Author Topic: Plans for MFT3 / Sysport cabinet  (Read 43225 times)
Offline Kodi Crescent
« on: January 30, 2012, 07:25 AM »
Hi.  I'm getting ready to make some sort plans for a sysport-like cabinet that my MFT/3 will sit on.  My plan is to have a rolling MFT that I can wheel around that will contain space for some systainers and a CT-22.  Surely someone here has done this before.
Does anyone have any plans or pictures of ones that you've built?
Thanks!
Offline mattfc
Re: Plans for MFT3 / Sysport cabinet
« Reply #1 on: January 31, 2012, 05:17 AM »
Thanks!
Here is what I did (combined rolling MFT + CMS)
http://festoolownersgroup.com/festool-jigs-tool-enhancements/sysport-cms-mft-(work-in-progress)/
Offline mparka
« Reply #2 on: January 31, 2012, 09:13 AM »
This is a thread exactly this topic was discussed.
Hope that helps.
Rolling MFT3 cabinet
« Reply #3 on: February 03, 2012, 07:34 AM »
Thank you both.  Great ideas!
Offline Sparktrician
« Reply #4 on: February 03, 2012, 11:11 AM »
I've had some down time this week, so I built my own version of a rolling MFT/3-Sysport using 18mm baltic birch plywood.  The criteria were that it had to be built 100% on metric system (my first), it had to hold an MFT/3 (with legs folded) at normal height so it would line up with my other MFT/3 sitting on its own legs, it had to have the same footprint as an MFT/3, interior partitions had to be line-bored to accept drawer glides and/or shelves, and it had to be assembled using dominoes (I also used pocket screws to keep things together as the adhesive set up).  I used 101.6mm locking casters from Woodcraft which are 130mm high including hardware, and sized all the component parts from there to achieve the goals.  It's still a work in progress; I still have to acquire some Accuride glides and make the pull-out shelves.  The center sections are likely to have drawers in which I can store boxes of abrasives for my various Festool sanders.  In any case, it rolls around quite well and the locking casters hold it in place quite well.  As you can see, I nailed the height just right.  There are four 100mm x 50mm x 12mm pads glued and brad-nailed to the top as alignment blocks to keep the MFT/3 from slipping off during material manipulation.  They are there for alignment only.  The MFT/3 actually sits on its own pads.  If any FOGgers are interested in the cut sheets which have dimensions, I can send them as a PDF file.
And yes, I know there's a nut missing on one of the caster pads.  There was apparently a 1/4" nut in the box of 5/16" elastic nuts, so there's another trip to Lowe's.
Edit, 12/23/13:  I did some re-thinking today of how I did the system holes in my Sysport, and have modified the narrative PDF file to reflect the re-think.  Both the cutsheet and the narrative document are now attached to this message for your ease in downloading.
[smile]
« Last Edit: December 23, 2013, 02:29 PM by Sparktrician »
- Willy -
Offline RL
« Reply #5 on: February 03, 2012, 11:20 AM »
darn fine job, sir!
I would be tempted to shift the fence and guide rail to the other MFT top to give yourself really good outfeed support.
« Reply #6 on: February 03, 2012, 11:25 AM »
darn fine job, sir!
Thank you kindly, sir.  I considered that, and may just reverse the order of MFT/3s in the shop to do that.  The shop is in quite a bit of disarray at the moment as I reconstruct things, and like the ability to use the new sysport as a roll-around close to the door.  I still have the obstructions of two Lally columns in the shop to contend with, and if I do reverse the order of the tables, one will be right smack in the way of the rail.  Much yet to be done in any case.
 [smile]
- Willy -
« Reply #7 on: February 04, 2012, 05:12 PM »
Thanks!  That's very similar to what I plan on doing.  I'm considering the aluminum version as well.  That may be outside the budget though.
« Reply #8 on: February 26, 2012, 07:51 PM »
Just as a follow-up, here's a photo of my version of the Sysport with the shelves mounted on glides.  I used dominoes to keep the systainers from sliding off to the front, and a simple cleat on the rear of the shelves to keep the systainers from sliding off to the rear, although I'll likely replace the cleats with dominoes in the near future.  Each of the large compartments will hold a Sys4 and a Sys2 or three Sys2s.  The space under the MFT/3 turns out to be a good place to stash the parallel guides, too.
