574700 Festool Cordless.H. Drill PDC18 Li 5.2 Basic New Sold
Dtools
574700, Festool Cordl.H.Drill PDC18 Li 5.2 Basic
Features:
Tremendous Range—Driven by a four-speed gearbox, you can drop it down low to hog out material, switch to high-speed hammer function to plow through concrete, or just go mid-range for all your common drilling applications.
The Most Versatile Drill Ever—Supported by its own set of FastFix interchangeable chucks and the complete Centrotec bit change system, it’s easy to see how this might be the only drill you could possibly need.
You Won’t Beat This Drill—Our unbeatable, industry-leading EC-TEC brushless motor is housed within the toughest glass-reinforced nylon we could find, plus the front end is jacketed with cast aluminum for added durability. This drill will stand up to anything you can possibly throw at it… or throw it at.
With the PDC 18, Festool set out to create the ultimate drilling machine. A fourspeed gearbox provides loads of torque for hogging out material with large diameter drill bits, then quickly switches over to deliver 3,800 RPMs to blast through concrete with its hammer drill functionality. You will not find a tougher drill, nor one that offers nearly the capability of the PDC, which quickly adapts for drilling into tight spaces with a FastFix right-angle chuck, and is further supported by the entire Centrotec range.
Specifications:
Motor Type EC-TEC Brushless
Battery Voltage 18 V / 5.2 Ah Li
RPM (Setting 1 / Setting 2) 0–400/0–850
RPM (Setting 3 / Setting 4) 0–1,850/0–3,800
Chuck Capacity 1/16" (1.5 mm)–1/2" (13 mm)
Max. Drill Diameter (Steel) 15/32" (12 mm)
Max. Drill Diameter (Wood) 1-31/32" (50 mm)
Max. Drill Diameter (Brick) 13-32" (10 mm)
Torque Setting Range 4.4–106 in-lbs (0.5–12 Nm)
Max. Torque in Steel 531 in-lbs (60 Nm)
Max. Torque in Wood 354 in-lbs (40 Nm)
Weight 4.1 lbs (1.9 kg)
Includes:
Centrotec Chuck
Centrotec Bit Holder
FastFix Keyless Chuck
Side Handle
T-Loc Systainer SYS 2
Asking $275.00 plus shipping. New  Any questions message me. Thanks Donny
