Author Topic: New 45 minute charger  (Read 15211 times)
Offline carlb40
  • Site carpenter
« on: August 11, 2016, 02:13 PM »
Just had a couple of pages on FB show off the new 45 min Airstream  charger - coming soon.  Also some new 18v airstream batteries.
Couldn't see the Ah rating of the batteries.
One thing i don't like is the fact the attachment for the  bumper protectors and often used by me belt clips has been omitted.  [mad]
https://www.facebook.com/Festool-geeks-540172772716232/?fref=nf
Carl
Never never go, never never know [smile]
Flickr
Offline Doug S
Re: New 45 minute charger
« Reply #2 on: August 11, 2016, 03:25 PM »
There is a video of new charger and batteries on festool.com
Looks like t18 will finally get a proper fixed belt clip.
Doug
Offline Kev
« Last Edit: August 11, 2016, 03:35 PM by Kev »
Offline ear3
« Reply #4 on: August 11, 2016, 05:27 PM »
Looking forward to it.  Had the experience for the first time last week of batteries not charging after they'd been in use on the TSC55 -- had to wait for them to cool off and the red light to switch to green on the charging station.  Of course --  I was working out in the sun in 90degree+ temps.
Kapex KS 120 w/UG Cart and Extensions • CXS Set • T 18+3 w/Centrotec Installer's Set • PDC 18/4 • TID 18 • TS 75 • TSC 55 • HKC 55 w/250, 420 and 670 FSK rails • Carvex 420 w/Accessory Kit • Domino 500 Set • Domino 700 XL • OF 2200 w/Base Accessory Kit • OF 1400 • OF 1010 • MFK 700 EQ Set • LR 32 • MFS 400 w/2000, 1000, and 700 extensions • Rotex 90 • Rotex 150 • LS 130 • ETS-EC 150/5 • ETS-EC 150/3 • Pro 5 LTD • RTS 400 • RAS 115.04 • RS 2 • Planex Easy • HL 850 • Vecturo OS 400 • AGC 18-115 • CT 36AC w/BT module • CT Sys w/Long-Life Bag • CT-VA 20 • MFT/3 • STM 1800
Offline yetihunter
« Reply #5 on: August 12, 2016, 12:36 AM »
Are the batteries and charger out sourced?   If so, maybe we can get them sooner? :)
Offline PreferrablyWood
« Reply #6 on: August 12, 2016, 04:50 AM »
I've got 5x 18v and 2x 15v batteries so I won't be buying the airstream until som of the lose their charging capacity, but it is a great improvement for those that demand cordless for heavy use full day, also you will get by with fewer batteries...
TS 55 R EBQ, Vecturo OSC, BHC SDS, RO 150, 850 HL E Planer, MFS 400x2, MFS extensions MFS VB 700 x 1 MFS VB 1000 x 2 . CMS GE, OF 2200, CMS OF+ CMS TS 75 insert modules. SYS-MFT Fixing-Set,
Festool 18V HKC 55, TI 15, CXS 2.6 Ah version, RO 90 DX, PDC 18/4 plus   TS 75 EBQ, PSC 420, OF 1010, RS 300 EQ, CTL Midi, MFT 3
Offline Gregor
« Reply #7 on: August 12, 2016, 07:30 AM »
While it makes sense to actively cool the battery while charging (so you can push more energy into it per timeframe) I see the following downside of the airstream charger:
To (and I admit that this is speculation) never ever use it where you work.
Festool dust collection is great (but not 100%) so the charger will effectively turn the airstream batteries into fine-dust collectors.
Offline carlb40
  • Site carpenter
« Reply #8 on: August 12, 2016, 01:55 PM »
In theory so could any charger with a fan built into it. However i have never had that sort of issue. But then my batteries are either charged at home, or in a room away from the dust making tools :)
Carl
Flickr
Offline six-point socket II
« Reply #9 on: August 14, 2016, 02:41 PM »
Hi!
While I personally try to avoid charging batteries in the same room that I work/ make dust in, I'd hope that this aspect was taken into account somewhere during the designing/engineering process. After all, we're talking about tools for professionals that do site work and I guess it's not always guaranteed/possible that a charger can be placed in a dust free environment.
That said, I'm pretty sure that Bosch's 36V chargers are air cooled by a fan during charging - not sure if the air flows through their battery packs (probably not) - but I never heard/saw complaints about chargers that died from dust.
Then again, you could clean battery packs and charger every now and then with some compressed air - as you probably already do with the tools themselves.
Maybe we hear from Festool about it? It's an interesting question nonetheless for sure.
Kind regards,
Oliver
Kind regards,
Oliver
Offline Phil Beckley
« Reply #10 on: August 14, 2016, 03:07 PM »
Hi
As soon as the UK microsite is ready I will post more detailed information. A video will be available shortly from the UK as well.
Rg
Phil
« Reply #11 on: August 14, 2016, 03:24 PM »
Doug
....and the C18
Rg
Phil
Offline #Tee
« Reply #12 on: August 14, 2016, 03:37 PM »
deng took festool like 100 years to finally integrate the battery life indicator on the battery like normal peoples lol. yes its on the tool but i often have batteries laying around and have no clue how charged it is. thats one sexy look new 18v tho [tongue]
When youre feeling depressed just treat yourself to a systainer even if its a mini systainer its ok.
IG: tee212
« Reply #13 on: August 14, 2016, 03:55 PM »
Hi
Rg
Phil
Hi!
Thank you Phil!