 [smile]
« Last Edit: February 26, 2012, 07:55 PM by Sparktrician »
- Willy -
Offline wow
  • Inactive Member
« Reply #9 on: April 07, 2014, 10:12 PM »
As a fairly new member here, I am still working my way through old threads to educate myself and benefit from the wisdom of others. Since it has been over 2 years since you built this, I am wondering what you have learned in that time and if you'd do anything differently?
Offline sprior
« Reply #10 on: April 07, 2014, 10:26 PM »
Pictures of version 1 and 2 of mine are in this thread.  The first version was good, the second is significantly better.
« Reply #11 on: October 23, 2014, 02:06 PM »
Wayne, I apologize for not seeing your post (below) sooner.  There are a few things I'd do differently with 20/20 hindsight.
  • First, I'd use the LR 32 to line bore the system holes into which I screw the drawer glides (I didn't have the LR 32 when I made this.)  I'd also use a horizontal pattern that reflected the actual spacing of system holes in the glides.  This was not clear thinking on my part when I built it to not be aware of that spacing and adhere to it.  With the LR 32 and parallel guides, it would be a piece of cake to do it right.
  • Second, I'd use QWAS Dogs in 20mm holes (or something like them) to locate the corners of the MFT on the top of the Sysport rather than the glued-on blocks.
  • Third, I'd edge-band the exposed edges to make them a good bit neater.  This would entail reducing certain dimensions slightly to compensate for the additional thickness of the edge banding.
  • Fourth, I'd eliminate the narrow center section on each side and move the columns adjacent to each other, making it possible to place drawers on one end, much as SPrior (Steve) did.  I really like that idea.
  • Fifth, I'd not store the parallel guides under the MFT.  They make it a real pain to do post-work clean-up.
  • Sixth, I'd spray paint the entire assembly in a gray that closely matches the Festool gray, or alternatively, use Osmo Poly-X on the Sysport as well as the MFT tops to be consistent.  Yeah, I know, it's a bit anal...
  • Seventh, I'd consider making a built-in port in which to park the CT 22, keeping the boom arm much closer to the Sysport, and allowing room for proper ventilation.  This would eliminate some of the drawers, I know.  Someone else on the FOG did something like this and I like the concept.
  • Eighth, I'd mount a power strip to one end.
If anything else comes to mind, I'll prattle on about that when it strikes me.
- Willy -
Offline sprior
« Reply #12 on: October 23, 2014, 03:35 PM »
Your first and third points are changes I made between ver 1 and 2 of my design so I totally agree.
For your second point I'll say that I rarely (almost never) take the MFT off the cabinet so it shouldn't matter much, but I went with a circle of dowel screwed into the corners instead of a glued block just in case.  Now that you mention the QWas dog idea though...  After I finished this I got a 3D printer and as a test printed some dogs, now sometime when I get bored I'll print up 4 of them that fit a MFT hole and have the same diameter as the dowels, drill the holes and swap them in.
The drawers on the end are REALLY nice.  My only nit was that if they were just slightly taller my Syslite would fit in them while in their case without dragging across the top - works the way it is.  I have a space for my Seneca parallel guides (I sold my Festool guides and bought these) under the drawers so I don't have the cleanup issue.
While I should have done a poly finish on my cabinet, I'm real lazy about finishes.
« Reply #13 on: October 23, 2014, 05:49 PM »
Steve, I also almost never take the MFT off the Sysport, except when I need additional assembly space.  The blocks I used originally work perfectly for holding on the MFT, but I think that they get in the way sometimes when the MFT is not atop the Sysport.  The QWAS dogs might alleviate that issue.  I'd be interested in knowing if your 3D printed versions work well.  You might be able to make the larger diameter tops a bit lower to match the height of the gray plastic pads on the MFT.
