492-525 Center drill bit.
How big is the centering mandrel thingy?
I have 3 floors of old doors to fit into 140 year old openings.
I am drilling a ton of pilot holes and some of the jambs resemble swiss cheese by now.
Will this word for mortise strike sets all the way up to some big 4 leaf hinges?
Oh, all the doors were bought at a salvage store.
Ughhhhh.
Brice Burrell said:
mastercabman said:
I believe it is a 5mm bit.
It is 5mm. I've got one, nice bit but pricey. I use mine on euro hardware and the occasional shelf pin hole.
That is not quite 140 year old door jambs and who knows how old doors.
I wonder how long it will take me to render it useless?
Is the bit replaceable?
WarnerConstCo. said:
Can I put a smaller bit in it?
Brice is correct, in that you cannot install a smaller bit into the holder and have it work correctly.  The holder has a 5mm bore to accept the drill, along with a larger counterbore that accepts the spring that pushes against the centering collar.  The 5mm drill bit is held tight within the 5mm bore with a set screw.  Attempting to install a drill bit smaller than 5mm would result in the drill bit being off center -- that isn't what you would want.
