Carquest said:
I have a Milwaukee corded hammer drill, so after reading your comments I think I will go with the regular Festool. I've never owned the C type drill, what are your opinions on that type handle versus the T type?
The choice between the
T18 or
C18 usually boils down to personal preference. If you have a dealer near you, I would recommend holding both to see which you prefer. If you end up buying blind, remember you do have a
30 day return option if you simply don't like the one you order, so you won't be married to whatever you choose initially.
On paper, it appears the
T18 has slightly more power, but I doubt it is a large enough difference to sway me one way or another. I just liked how the
C18 drill fit in my hand. The fact I could
"hang" the
C18 also appealed to me, rather than alway's needing to stand it up, or lay it on it's side.
Perhaps I was swayed by the fact my original purchase was the
CXS, which is also the C style, which I took back and upgraded to the
C18 (although I ended up winning the
90-year anniversary edition of the CXS in the end, so now I have both).
It could have just been the fact when I walk through Home Depot, I don't see other C Style drills on the shelves, so my
Festool C18 is rather unique from a design perspective.
I don't think you can go wrong with either, although I will add you might want to consider the
CXS set as an alternative to either the
C18 or
T18, if all you need is a lighter duty cordless drill/driver. Anyone here will tell you just how much they love their
CXS, and many use it as their go-to drill, 90% of the time. Had I not won mine in a contest, I would have eventually re-purchased it. It is a sweet little driver/drill, that can handle all but the most intensive projects. It is not however on the 18v platform, so if you are into cordless tools, you will end up with another platform to maintain, and you would lose the advantage of sharing batteries between the other Festool cordless tools.
Sorry if you are more confused now than you were. The initial plunge does require some thought.
