Author Topic: 10% angle in 4" stock  (Read 2506 times)
Offline Iceclimber
« on: December 11, 2014, 01:30 PM »
I need to join two pieces of 4" stock together.
Actually i don't a friend does and thought of me and my tools as he does not have a tool capable of such a cut.
I have a Kapex and a TS 75. I am not sure as to the cut capacity of the Kapex at sucj a angle as its fairly new and i have yet to use it in such a manner.
I also am not sure what the TS75 can do. My. Guess is it will come up a bit shy of the depth of cut needed. From what i understand the cut needs to be jointable..
Kapex, MFT/3, MFT, CMS VL, 1400, TS75, Carvex420, CXS, DTS 400, Midi, CT36, RO90 and a bunch of other little junk and accessories it would be nuts to get into listing..
Offline ear3
Re: 10% angle in 4" stock
« Reply #1 on: December 11, 2014, 01:52 PM »
What about a lap joint with OF1400?
Offline Iceclimber
« Reply #2 on: December 11, 2014, 02:07 PM »
My bad.
I am passing along bad info. It a piece of hollow 8" x 18" stock and he needs to be able to cut at least 4" in to get throught the 8" measurment as he can do it in two passes one from each side.
I guess a sawsall would not be a clean enough cut and a regular skill just wont do ot either.
Offline Wooden Skye
« Reply #3 on: December 11, 2014, 02:11 PM »
Do you have a bandsaw?  That should be able to get a fairly clean cut, might just need minor cleanup.
Bryan
TS 55, (2) 1400 Guide Rails, 1900 Guide Rail, MFT/3, Domino DF 500, 2 domino systainers, ETS 150/3, RO 90, CT 26, (2) OF1400, RO 150. RTS 400, LR 32 set, PS300 jigsaw, 3 abrasive systainers, (2) sys toolbox, (2) sys mini, clamps and other accesories
Offline ear3
« Reply #4 on: December 11, 2014, 02:14 PM »
An 8" beam?  Since the swordsaw is NAINA (and way expensive anywqay), what about the beam cutter attachment to the worm drive?
http://www.amazon.com/Prazi-USA-PR7000-Cutter-4-Inch/dp/B0000224SA
UPDATE: or bandsaw, as suggested above, provided it had sufficient HP.  Do you have a picture thlought, I'm having trouble imagining what you mean by "hollow" 8" x 18" stock.
Offline charley1968
« Reply #5 on: December 11, 2014, 02:15 PM »
Maybe just a plain handsaw??
Just for today..
Offline Charlie Mac
« Reply #6 on: December 12, 2014, 10:40 AM »
I'd also use a handsaw.
