Saturday I'm planning to build a rolling base cabinet for wood turning tools and this is also a practice project for doing things the 32mm way.
I'm planning to build the cabinets the standard 24" (610mm) depth with a 19mm gap between the back edge and the dado for the back, and then the front holes 37mm from the front edge. The problem of course is that the sheet of plywood is exactly 48" wide and I've got to clean up the factory edges and make one kerf down the middle to cut the panels, so of course there's no way I can really get the 24" (610 mm). For this project I don't really care if the depth is exactly 24", I'm just trying to figure out how to follow the standard correctly.
So what's the standard 32mm system way of dealing with this? I want to drill front, middle, and back sets of holes that will line up with the holes in drawer slides so I assume they should be spaced at 32mm increments. Should I make the whole cabinet depth 578mm instead?
