward to that day!
I would say that 20% of the Domino's functions correspond with the Lamello, So why not just let the Lamello handle the 20% that its very good for, and hey if that clumsy employee drops it, I can borrow one, from any woodworker I know.
The Domino is for seasoned woodworkers, the margin for error is much higher than the Biscuit joiner, therefore giving a novice a 20 second demo is out of the question.
If I had to explain to someone how to make a mortice and tenon joint using the typical machines required, the 5-10 min explanation the Domino needs wins hands down.
Mirko
