96 mm MFT hole spacing
ccarrolladams said:
Hi, Sparktrician,
Although I have studied transcripts of the Standards Committee meetings, I have found no discussion of any particular set-back of hole rows. Perhaps this is because parts would functionally interchange even if the set back were to be different. On the other hand, there was a lot of discussion before 80mm up from the bottom fixed shelf and down from the fixed top shelf became a standard. Remember, the 80mm is measured on the inside from the inner face of the shelf, not necessarily the physical end of the side piece.
Reading the hundreds of books about using System 32, the common explanation for the 37mm from off-set is that experience soon showed that if the front shelf support were off-set more an empty shelf would tip forward and if less than 37mm the support pins would be too far apart for ideal support. I have not found bench note from experiments. I like to think hundreds of apprentices were required to drill test holes every millimeter from 30mm to 60mm so tipping tests could be done.
Also, one of the first post-WWII European-style cabinet door hinge needed a hole 37mm in from the face of the cabinet. My guess is this is the reason most of us use the 37mm off-set.
At about the same time as the hinges using 37mm off-set became popular, manufacturers designed drawer slides using a 37mm off-set for the forward hole.
My suggestion is to double check the installation specs of the selected hardware before calling for the 37mm off-set for the outside hole row!
Thanks very much for your insights, Carroll.  This is the sort of information that most literature I've seen on the 32mm system does not discuss.  It certainly adds to my understanding of the system to have an infill.
[smile]
Svar said:
Why holes on MFTs are spaced at 96 mm? Why not 100 mm for a round number and convenience of referencing / measuring? Yes, I know, there is standard 32 mm shelf pin spacing, but that is what LR32 rail system for. What does it have to do with the table top? The only instance I know of something matching to 96 mm pattern is Kapex feet, but then again Kapex was made to fit MFT, not the other way around. Is there anything in Festool arsenal that requires dog holes to be that way?
This all comes down to many attempts by users to make their own tables mimicking Festool plates, although other (not necessarily square) hole patterns might be more practical.
Is that 96mm center to center of hole? What is the distance from the center of an outside hole to the edge of the wood top? I am looking to having a friend with a CNC make a custom sized top for me and need to know the exact dimensions.
  Jack
It is 96mm hole-to-hole (centers) and 70mm to the edges (center to edge).
Just remember the 70mm edge of top to hole center only applies to the actual Festool tops.
When custom making your own tops of other sizes, such as 4' x 8' you need to stick to the 96mm on center for the field holes.
Using the 48" x 96" example the spacing from the edges will be as shown (for a 13x25 hole array).
[attachthumb=#]
