3/4" Euro-Color-Ply Phenolic Plywood Available in 2' x 4' sheets
Anderson-Plywood
Festool Dealer
Euro Color Ply is an ideal material for the furniture and joinery industries. Its features provide smooth and superior surfaces that are ready for use. The panels are rigid and often used for making jigs and tooling as they are extremely durable.
Size: 2' x 4' (24" x 48")
Thickness: 3/4" (19mm)
Color: Green, Light Brown, Dark Brown, Black, Red, White
Number of Plys: 14 Plys
Advantages:
Environmentally friendly, durable, easily workable, hygienic, odour free, easy-to-clean, wear-resistant, weather- and water-proof, resists commonly used chemicals. Riga Form for shuttering can be re-used many times.
Characteristics of Overlay:
Surface with an overlay is smooth, glossy and hard. It resists abrasion, it is weather and moisture proof and resists commonly used chemicals, dilute acids and alkalis. The surface is easy to clean with water or steam.
Applications:
  • Jigs and tooling
  • Desks, table tops, shelves
  • Fittings for kitchens, offices, shops
  • Garden furniture
  • Signs, billboards
Click here to order!
Anderson Plywood's Layout Square for MFT Table is also made from the same material:
I would just like to let folks know that you have to be careful with cut edges on this material as the cut edges are extremely sharp.  You definitely want to round them over.  Otherwise, it's great stuff.
Baltic Birch plywood in 3/4" x 2' x 4' is now available for ordering on our website too!
Here is the link:http://www.andersonplywood.com/birch-baltic-wpf-b-bb-mlt-lumber-bbi3424/
Grade: B/BB
Size: 2' x 4' (24" x 48")*
Thickness: 3/4" (18mm)
Number of Plys: 13 Plys
Glue: T1 Exterior Grade
Core: Veneer Multi-Core
Cut: WPF Rotary Cut
Applications:
Because of its pleasing appearance, it is a wood typically used for cabinetry and other furniture. Baltic birch is suitable for a variety of projects, from cabinetmaking to building construction.
This looks fantastic, I am working on a project soon to create a lot of craft cabinets and I'd love to use this material, couple things I'd need to work out.  Is there an edge banding that matches it?  Is there a larger sheet available like regular 4x8?
Thanks!
