- Jan 22, 2007
Thought you guys might be interested in this one because they come in a color similar to Festool green. They are even using Festool in their video. No affiliation with Festool, however. [smile]
Save $15 if you pre-order the new IsoTunes FREE Wireless OSHA-approved Bluetooth earbuds.
- Ultra-Lightweight - At just 4.5 grams each, these earbuds are light enough to forget they're in your ears
- All-Day Battery Life - 7+ hour battery life gets you through long days without having to recharge
- Charge On The Go - ISOtunes FREE comes with a protective case that charges your earbuds -- two full times -- before needing a recharge itself. That's 21+ hours of battery life before needing to find an outlet
- Free to Talk - Dual omni-directional microphones with CVC background noise cancelling means you can take calls in loud environments, with one earbud or both
- SafeMaxTM 85dB Volume Output
- Designed & Proven to Reduce Noise - 22 dB Noise Reduction Rating ANSI-certified, OSHA and NIOSH Compliant
- Built to Last - IP45 Rated to protect against sweat, water and dust
- Backed by a 1-year manufacturer's warranty
