80/20 Cutting Slot for Clamps
Bugsysiegals
I'm building a MFT cart like the one in the link below using 80/20.  The Festool clamps fit in the track amazingly but only slide in if the end is open.  As seen in the images of the cart below, I'll have several segments which do not have the open ends and can only think to grind some material away so the clamps can slide into the track as also seen in the link below.
The question, how do I remove aluminum material in a way which looks decent and isn't jagged and sharp afterwards?  I was thinking perhaps there's some sort of bit I can chuck in my drill press, set up a fence, align the extrusion so the bit is centered, and slide the extrusion down the fence to get a nice straight cut.  Is there such a bit which would cut in this way and leave a nice finish or is there a better way to achieve this?
MFT Cart
Aluminum can be milled with carbide bits in a router.  Possibly construct a jig such as the type used to mill recesses for door hinges and secure to the extrusion.
I mill lock cutouts in aluminum doors with aluminum router bits that I buy from Toolstoday.  I use WD-40 for lube, works great although it makes a horrendous noise.  Take light cuts.  I used my MFS jig with 3" angles attached to the jig and clamped to the doors.
