Dave Ronyak said:
Maybe super Sleuth Forrest Anderson will respond with better up-to-date information for you.
I heard that!
The boom arm is actually listed in the USA and UK parts catalogues, but not in the place you'd probably expect.
Go to the
USA Parts Catalogue
Instead of looking under "Dust Extractor", click the "+" next to Accessories to expand that branch
The short code for the boom arm is "CT ASA", so click the "+" next to that entry to expand that branch
Click on "492762 - CT-ASA/SB 120V" to get a list of parts and a parts diagram of the boom arm in the right-hand pane:
The 50mm hose assembly is shown as parts 1, 3 and 4:
1 493047 D 50/D 50 VM-AS
3 452896 D 50 DAG-AS
4 452386 D 50 MW-AS
Item 3 is two rotating 50mm connectors, part number 452896. The
Festool USA catalogue for 2008/2009 has them, and lists them on page 20 as follows:
Hose Sleeves - Rotating connector:
Hose connector to fit inlet of dust extractor, external dia. 2 9/32? (58 mm).
Antistatic version for D 50 suction hose - 452896 - $23.00
Item 1 (493047) is a reducing sleeve for connecting the 50mm hose to the tool hose, and is listed on the page 21 of the USA catalogue:
Hose sleeves?Reducing sleeves (continued)
Hose connector for tools or cleaning sets.
Antistatic connector sleeve
To connect suction hoses D 50/D 36/D 27 - 493047 - $13.50
The hose itself is No 4, but if you search the Festool USA catalogue for 452386 or D50 MW-AS, it doesn't appear to be listed. However you will find it listed on page 282 of the
UK catalogue which shows three versions of 50mm anti-static hose:
Suction hose D50 antistatic:
with rotating adapter and connector
Diameter: 50 mm, Length: 2,5 m D 50x2,5m-AS 452888
Diameter: 50 mm, Length: 4 m D 50x4m-AS 452890
ordered by metre (without rotating
adapter or reducing sleeve),
Diameter: 50 mm D 50 MW-AS 452386
The 50mm boom arm hose turns out to be an unspecified length of order-by-the-metre anti-static 50mm hose (plus two rotating connectors and a reducing sleeve).
Although not listed in the catalogue, you may well be able to order the required length of 50mm hose from a dealer as a spare part.
As a guide, the UK price is 24.45 GBP + VAT per metre at 2008 prices, compared to 9.55 GBP + VAT for the 493047 reducing sleeve.
As to how much 50mm hose you should order, can someone measure the length of the 50mm hose section on their boom arm?
Forrest
