Author Topic: Kapex extension wings on MFT/3?  (Read 14391 times)
Offline Hans Mertens
    • my company's website
« on: October 07, 2009, 01:48 AM »
Hello,
Can somebody who has  the extension wings for the Kapex test that these fit on the MFT/3?
And are they flush with the tabletop or recessed and how much then in mm?
Thanks in advance!
Offline greg mann
Re: Kapex extension wings on MFT/3?
« Reply #1 on: October 07, 2009, 03:13 PM »
Flush. They make a nice place to hang a Festool clamp out in space if you need to do so for any reason. I have used my MFT fence as a long extension fence for the Kapex and have also mounted the Kapex wing on the MFT and, along with the other on the saw, was able to clamp an extrusion between them on which I could mount a length stop. It was a makeshift set up but got me through a need.
Greg Mann
Oakland, Michigan
« Reply #2 on: October 08, 2009, 01:35 AM »
Thanks Greg,
That's the answer I was looking for.
Cheers
Offline paul_david_thomas
« Reply #3 on: October 08, 2009, 03:36 PM »
Yeah, just tried it out... rather useful !
TS55, MFT/3x2, Domino, CMS, C12, RO150, RTS400, Kapex 120, CTL26, OF1400 & Two German Wirehaired Pointers :-) They really help !
Offline grbmds
« Reply #4 on: May 04, 2014, 04:54 PM »
I know this thread is old, but does Festool sell either the left or right extension for the Kapex separately? Do these still install on the MFT3 the same way they would install on the Kapex MFT?
Randy
Offline Tom Bellemare
  • Inactive Member
« Reply #5 on: May 04, 2014, 04:56 PM »
Yes and yes
Offline grbmds
« Reply #6 on: May 04, 2014, 05:02 PM »
Can either just be ordered from a Festool dealer by using the part number quoted on the Festool Kapex accessory page?
Randy
Offline RKA
« Reply #7 on: May 04, 2014, 06:24 PM »
Yes
-Raj
Offline copcarcollector
« Reply #8 on: May 04, 2014, 06:30 PM »
If you need  a short extension on your MFT, for example a place to clamp material while using the Domino, the Kapex Crown Stops also work! As demonstrated by Steve Bace in Henderson...
105488-0
  • Inactive Member
« Reply #9 on: May 04, 2014, 09:00 PM »
Because I transitioned to the UG, I tend to have my Kapex Extensions attached to my MFT/3 for various reasons almost all of the time...
105500-0
They provide the up-facing t-track that was lost in the transition from the previous MFT 800/1080 to the current MFT 3 series. I find that t-track quite useful sometimes, especially at the edge of the table.
They also give a little more horizontal surface for various things. It sounds like an insignificant amount of space but the fact that it hangs off the edge makes it more useful and it's synergistic.
Offline Wonderwino
  • That Green Koolaid causes mutations.
« Reply #10 on: May 04, 2014, 09:12 PM »
UG wings are great on the MFT/3 to the right of the fence for fall-off support when cutting shorts off long stock.
Water separates the people of the world; wine unites them.
Offline tjbnwi
« Reply #11 on: May 04, 2014, 09:59 PM »
The UG wings also fit the MFT 3.
The thumb nut is very close to the clamp grove when the retaining tab is pushed into the MFT. I did sand some of the meat off of the thumb screw to make installing the wings a little easier.
Yes, the wings fit the CMS also.
Offline grbmds
« Reply #12 on: May 04, 2014, 10:11 PM »
DO YOU FIND THE EXTENSION WINGS USEFUL? WHAT MAKES THEM USEFUL FOR YOU? I'M TRYING TO DECIDE IF ONE OR BOTH EXTENSIONS WOULD WORK BEST OR ANOTHER OPTION (LIKE MAYBE A SECOND TABLE SINCE THE TWO EXTENSIONS TOGETHER ARE ABOUT AS EXPENSIVE AS A WHOLE TABLE).
Randy
Offline tjbnwi
« Reply #13 on: May 04, 2014, 10:16 PM »
I find them more than useful. One of my most used Festools.
If you're not to far from the northern Indiana/Illinois border you can stop by and take a look at the set up.
Offline Emer Construction
« Reply #14 on: May 05, 2014, 09:51 AM »
another option is the fastcap best fence setup. I keep meaning to look into that one.
Steven
Offline grbmds
« Reply #15 on: May 05, 2014, 12:31 PM »
Since my only use is in my woodworking shop, I have always felt the most versatile addition would be a second MFT3. The problem is moving it around in different configurations of MFT #1 & MFT #2, meaning retractable wheels on one of them. I still feel that way and the cost of the Kapex extensions seems to indicate that also. Are there ways to attach retractable casters to the MFT legs?
Randy
Offline glass1
« Reply #16 on: May 05, 2014, 12:43 PM »
Will the multiblades kapex wing attachment also fit on the mft ? Will the best fence kapex wing atgachment fit as well ? Thx
Offline iamnothim
« Reply #17 on: May 05, 2014, 05:28 PM »
Where's your MFT/3    [eek]
(Attachment Link)
My reputation pre-deceases me.
« Reply #18 on: May 05, 2014, 05:47 PM »
I just had a friend try the best fence on the mft...he said it didnt work
Steven
  • Inactive Member
« Reply #19 on: May 05, 2014, 06:03 PM »
(Attachment Link)
It's in my shop. It's really not that scary, is it?
