Richard/RMW
- Jul 11, 2010
So it was 60 degrees this afternoon, the boss was having dinner with her girlfriends and UPS showed up with a box from Woodpeckers - Party Time!!! [big grin] [thumbs up] [thumbs up]
Anyway, this idea has been brewing for a while, I basically wanted a guide that could be adapted to various routing needs.
The basic router guide looks like this:
[attachthumb=#]
Rather than using an edge guide I wanted to make use of the 40mm guide bushing and run it between 2 parallel tracks, to do this I made a couple of spacers that fit the Woodpeckers track. The tricky part is getting the spacing right, the guide bushing is right at 40mm, the spacers are about 0.05mm wider, just enough to prevent binding.
[attachthumb=#]
[attachthumb=#]
[attachthumb=#]
[attachthumb=#]
[attachthumb=#]
In one iteration I plan to to mount it to a material-holding jig using several of Pete Pedisich's ideas from Mortising Jig for Festool OF1400. This guide would replace the 8020 extrusions and the edge guide that Pete used.
I also wanted to be able to clamp the guide to material to be cut. I was not sure if the Festool clamps would fit the t-slots so I bought some of Woodpeckers clamps, which are really nice.
[attachthumb=#]
I did get the Festool clamps to fit by sanding off a tiny bit on each side, probably less than 0.25mm overall.
[attachthumb=#]
[attachthumb=#]
The final result is a very flexible guide that will fit most diameter bits (anything under about 1.5" diameter) and I can get a pretty good depth of cut. Shown here I have the full cutting depth of a 1/2" carbide end mill with about 1.5" flutes.
[attachthumb=#]
I used 30" tracks, which lets me route a 24" wide groove after accounting for the spacers and the guide bushing.
My next project is to make a platform for this to sit on that I can clamp material to, similar to the mortise jig Pete made. I also plan to modify the spacers so I can attach a 40mm wide strip of 1/4" MDF between them, inside the space between the tracks. This will serve as a sacrificial template that is routed through, which will then give me a reference point for the edge of the bit that I can align to a line on the material to be routed.
Comments or suggestions are welcome.
RMW
[attachthumb=#]
[attachthumb=#]
[attachthumb=#]
[attachthumb=#]
[attachthumb=#]
[attachthumb=#]
[attachthumb=#]
[attachthumb=#]
[attachthumb=#]
[attachthumb=#]
RMW