- Willy -
Offline sprior
« Reply #14 on: October 23, 2014, 07:33 PM »
Sparktrician,
Just sent you a PM - I think.  If you didn't get it let me know.
Offline sprior
« Reply #15 on: October 23, 2014, 09:39 PM »
Because it was just that easy I designed and printed a sample dog on the 3D printer.  It's made of ABS plastic with a 50% infill and the small end with a 19.95mm diameter fits like a glove in a MFT hole and the top diameter of 24.5mm matches the dowel that currently locks the MFT in place.  It's strong enough to use for clamping, but of course not calibrated like a real Qwas dog.  I should have no problem drilling holes centered on the screw hole and then I can drop the dog in the place of the dowel.  Just have to print 3 more just like it.
Offline eddomak
« Reply #16 on: October 23, 2014, 10:39 PM »
How about printing the dogs with the holes already missing from the design? Should save on plastic and be more precise? Just an idea though, as I have no experience with 3D printing.
Offline sprior
« Reply #17 on: October 23, 2014, 11:03 PM »
The screw hole I was referring to is in the top of the cabinet.  If you look at the round piece of dowel on the right you can see it is screwed into the top.  What I'm talking about is drilling a 20mm hole through the top centered on the existing screw hole once that dowel is removed.  Then I can slip the plastic dog into that hole and it will have the same dimension and location on the table as the piece of dowel it will replace, but it will simply pull out of the hole when desired.
Offline wow
  • Inactive Member
« Reply #18 on: October 24, 2014, 12:25 AM »
Great synopsis - thanks! I have yet to start building my MFT or Sys Cart, so I really appreciate your insights.
Offline PreferrablyWood
« Reply #19 on: October 24, 2014, 01:04 AM »
I think Sparktrician has made a Sysport cabinet that I will emulate when I reach the stage where I need one. I like that he uses Two MFT/3's so he can take it of the Sys port to make extra assembley space, the modular aspect is very appealling!!
Thanks for sharing!
TS 55 R EBQ, Vecturo OSC, BHC SDS, RO 150, 850 HL E Planer, MFS 400x2, MFS extensions MFS VB 700 x 1 MFS VB 1000 x 2 . CMS GE, OF 2200, CMS OF+ CMS TS 75 insert modules. SYS-MFT Fixing-Set,
Festool 18V HKC 55, TI 15, CXS 2.6 Ah version, RO 90 DX, PDC 18/4 plus   TS 75 EBQ, PSC 420, OF 1010, RS 300 EQ, CTL Midi, MFT 3
Offline eddomak
« Reply #20 on: October 24, 2014, 05:29 AM »
Sorry, I get what you are saying now.  ;D
« Reply #21 on: October 24, 2014, 08:00 AM »
Sparktrician,
Got it, Steve.  Looks like a winner to me.  PM sent back.
 [smile]
- Willy -
Offline mikey2
« Reply #22 on: July 29, 2015, 04:46 PM »
I just started one of these, and have my own solution for the exposed caster nuts on the bottom panel. I will place T-nuts in a shallow counterbore so they are flush with the top of the bottom panel, and come from below with a bolt and washer through the caster mounting plate. The Woodcraft 3" and 4" casters have enough clearance, cannot say for other brands. The T-nuts could then actually be partially under the vertical panels to get the casters as close to the edge of the cabinet as needed.
Offline GarryMartin
« Reply #23 on: May 22, 2016, 07:32 AM »
I'm trying to get around to starting my MFT and KAPEX workstations and have been reviewing my old notes. I've found quite a few images I'd saved at the time, so where I can, I'm trying to add them back in to the threads where the photos were previously lost.
Hope someone finds this useful and that it's OK with the original authors.
Offline McNally Family
  • Festool Atomic Phaser Particle Blaster (APPB Set)
« Reply #24 on: May 22, 2016, 08:51 AM »
I have an old table saw with a cast iron top that i don't use anymore, and have considered purchasing the Festool MFT/3, to place on top of the saw somehow, because the saw is so much more stable than the MFT/3 would be, even with leg supports (due to the weight of the saw I suspect).    I am not concerned with mobility, so having the whole project shop-bound is fine.
