6" Abrasives
Samo
Hey Foggers,
So I'm hoping to stock up on some 6" before the promo. is over.  I have the RO 150 FEQ and the ETS 150/3.  I really work the  Rotex and with the new abrasive available, what do you guys recommend as "must have" in your 6" kit?  [unsure]
I'm looking for the min. must have, as I also with be doing a package deal to take advantage of 10% off one more sander and one more vac.  Ouch!!!  [eek]
Thanks, Sam
You forgot to tell everyone what you plan on using the sanders on -- objects and materials.
Ken,
Of coarse all objects and all materials.....Duh!!!!!!!!!!!
Are you cleaning a hole saw now?
Samo said:
Ken,
You don't understand what I was getting at.  I wanted you to tell us what objects you wanted to sand and what the objects are made of if it's not easy to figure that out.  Then members can tell you what sandpaper would work best, in their opinions.
Ken,
I have florescent green spray paint. I can spray it all over the mint Saw Boss, if that helps?
Objects?  I don't need any stinking objects.
All surfaces, painted, stained and petrified.  If I had any idea of the future I would not be asking.
First, for general use on all surfaces I'd suggest you stock up on Brilliant or Granat, which are mostly interchangeable in my opinion.
Grits: P40, 60, 80, 120, 180, 240, 320
Then for fast paint removal on rougher jobs you'll want some Crystal in the low grits.
Grits: P40, 60/80
Some Rubin for using on bare wood. Above 120 I use Brilliant or Granat.
Grits: P50, 80, 120.
And finally some Saphir for the really rough jobs. Removes about anything.
P24, 50.
Samo – appreciate where you’re coming from.
Please consider getting some low grit Granat.  Would suggest 40, 60, and, maybe 80.
Let me explain.
A while back, customer wanted 2 bed flat painting whilst they were on holiday.  I’m on a roll, with my not long acquired R0 150 + Midi.  So, as an experiment on my part, decided to sand down their flush doors – original wood substrate never smoothed at all; horribly rough surface.
Job finished; the end result was good, not exactly mirror like – but pretty damn good.
So another person wants the same.  This customer has me paint something, living room in particular, every year; seriously heavy smoker.  They pay, so I don’t care!  And yes, have suggested they clean the painted surfaces occasionally.  They want a fresh coat of paint.
Come to sand down doors (y’know – end up with 1/3 bare wood – you get the idea.)
The second door and, I’m in trouble.  Neither Brilliant, nor Cristal were cutting into surface – to exaggerate, almost skidding across surface - using Rotex mode.  I’m almost panicking, and, getting seriously concerned – what’s going on?  But a bit angry as well.  So, out comes Saphir 36 – yes really.  O/k it worked to an extent, but horrible scratching.
Round trip to dealers (60 miles.)  Bought some 40 and 60 Granat.
Well talk about unbelievable.  The Granat just got on with it.  But tough – one disc covered about 1/4 to 1/3 of door, before losing its ‘edge.’
Cannot tell you how relieved I was.
What paint had I used?  Dulux (Primrose White) non-drip gloss low VOC – it’s what the customer bought.  Presume this is what Festool on about, when they talk about ‘modern’ paints, and, Granat being the one to use.
Sorry for going on – should have had therapy.  Hope I haven’t got some sort of PTSD.  [scared]
oldie,
Thanks, I do know the feeling.  [cool] Needing therapy.
I have had two very profitable jobs with just the sample adhesives included in my RO 150 kit.  One was restoring wooded doors that were saved by epoxy repair and repainting.  Her Painting Contractor could not or would not do them for her and since she had me replace all of the remaining ext. doors, she was happy they could be saved.
On the same job I was taking my lunches at the local cafe and asked the owner if he would like his table refinished.  He had a holiday three day weekend coming up and I sold him with the fact that I could do the work with no dust.  He only had to close one extra day for the work and I bought a new HVLP spray rig and still made a decent wage.
Alex,
Thank you Sir,
I will use your recommendations along with the pricing of each type and see what I can manage.  [crying]
Thanks again!  I read all your posts and they have helped on my sander purchases.
Sam
Samo, I have most of these types and grits in stock for 5 different Festool sanders. I mostly buy the 10 packs though, and if possible prefer to have somebody else pay for them when I help them with a job.
To get started, get the Brilliant or Granat grits. They can do most jobs on all surfaces. Later you can get others types when needed. Just add them one by one over time.
