5-hole pattern 5" sanding pads?
jollytanaka
I have recently acquired an ETS 125 which is becoming my go-to sander. Unfortunately, I have box after box of 5-hole 5" sanding discs which I use with my other non-Festool sanders. Has anyone heard of aftermarket sanding pads for the ETS125 with different hole patterns?
The easy solution would be to take a Festool pad and drill holes, but I'd rather find something off the shelf.
While this does not answer the query, the best take is to sell on the non-Festool paper as soon as you can get rid of the other sanders.
Big part of the ETS 125 excellent dust collection is the different dust extraction holes geometry. Festool did not make "their own" geometry just for the giggles.
I could see a point in using the Festool/compatible pads and paper on cheaper sanders. Not the other way round. So do not hold your breath on someone making it.
If you like the ETS 125 finish sander, you are soon to want an ETS EC 125 or, better, the cordless ETSC 2 125. At that point, non-Festool paper will become redundant fast.
Not only the dust extraction, also the cool running paper, which has everything to do with their pads and hole pattern
That makes zero sense
Don’t drill. Buy a leather punch and use a block of wood for the backer and strike with a hammer. The drill will make a mess of the pads. Chuck the punch in a drill and use a sharpening stone to re-sharpen.
Note: Most of these punches are not ready to use out of the box. Most need a little work with a stone to be really sharp. Osborne is the premium punch maker. But for occasional use almost any of these will suffice. (The cheaper ones may require more frequent sharpening. I would use a punch slightly oversized so that alignment is not as fussy.)
or you could laser cut them. That's how Klingspor does it. You can see the tell-tale black soot around the edges.
Either way, you will get better performance and a longer life out of quality paper/abrasive. The cheap stuff is a false economy. You might get more individual pieces, but they don't last as long.
I haven't made this, but if ever I do it'll be like this one.
Yeah fix the paper. There is nothing wrong with the pad.
I had not seen that word before, even though it exists in my own language too.
I am too frugal to get rid of several sanders and hundreds of dollars of 5-hole sanding disks, so the thread you mentioned fits my bill for sure. I hadn't thought of punching holes in the paper to match the ETS125 pads. Thank you.
Not sure if this is the issue but I have an older 5” Festool sander. I have a bunch of Festool sandpaper for it. Sometime between 2004 and 2008, they changed the hole pattern. I was stationed overseas at the time and I missed out on their trade in program. I still have a bunch of paper with the old pattern. Festool wouldn’t swap out my paper, but they did find an old sanding pad with the old pattern to send to me. Of course it was old and so has also disintegrated. Looking to sell my old pattern paper if anyone is interested.
Selling the old recoups some of the previous investment, and then you're saving on purchasing new hole punching equipment - but mostly you're saving the monetary value of your time in not doing all that.
As I get to be an even older woodworker, I find that time to make the projects I really want to make is my most valuable commodity.
