Author Topic: Vac System Bracket for MFT  (Read 2096 times)
Offline Kurtt
« on: December 17, 2018, 11:56 AM »
I am trying to find the post that has the instructions on how to build the Vac System Shop made bracket for the MFT. I am new to the FOG and would appreciate any guidance. Thank you.
Offline DynaGlide
Re: Vac System Bracket for MFT
« Reply #1 on: December 17, 2018, 12:31 PM »
@Kurtt http://festoolownersgroup.com/festool-jigs-tool-enhancements/vac-sys-shop-made-bracket-for-the-mft/
I made one but found it had a little too much flex on the MFT/3 profile.
Instagram @matts.garage
Offline rst
« Reply #2 on: December 17, 2018, 05:51 PM »
289112-0   289114-1  I used 8020 1530 series extrusions to make my outriggers, I have two for the two stations I use.
« Last Edit: December 17, 2018, 05:54 PM by rst »
Offline Kurtt
« Reply #3 on: December 18, 2018, 12:30 PM »
Offline Kurtt
« Reply #4 on: December 18, 2018, 12:31 PM »
(Attachment Link)     (Attachment Link)   I used 8020 1530 series extrusions to make my outriggers, I have two for the two stations I use.
Perfect Just what I was looking for. Thank you.
Offline grbmds
« Reply #5 on: December 18, 2018, 02:56 PM »
It works great! Keeps the Vac Sys out of the way when not in use and it's always there when I need it. I have never had a problem with flexing.
Randy
Offline gunnyr
    • Compass Custom Creations
« Reply #6 on: December 18, 2018, 07:08 PM »
I had the same issue.  I saw @Sedge at a demo earlier this month and he showed me how he places the bracket over a leg and inserts a shim to reduce the flex.  I made mine out of a 9x18 piece of corian.  I will likely rabbet it to fit my MFT so that I don't need to use a shim.
The nut that you see on Sedge's bracket is called a Low-Profile Narrow-Base Weld Nut, p/n 98001A135, they are $7.68 for a pack of 25 from McMaster-Carr.
« Last Edit: December 18, 2018, 08:18 PM by gunnyr »
Semper Fi,
Jeff
TS 55 REQ|HKC 55|PSB 420|DF 500|ETS EC 125/3 EQ|ETS 150/3|ETSC 125|DTSC 400|RO 90|RO 150|OF 1400|MFK 700|LR 32|MFS 400/700|CXS (2)|PDC 18|DWC 18-4500|CT MIDI|CT 26|CT 48|MFT/3 (2)|VAC SYS-SET|STL 450|DUO-SET|SYSLITE KAL II