I found the German press release about the AIRSTREAM system: https://www.festool.de/Presse/Presse-Portal/Documents/Pressemitteilungen/AIRSTREAM_0916_DE_ohne%20Sperrfrist.pdf
It states that the air flows through an encapsulated cooling channel that runs between the battery pack's cells (I hope I translated that correctly)
So dust shouldn't be a problem, just as I thought, Festool did take this into account.  [thumbs up]
Kind regards,
Oliver
Kind regards,
Oliver
Offline Mike B
« Reply #14 on: August 15, 2016, 08:51 AM »
Gah! and all this a month after I go all-in on half a dozen 5.2's and an extra charger... typical.
Any information on compatibility? Will standard batteries still charge in the Airstream charger but slower? Or will the new batteries work in the old charger (at slower charge rate)?
Hate to have to drag an extra charger about...
« Reply #15 on: August 15, 2016, 09:13 AM »
Hi!
The new chargers are compatible with the "old" 12, 15 and 18V battery packs per Festool's press statement.
Kind regards,
Oliver
Kind regards,
Oliver
Offline Shane Holland
  • Festool Dealer
« Reply #16 on: August 15, 2016, 09:15 AM »
Compatible and able to charge faster might be two different things though.
The Tool Nut
ToolNut.com
877-866-5688
« Reply #17 on: August 15, 2016, 09:22 AM »
Absolutely. It's my understanding that if you want to charge "old" battery packs faster you go for the new TCL-6 charger. If you use the new Airstream charger ASC 8 with "old" battery packs it will be just compatible. Like I said, just my understanding from the press statement. It's still possible that also the ASC-8 will charge "old" battery packs faster.
But at least we don't need to worry about compatibility, and that is what was asked :)
Kind regards,
Oliver
« Last Edit: August 15, 2016, 10:06 AM by six-point socket II »
Kind regards,
Oliver
Offline Mike B
« Reply #18 on: August 15, 2016, 10:05 AM »
Good to hear, thanks!
« Reply #19 on: August 15, 2016, 01:25 PM »
Hi
Rg
Phil
Hi!
Thank you Phil!
Kind regards,
Oliver
.....correct. The air runs through a channel
Dv
Phil
Hello from Germany..... [wink]
« Last Edit: August 16, 2016, 03:04 AM by Phil Beckley »
« Reply #20 on: August 15, 2016, 01:34 PM »
.....Li ion will charge on the AS charger at 8ah.
RV
Phil
CORRECTION
The 5.2 will charge at 8A the 4.2 and 3 will be charged at 3A
rg
Phil
« Reply #21 on: August 15, 2016, 04:32 PM »
Hi
Rg
Phil
Hi!
Thank you Phil!
Kind regards,
Oliver
Dv
Phil
Enjoy your stay, Phil!
I guess you've been to Germany numerous times - and I also guess you've done your fair share of sight seeing in the surrounding area of the Festool HQ? If you have some spare time & like fast cars (namely: Porsche) - the 40km distance from Wendlingen to the Porsche Museum in Stuttgart is well worth the drive - as is the Mercedes-Benz Museum (that lies exactly on the route) And you'll get a 25% discount if you show your ticket from Mercedes at Porsche (or vice versa, it's a currently running promotion)
But you've probably been there, I guess - not a real insider tip by any means ;)
Kind regards,
Oliver
Kind regards,
Oliver
« Reply #22 on: August 16, 2016, 03:05 AM »
Hi
Please see below my correction
CORRECTION
rg
Phil
Offline Bash
« Reply #23 on: August 17, 2016, 07:12 AM »
What are the dimensions of the new chargers and batteries?
Will they fit the current systainer inserts?
« Reply #24 on: August 18, 2016, 02:25 AM »
Well..I have heard rumors that Festool will soon launch new screwdrivers whit the new batteries, Perhaps it is rather given to launch new cordless drills now when they have release new batteries? Their current Driver's are at the stone age compared to all other brands, so they need to be updated and refreshed!
Anyway I look forward to new toys.. and i really hope they come out whit a brushless Cxs soon! i love that drill but mine is almost worn out, and i will not buy a new one untill festool relese a new model thats for sure!
....nothing planned in this area to update the 'stoneage' drivers  [wink]
rg
Phil
« Reply #25 on: August 18, 2016, 02:28 AM »
.....overall size is as follows
240lx80hx100w
As they are longer than the TCL 3 they will not fit the current insert. Machines supplied with the AS charger will have a re designed insert
rg
Phil
Offline mrB
« Reply #26 on: August 18, 2016, 08:22 AM »
"stone age drill/drivers".  Ha! I would not agree with that. I have not used a drill i prefer than either my T18 or CXS in their respective class. And I've used a lot of drill/drivers.
 I do think an option for the drills to come with the smaller 2.6ah batteries would make sense. The 18v drills are a lot comfier in use with these batteries.
  • Festool Dealer
« Reply #27 on: August 18, 2016, 09:30 AM »
What needs to be updated or refreshed? They put holes in stuff and drive screws.  [huh]
Just because other brands have a new flavor-of-the-month all the time with new models, they don't change the functionality.
The Tool Nut
ToolNut.com
877-866-5688
« Reply #28 on: August 18, 2016, 09:42 AM »
well stoneage drill was litte overdo so i apologize for that  [smile]
....made me smile  [smile]
rg
Phil
Can we try and keep this thread focused on the charger please  [wink]...but still no current plans on the drill drivers ....
Offline amcore
« Reply #29 on: August 18, 2016, 09:48 AM »
now i have remove my toughts.. but the quotes are still there!
Festool addicted!