The owner of our local Woodcraft store has a cabinet similar to your pictured version, except he has removed the legs on the MFT/3.  I spent some time looking it over yesterday, and just now studied your pictured version.  The only potential problem I could find, other than figuring out how to secure the table on the saw, was the fact it seems to create limited clearance on the underside to the MFT/3, which would mean regular clamping would be a one sided affair, with the body of the clamp on top of the table, which in itself is not a deal killer, but it is nice to have the option of clamping from underneath the table as well.   I guess I need to study the idea of further elevating the space between the saw and tabletop to solve the problem.   Of course, then we are talking about raising the working height overall, which may actually be an improvement.
GREEN: In order of purchase = | CT26  |  RS 2 E | Hose w/ Sleeve 3.5m | 115mm X 226mm Hand Sanding Block | 80mm X 133mm Hand Sanding Block | HSK D21.5 5m hose | CT Boom Arm Bundle Set | 1080 Plate for custom MFT | OF 1400 EQ Router (metric) w/accessories | SYS-Rock BR10 | Cordless Sander RTSC 400 Set |  Cordless Delta Sander DTSC 400 Basic | Linear Sander LS 130 | PDC 18/4 set | CXS  2.6Ah Set | Installer Cleaning Set (2018 version) |  New style Festool hose D 27/32 x 3,5m AS/CT | Replacement Hose Garage | Remote control CT-F I/M-Set | MFH1000 work stool | Next purchase: TBD
RED: // Mafell P1cc  //  MT55cc  // Next purchase: TBD
Offline GarryMartin
« Reply #25 on: May 22, 2016, 09:02 AM »
Just to make it clear with these recent posts of mine; they're not my photos, they belong to the original authors. It's just that some time ago the FOG suffered a catastrophic issue where a large number of photos were lost and only the links or thumbnails remained in the original posts.
I'd saved a number of these images in Word documents with comments etc. so that I could print them easily for reference as the print function on the FOG is somewhat limited. While I've been reviewing those documents in preparation for my own build, I've found the original threads where possible and added the photos that I essentially had "offline copies" of back into them.
Back to the point of your comment though, putting the folded table on a worksurface does somewhat limit your clamping. Some people take the legs off to make it easier, and you have essentially about 160mm underneath the table doing it in this way. You're not going to get clamps underneath with any ease, but you can still use the threaded knobs from the MFT-SP Work Clamps for example.
Offline sprior
« Reply #26 on: May 22, 2016, 11:50 AM »
I didn't know about the big data loss on this forum, that's a big shame.  If the original images were still around would the sysadmins be interested in putting them in place so the original posts could work again?
« Reply #27 on: May 22, 2016, 04:58 PM »
Well that explains a whole bunch!  I wondered why I would sometimes click on a photo within a post, and come up empty handed....
As for the worktable idea, my "plan C" (Plan A, just use the MFT/3, Plan B, use the table saw as a base, and Plan C, the custom approach) if the table saw idea does not work out, is to build my own table, utilizing the basic premise of the MFT/3, but without  incorporating the actual MFT/3 itself.  Here is an interesting set of plans I found on the same website I buy my German sandpaper from:
http://vsctools.com/shop/the-ultimate-work-table/
The guy who designed this table is rather bright, and I enjoy watching all his video's on YouTube.  He goes by the name of "AskWoodMan".   Just Food for Thought!
Offline Patrick Cox
« Reply #28 on: May 23, 2016, 02:00 PM »
I am curious what type of clamping is limited with the MFT3 mounted on a stand/cart?  It looks like there should be plenty of room to use the various screw and ratchet clamps that use the MFT3 holes for clamping.
Offline sprior
« Reply #29 on: May 23, 2016, 02:04 PM »
I haven't found leaving the legs on to be much of a problem, sometimes you have to wiggle the clamp around to clear the legs, but it hasn't been enough to annoy me (yet).  I like the idea that in theory I could just grab the MFT off the top and go somewhere if necessary, though in reality I'll probably never do that.
