Walnut is not a tough wood. I would expect that it should cut well with the 28 tooth blade in both directions. Assuming that you are using a rail for the rips, you might want o make a partial depth cut first and then the full depth cut. On the rail the saw had a depth of cut of about 1 15/16" so you are fine.
