497701, Festool Workshop Cleaning Set with the CT Mini
Billy D
Can anyone tell me if this kit can be used - with good results - with the CT mini?
Bill
I have the cleaning set and a Midi.  It will work with either the 36mm hose or the hose that comes with the Midi/Mini.
You do give up storage of the hose in the hose garage and the 36mm hose does not have a right angle connector, so you cannot place another sustainer on top while using the larger hose.
But the tools that come in the set work well with the smaller hose on the Midi.
I also have the smaller plastic set from Festool - which comes in a Sys1.  I actually leave it attached on my Midi for use in my garage or away from my shop most of the time.  The larger set I leave on top of a CT26 vac in the shop with a boom arm.
